#1 2018-08-03 11:15:12
mutluit
chrooted minimal install via debootstrap under Debian (or in LXC)
Looking for an HOWTO on installing a minimal devuan 2 (ascii) (w/o GUI) in a chrooted subdirectory via debootstrap under Debian 8 (jessie), or newer.
Alternatively, installing in an LXC container under Debian.
As said, w/o GUI desktop.
Rationale: I've all old releases of Debian beginning with 3.0 (woody) installed in chrooted subdirectories, can start them in parallel and use their apt-get install etc.
Would also like to install Devuan alike.
Anyone have experience with these installation method(s) with Devuan under Debian?
#2 2018-08-03 14:50:15
mutluit
Re: chrooted minimal install via debootstrap under Debian (or in LXC)
Ok, I've been successful installing Devuan 2 (ascii) under Debian into a dir with the following conf file to be used by the tool "multistrap" (s. Debian repo).
It reports a keyring error, but noauth=true ignores the error and continues installing. The installed dir looks like this:
# ls -l ascii-i386/
total 56
drwxr-xr-x  2 root root 4096 May  4 12:23 bin
drwxr-xr-x  2 root root 4096 Jun 10 13:21 boot
drwxr-xr-x  2 root root 4096 Jun 10 13:21 dev
drwxr-xr-x 31 root root 4096 May  4 12:23 etc
drwxr-xr-x  2 root root 4096 Jun 10 13:21 home
drwxr-xr-x  8 root root 4096 Jan 29  2017 lib
lrwxrwxrwx  1 root root    5 Aug  3 16:37 lib64 -> ./lib
drwxr-xr-x  2 root root 4096 Jun 10 13:21 proc
drwx------  2 root root 4096 Jun 10 13:21 root
drwxr-xr-x  2 root root 4096 Jun 15  2017 run
drwxr-xr-x  2 root root 4096 Aug  3 16:38 sbin
drwxr-xr-x  2 root root 4096 Jun 15  2017 sys
drwxrwxrwt  2 root root 4096 Aug  3 16:38 tmp
drwxr-xr-x  9 root root 4096 Jan 29  2017 usr
drwxr-xr-x 11 root root 4096 Jun  7  2017 var
I haven't started the OS yet, as one needs to make some more steps for starting it in a chrooted environment. Will post a follow-up soon...
# file: my_multistrap.conf
# run:
#   multistrap -d /sw/pkg/debootstrap_devuan/ascii-i386 -f my_multistrap.conf
[General]
arch=i386
# same as --tidy-up option if set to true
cleanup=true
# same as --no-auth option if set to true; keyring packages listed in each bootstrap will still be installed.
noauth=true
# extract all downloaded archives (default is true)
unpack=true
# whether to add the /suite to be explicit about where apt needs to look for packages. Default is false.
explicitsuite=false
# enable MultiArch for the specified architectures; default is empty
multiarch=
# aptsources is a list of sections to be used
# the /etc/apt/sources.list.d/multistrap.sources.list
# of the target. Order is not important
aptsources=Debian
# the bootstrap option determines which repository
# is used to calculate the list of Priority: required packages
# and which packages go into the rootfs.
# The order of sections is not important.
bootstrap=Debian
[Debian]
packages=
source=http://deb.devuan.org/merged
#keyring=devuan-devs.gpg
suite=ascii
