#1 2018-08-23 09:08:19
minghia
Serial port on Raspberry Pi using Devuan
We are trying to use the serial port on a Raspberry Pi 3B running Devuan and we can't seem to anything through what we think is the serial port on pins 8 & 10 on the header. Does anyone have any experience getting the serial port to work on a Raspberry Pi using Devuan?
Note I have enable-uart=1 in my /boot/config.txt and I have also disabled the WiFi and the Bluetooth.
Tony
#2 2018-09-04 03:30:45
minghia
Re: Serial port on Raspberry Pi using Devuan
Solved it when I realised that by disabling the bluetooth and wifi and enabling the UART, the kernel creates /dev/ttyS0. I was trying to use /dev/ttyAMA0 which gets switched to the second UART after the enabling and disabling.
#3 2018-09-04 16:40:54
Devuoted
Would you find the time to post details from your config.txt and cmdline.txt to show how you made this work?
Whenever I add 'enable_uart=1' to config.txt I get a kernel panic on boot.
Devuoted
#4 2018-09-05 02:39:52
minghia
## memory shared with the GPU
gpu_mem=128
## always audio
#dtparam=audio=on
## maximum amps on usb ports
max_usb_current=1
## enable hardware-accelerated graphics
dtoverlay=vc4-kms-v3d
#dtparms=i2c2_iknowwhatimdoing
dtoverlay=pi3-disable-bt
dtoverlay=pi3-disable-wif
enable_uart=1
## kernel
kernel=kernel8.img
My cmdLine.txt is netbooting so I don't know if that is of help. But I can give to you with the IP address removed:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/nfs rootfstype=nfs nfsroot=XX.XX.XX.XX:/root elevator=deadline fsck.repair=yes rootwait ip=dhcp plymouth.ignore-serial-consoles
It maybe the plymouth.ignore-serial-consoles that does it.
#5 2018-09-12 18:19:34
Devuoted
Thanks a lot for sharing your information.
I got it to boot as it should with help of your example.
In /boot/config.txt I added the directives:
core_freq=250
enable_uart=1
In /boot/cmdline.txt I removed
console=ttyAMA0,115200 kgdboc=ttyAMA0,115200
and I added
Furthermore, in /etc/inittab I removed (commented out) the line:
T0:23:respawn:/sbin/agetty -L ttyAMA0 115200 vt100
The computer now boots as expected. Next step is to move it to an Internet-depraved site and see if I can get it to communicate with the 3D-printer there. :-)
Thanks for your help.
#6 2018-09-16 19:07:36
Devuoted
So, just to follow up on my own post.
The serial port is now available and functional. I have contact with the 3D-printer in question through OctoPrint.
Thanks again.
