#1 2018-11-09 08:53:14
boycottsystemd
[SOLVED] ASCII: can't run ObConf in openbox
Failed to execute child process "obconf" (No such file or directory)
Any idea please ?
#2 2018-11-09 10:09:29
zephyr
Re: [SOLVED] ASCII: can't run ObConf in openbox
Any idea please ?
Are you adding Openbox or running an Openbox derivative?
Curious, it is suggesting you don't have obconf installed. Running CROWZ ASCII, no issues on this end.
screenie!
cheers
zephyr
CROWZ
#3 2018-11-09 10:11:05
Geoff 42
I use openbox with LXDE and obconf just works. I see that openbox recommends obconf, so it might be that it has not been installed. It should be in /usr/bin/obconf if it has been installed.
Geoff
#4 2018-11-09 10:22:06
zephyr
My thoughts exactly, not sure if he is creating or using someone else Openbox derivative, think there might even be someone using ob-generator and not the classic menu setup.
cheers
zephyr
CROWZ
#5 2018-11-09 10:28:38
boycottsystemd
Thank to both. It was running fine some time ago but it is not installed now. I don't know why.
I've installed it and it's ok.
#6 2018-11-09 10:33:20
zephyr
Most excellent! smile
cheers
zephyr
CROWZ
#7 2018-11-27 11:47:16
boycottsystemd
cheers
zephyr
Thank you smile
