#1 2018-09-26 11:44:36
weberjn
VirtualBox Guest Additions
I installed Devuan ASCII on current VirtualBox 5.2 (win 10 host), virtio network driver. All fine, but screen resolution only 1024x768.
So I tried to install VirtualBox Guest Additions. Build of the modules started, but never ended.
Has anybody got this to work?
Thanks,
Juergen
#2 2018-09-26 12:20:57
Re: VirtualBox Guest Additions
Works. Requires the headers for the kernel and the make utilities build-essentials.
Good luck, rolfie
#3 2018-09-27 17:18:15
weberjn
Thanks, build-essential was needed. Still, building the tools needed ages.
