#1 2018-11-02 19:42:24
icavot
[Solved] ISO verification - no trusted keys - expired keys
Hi. I'm trying to verify a Devuan ascii live ISO.
·When I run: 'gpg --import devuan-devs.gpg' I get this message:
gpg: Total number processed: 7
gpg:               imported: 7
gpg: no ultimately trusted keys found
· When I run: 'gpg --verify SHA256SUMS.asc' I get this message:
gpg: Good signature from "fsmithred (aka fsr)" [expired]
gpg: Note: This key has expired!
Is this OK?
#2 2018-11-03 01:23:22
clint.barton
Re: [Solved] ISO verification - no trusted keys - expired keys
icavot wrote:
Is this OK?
I think it's no OK. Where did you download devuan-devs.gpg file? I've downloaded it from Leaseweb mirror.. This is the output when import the key:
And when I check the SHA256SUMS.asc file I get this:
Regards. wink
JABBER/XMPP: clint@suchat.org / clint.barton@suchat.org  Diaspora*: barton@pod.orkz.net
#3 2018-11-03 13:20:15
icavot
I downloaded the files from the fau.de mirror: https://ftp.fau.de/devuan-cd/devuan_ascii/
I want to use the desktop live ISO. https://ftp.fau.de/devuan-cd/devuan_ascii/desktop-live/
#4 2018-11-03 22:24:28
Yeah, my key expired. I wasn't paying attention. I'm not at home right now, so I can't fix it. Post the sha256sum of the file you downloaded, and someone here can verify it.
Make sure you say exactly which iso you have.
#5 2018-11-04 07:56:25
icavot
This is the SHA256SUM that it's suposed to have:
76584ce7183993306af8b00edc8ffce3a1dc69b10f0a97e0a6302d49b0a63858  devuan_ascii_2.0.0_amd64_desktop-live.iso
Source: https://ftp.fau.de/devuan-cd/devuan_asc … SHA256SUMS
And this is the SHA256SUM of the ISO that I got with the program gtkhash:
I got the ISO from this folder: https://ftp.fau.de/devuan-cd/devuan_ascii/desktop-live/  (it's the amd64 desktop live ISO)
They coincide. In principle, that should be ok, right?
Also:
This is the source of the file SHA256SUMS.asc:
https://ftp.fau.de/devuan-cd/devuan_asc … 56SUMS.asc
This the the source of the devuan-devs.gpg file:
https://ftp.fau.de/devuan-cd/devuan_asc … n-devs.gpg
#6 2018-11-04 16:55:43
OK, sorry for the trouble. Here's what happened - I extended the expiration date back on Sept. 9, but I wasn't able to send the key to a keyserver due to network problems. I even used that key a couple weeks ago and didn't notice a problem, because the key is not expired on my system.
Key was uploaded to pgp.mit.edu a few minutes ago, and it show up on their website. It may take a little time to propagate to other keyservers. Meanwhile, here's the sha256sums directly from the file I uploaded to files.devuan.org back when the isos got uploaded. (May?) It matches what's on the download site.
8f535c235897303a5d55266858ffe9fe6c4d3e830f609c77c406f6e4aed0befa  devuan_ascii_2.0.0_i386_desktop-live.iso
#7 2018-11-04 22:31:24
icavot
OK. Thanks a lot.
