#1 2018-10-24 07:02:42
spartrekus
Soon a fix for SSHFS and FUSE broken in the Devuan Stable Unstable ?
Hello,
I would like to notice that SSHFS cannot be installed for Stable and ASCII. I tried Jessie too, but it has the same issue.
All mirrors are same: us, de, fr and sp tested.
Tested with i386, netinstall, and the CD1.
I would need sshfs and a fix for it.
I would be nice. Best regard,
Thank you!
#2 2018-10-24 13:58:31
Re: Soon a fix for SSHFS and FUSE broken in the Devuan Stable Unstable ?
What error message are you getting? I've never had a problem installing or using sshfs in debian or devuan.
#3 2018-10-24 16:05:06
spartrekus
package broken, with a possible risk of using unstable.
I use devuan since long. However, I never found such issue with sshfs but it is ... well it is a big issue for Package. sad
Sad but true
Devuan Stable is as well infected sad
#4 2018-10-24 16:48:02
yeti
$ sshfs yeti@sdf.org: ~/mnt ; ls -l ~/mnt ; fusermount -u ~/mnt
yeti@sdf.org's password:
total 12
lrwxr-x--- 1 24249 500 19 Aug 17  2015 gopher -> /ftp/pub/users/yeti
lrwx------ 1 24249 500 14 Jun 15 19:03 html -> /www/nz/y/yeti
-rw------- 1 24249 500 37 Aug 18  2015 xtermtitle
Tested using ASCII/armhf on Cubietruck.
I don't get it.
What is broken?
I installed sshfs just some seconds before this test.
Maybe I'm still too undercaffeinated...
#5 2018-10-24 19:28:19
Please post your sources.list and any repos enabled under sources.list.d.
Also, post the output of apt-get install sshfs and dpkg -l *ssh*
#6 2018-10-26 09:40:19
spartrekus
FIXED !!!
1) get devuan from a mirror :
08aef5aa1ba1b6db90aa2dd3c22e0415  devuan_ascii_2.0.0_i386_netinst.iso
2) bring the non-systemd debian on the pen:
dd if=devuan_ascii_2.0.0_i386_netinst.iso of=/dev/sdb
3) boot, press ESC and select install (non graphical mode):
  then regular, select EN language, ... and get the prompt wpa/wifi
  done,
  then select to  belgium: be: deb http://be.deb.devuan.org/merged ascii main non-free contrib
(same with us and germany)
4) delete the all harddisk with automatic fdisk/part stuffs
5) install the minimal installation
\[*\] lowest one for standard
  remove all x11 kde, gnome,... and remove print server with [ ].
6) done, grub installed, completed
7) reboot the i386 notebook and wait... tty login
8) root
    my pass
9) bring wifi/wpa and make a quick check with ip addr.
10) apt-get update
11) apt-get install sshfs
IT NOW WORKS !! FIXED (at least on be repository).
#7 2018-10-26 09:49:09
Did the error message tell you to run apt --fix-broken install? What happened when you did that? Were any other packages named? There must be more information in output.
#8 2018-10-26 10:03:08
spartrekus
I dont know so much what happened. I tried few days ago, and today, all went fine.
Maybe someone changed the Package.gz. I likely have a backup of it still, but I dont know where it still.
I made a mirror of the Packages of stable on a disk.
fixbroken is dangerous because it leaves error.
Usually, when it is a such a big issue, I move the machine to FreeBSD, it is much more stable (and without the systemd).
Man, debian goes to such amazing direction... sad
