#1 2018-11-18 15:31:15
HextorBRX
domain name (installation)
Hello
Out of curiosity, I would like to know when entering a domain name is relevant: https://ibb.co/jAexjf
I have always skipped this step.
#2 2019-01-19 18:05:18
PedroReina
Re: domain name (installation)
You can safely skip this step. Anyway, if you need to use it afterwards, just edit your /etc/resolv.conf and add a line like domain yourowndomain.
Then when you type ping host you will get automaticaly ping host.yourowndomain.
This is useful, as indicated by the instaler, when you have configured a home network with your own nameserver. I did, it is fun (I'm not a pro, this is not my work) and it is useful when you internal network get bigger.
Further reading: man resolv.conf and https://www.isc.org/downloads/bind/
