#1 2018-08-16 18:49:26
lvdave
Owncloud Client on Devuan Ascii - Missing libraries
When trying to install the Owncloud client for Debian 9 (https://download.opensuse.org/repositor … _amd64.deb), I get the following output from dpkg...
Preparing to unpack owncloud-client_2.4.3+oc-10035_amd64.deb ...
Unpacking owncloud-client:amd64 (2.4.3+oc-10035) ...
dpkg: dependency problems prevent configuration of owncloud-client:amd64:
 owncloud-client:amd64 depends on libowncloudsync0 (= 2.4.3+oc-10035); however:
  Package libowncloudsync0 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5concurrent5; however:
  Package ocqt562+240-libqt5concurrent5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5core5a; however:
  Package ocqt562+240-libqt5core5a is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5dbus5; however:
  Package ocqt562+240-libqt5dbus5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5gui5; however:
  Package ocqt562+240-libqt5gui5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5keychain1; however:
  Package ocqt562+240-libqt5keychain1 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5network5; however:
  Package ocqt562+240-libqt5network5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5sql5; however:
  Package ocqt562+240-libqt5sql5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5webkit5; however:
  Package ocqt562+240-libqt5webkit5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5widgets5; however:
  Package ocqt562+240-libqt5widgets5 is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5xml5; however:
  Package ocqt562+240-libqt5xml5 is not installed.
 owncloud-client:amd64 depends on owncloud-client-l10n; however:
  Package owncloud-client-l10n is not installed.
 owncloud-client:amd64 depends on ocqt562+240-libqt5sql5-sqlite; however:
  Package ocqt562+240-libqt5sql5-sqlite is not installed.
dpkg: error processing package owncloud-client:amd64 (--install):
I was under the impression that Devuan/Ascii WAS Debian/9/Stretch MINUS systemd. I've installed this client on an actual Debian 9 system and it
installs perfectly... These appear to be qt5-related libs, which is kinda weird, as I chose the KDE/Plasma5 DE choice when installing Devuan. These
libs *should* already be there. After these errors, if I do an "apt-get -f install", which generally fixes dpkg dependancy problems, it offers to remove "owncloud-client"....
Help!
#2 2018-08-16 21:01:34
ivanovnegro
Re: Owncloud Client on Devuan Ascii - Missing libraries
You can find the client in the Devuan repos. From backports even a slightly newer version than in stable.
apt policy owncloud-client
owncloud-client:
  Installiert:           (keine)
  Installationskandidat: 2.2.4+dfsg-2
  Versionstabelle:
     2.4.1+dfsg-1~bpo9+1 100
        100 http://de.deb.devuan.org/merged ascii-backports/main amd64 Packages
     2.2.4+dfsg-2 500
        500 http://de.deb.devuan.org/merged ascii/main amd64 Packages
#3 2018-08-17 16:02:54
lvdave
Thanks.. Other than having to translate the german words, this worked... Thanks again..
