#1 2018-12-05 03:50:30
Copper36
GRUB update renders the machine unbootable
Not sure if this qualifies for a bug - Devuan ASCII 64bit is installed on an iMac 5.2 and runs OK until GRUB update. There are 6 packages version 2.02~beta3-5 intended to upgrade to 2.02~beta3-5+deb9u1. Some (or maybe all) of them are the culprit. I do not see how I could block their update via Synaptic, but probably there is a way to do it in a terminal straight with apt.
So. If there is an easy way to fix it, I'd be glad to follow it. I'm just afraid I might forget about these packages and update them automatically some time...
Thank you.
#2 2018-12-05 13:45:40
zephyr
Re: GRUB update renders the machine unbootable
To block a package use...
sudo apt-mark hold <package-name>
to unblock or unhold
sudo apt-mark unhold <package-name>
Hope this helps and what you are asking for! smile
cheers
zephyr
CROWZ
easier to light a candle, yet curse the dark instead / experience life, or simply ...merely exist / ride the serpent / molon labe
#3 2018-12-11 02:39:47
Copper36
Thank you zephyr,
One more question - after I had put them on hold I do not see any changes in their status in Synaptic. It is still in the "upgreadable" list. Is it how it's supposed to be?
Thank you.
#4 2018-12-11 11:19:10
zephyr
Make sure package(s) is on hold by running...
sudo apt-mark showhold
You should get a list of held packages and will stay that way until you run...
Here is some useful info...
https://manpages.debian.org/stretch/apt … .8.en.html
cheers
zephyr
CROWZ
#5 2018-12-18 07:19:53
spartrekus
I found a work around is to install grub with dd.
It works and it is reliable.
The grub of devuan has some bugs, sometimes it works, sometimes not.
you can install anyhow with the classic debootstrap:
https://github.com/spartrekus/devuan-installation
