#1 2018-07-19 00:39:39
Ron
[SOLVED] About mate-tweak configuration tool
Can anyone tell me if the mate-tweak configuration tool gives Mate more functionality, or just the same functionality in one convenient place?
#2 2018-07-19 15:40:26
ivanovnegro
Re: [SOLVED] About mate-tweak configuration tool
Ron wrote:
...or just the same functionality in one convenient place?
Sounds more like it and I have it installed. There is nothing you cannot do from the command line or from dconf. The only thing it has and I do not use it, is to save panel layouts.
#3 2018-07-19 21:11:11
Ron
Well, that's what I figured. Thanks.
