#1 2018-08-30 22:06:47
EpicCrackhead
What are the necessary packages for audio to work correctly?
Hi, i'm installing a minimal devuan ascii install and i got everything to work except for audio
sudo apt-get pulseaudio (and the other packages that came with it) just didn't cut it, can't hear anything, am i missing some packages?
#2 2018-08-31 00:47:59
dxrobertson
Re: What are the necessary packages for audio to work correctly?
I have 1 PC that is troublesome in that the headphones and speakers are inverted; no sound unless I plug in headphones.  A long shot but plug in headphone and try sound.
Next I would try opening a terminal and use (enter) "alsamixer".  If pulseaudio is installed, hit F6 to select a sound card; down arrow off of "default" and select the "real" sound card.  Then play around with the volume levels.  right/left arrow to select, up/down arrow to adjust.  MM means mute, hit key "M" unmute.
A good test website for audio (atleast from the browser perspective) is http://hpr.dogphilosophy.net/test/.
What to install? My installs are minimal, but installation with non-free didnt have any sound problems; so not sure what you need as far as packages.  I have noticed that various media applications require a varied install of different codec packages.
#3 2018-08-31 13:25:17
catprints
I find that removing pulseaudio usually fixes my sound issues. Just my experience. If you need it-different story.
"The obstacle is the path."
#4 2018-09-01 11:47:07
EpicCrackhead
Yeah i fixed it, just reinstalled the distro with XFCE, did apt-get cache search alsa, then apt-get cache search pulse, then copied all the package names ad installed them in my minimal install, AND IT WORKED, HAH.
#5 2018-09-01 23:30:33
ivanovnegro
A default Devuan install usually gives you all you need nowadays.
Of course if you make a very minimal install you always could forget some important package.
#6 2018-09-04 16:35:36
Ogis1975
No need any pulse audio. Just install
alsa-utils
alsamixergui
and
libalsaplayer0
If you have multiple sound cards, just create
 .asoundrc
  file with content
pcm.!default {
    type hw
    card Headset
ctl.!default {
    type hw
    card Headset
Where "Headset" is my default sound card. And here you go. Now you have a working sound. Good luck.
