#1 2018-09-15 14:41:41
makh
<Solved> [Ascii] Problem with AptCacherNg
Hi
I am unable to use in Devuan:
https://wiki.debian.org/AptCacherNg
... It worked fine in Debian.
I get in my client machine:
Could not resolve the 'myservername'
My configuration is:
1. Both machines are on the same network.
2. Both machines can ping to each other.
3. Both machines are guest OS, within virtualbox.
Thankyou
HP Probook 440 G2: Arch, Debian Stable
Others: Devuan, Centos, Ubuntu, Opensuse
GUI: Openbox, Xfce, Cinnamon
Chroot: Debian, Ubuntu, Fedora
#2 2018-09-15 16:23:26
Re: <Solved> [Ascii] Problem with AptCacherNg
First try:
ping -c 1 wiki.debian.org
on both systems. You should get something like:
$ ping -c 1 wiki.debian.org
PING wilder.debian.org (82.195.75.112) 56(84) bytes of data.
64 bytes from wilder.debian.org (82.195.75.112): icmp_seq=1 ttl=53 time=41.9 ms
--- wilder.debian.org ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 41.989/41.989/41.989/0.000 ms
Chris
#3 2018-09-15 18:12:11
makh
chris2be8 wrote:
First try:
Chris
Thats working!
#4 2018-09-15 22:48:06
makh
Hi
I got it working for now. But its a temporary fix:
I replaced the server-machine-name by its IP address: 192.168.AB.CDE
But my machine is basically behind the DHCP Router, so ... if address of server changes, then I have to manually edit the above values again.
I hope theres a solution to use the name instead of IP address!
Thankyou
#5 2018-09-16 08:28:08
neutron_stz
post contents of /etc/hostname and /etc/hosts
#6 2018-09-16 23:49:03
makh
Hi
Server Files:
1.
vmdevuanr1
2.
127.0.0.1	localhost
127.0.1.1	vmdevuanr1
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
Client Files:
1.
vmdevuanbeta
2.
127.0.0.1	localhost
127.0.1.1	vmdevuanbeta
Thankyou
#7 2018-09-18 12:38:58
makh
Hi
My other settings are:
Client Machine:
cat /etc/apt/apt.conf.d/proxy
#Acquire::http { Proxy "http://192.168.15.235:3142"; }
#Acquire::http { Proxy "http://vmdevuanr1:3142"; }
... It works with the static address only!
Output of apt update is by using:
apt update &> output.txt
Err:1 http://packages.devuan.org/merged ascii InRelease
  Could not resolve 'vmdevuanr1'
Err:2 http://auto.mirror.devuan.org/merged ascii-security InRelease
Err:3 http://auto.mirror.devuan.org/merged ascii-updates InRelease
Err:4 http://auto.mirror.devuan.org/merged ascii InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
W: Failed to fetch http://auto.mirror.devuan.org/merged/dists/ascii-security/InRelease  Could not resolve 'vmdevuanr1'
W: Failed to fetch http://auto.mirror.devuan.org/merged/dists/ascii-updates/InRelease  Could not resolve 'vmdevuanr1'
W: Failed to fetch http://auto.mirror.devuan.org/merged/dists/ascii/InRelease  Could not resolve 'vmdevuanr1'
W: Failed to fetch http://packages.devuan.org/merged/dists/ascii/InRelease  Could not resolve 'vmdevuanr1'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Thankyou
#8 2018-09-18 16:22:37
Try ping vmdevuanr1 and host vmdevuanr1 on the system you ran apt update on.
(The "Could not resolve 'vmdevuanr1'" message sounds as if it is the key problem.)
Chris
#9 2018-09-19 06:02:23
neutron_stz
add following line to clients /etc/hosts file:
192.168.15.235 vmdevuanr1
and try again with hostname instead of ip
#10 2018-09-22 07:35:12
makh
Chris
Hi
ping vmdevuanr1
ping: vmdevaunr1: Name or service not known
host vmdevuanr1
Host vmdevaunr1 not found: 3(NXDOMAIN)
@neutron_stz: Actually I want it to be not hardbinded, as I am using a dhcp server. As IP changes, then I have to re-edit again!
Thankyou
#11 2018-09-22 09:15:19
Presumably, as implied by your initial note "... It worked fine in Debian.", you are also running a DHCP/DNS service combination, such that the DHCP server upon serving an IP for vmdevuanr1 registers that host name appropriately with the DNS service, so that other hosts should be able to resolve it? Which DHCP/DNS service combination are you using?
#12 2018-09-22 10:41:46
makh
Hi
It is a simple internet DHCP router. I am using it in default, no such special configurations!
Actually I tested this all system, and had no issue in Debian. So I went on to test on Devuan.
I also tested one more configuration: use apt-chacher-ng for the server access to the media. Strangely, for server itself, it works, for both Debian and Devuan! But for devuan client to server fails. sad
Thankyou
#13 2018-09-22 16:07:43
To make it work the client needs to know what IP address vmdevuanr1 has. The server will know it's own IP address, probably as 127.0.0.1, so it will work there. The client needs to either have it edited into /etc/hosts when necessary (tedious manual work) or to be able to look it up in DNS.
What does /etc/resolv.conf contain? Mine contains:
nameserver 192.168.1.1
Which tells the system to ask my internet router (at 192.168.1.1) to resolve IP addresses. Try using your router as a DNS server as well as DHCP server. If it's already your DNS server look at it's admin screens to see if there's an option for it to resolve addresses it's handed out by DHCP. Or you may need to add a suffix to vmdevuanr1 in /etc/apt/apt.conf.d/proxy
Chris
#14 2018-09-22 16:51:23
makh
Chris
Hi
1. Both my client and server contain:
2. But under the same configuration; the debian server is giving the service: do I need to probe into the Router?
My Router has only two fields in DNS tab:
Enable DDNS     (Default disable)
DDNS Service Provider     (dyndns.org)
I dont know much about Networking; but nothing else seems to have DNS settings etc!
3. If you are running the same service via apt-cacher-ng; does it works for your client machines?
4. The ping and host commands work for both my debian machines!
Thankyou
#15 2018-09-23 14:09:36
makh
Adding to above:
5. From the same machine ie vmdevuanr1:
ping -c2 vmdevuanr1
... Works
host vmdevuanr1
... Fails
#16 2018-09-23 14:21:13
makh
Adding:
6. Theres also another difference in the two configurations, as I can explore:
a. In Debian I have by default installed: network-manager
b. In Devuan I have by default installed: wicd
Thankyou
#17 2018-09-23 14:36:39
makh
Solved, at last:
On Devuan Apt-cache-ng Sever:
apt install network-manager-gnome
apt remove wicd
apt autoremove
All is well that ends well... smile
Thankyou all for your kind input!
#18 2018-09-23 16:02:03
The way I would have done it it to make all systems that act as servers have a fixed IP address. Then systems connecting to them can use that IP address (preferably an entry in /etc/hosts).
First check what range of addresses your DHCP server can hand out (eg 192.168.1.2 to 192.168.1.200). Then give the server an IP address that's not in that range. You get problems if two systems try to use the same IP address.
Or configure the DHCP server to give the relevant system a fixed IP address.
You may not need this advice now, but someone else might find it useful.
Chris
#19 2018-09-23 17:31:50
makh
Chris
Hi
Thanks
But I believe there was some defect in wicd!
