#1 2018-06-27 09:29:22
david
I can not install the new Devuan(2)
     Installation of Devuan 2 is totally others than Devuan 1. I can not find a installation guide or video or pictures.
Please help me.
#2 2018-06-27 09:49:03
devuser
Re: I can not install the new Devuan(2)
How are you installing? The installer on the non-live CDs should be virtually identical for Jessie and Ascii.
#3 2018-06-27 10:10:30
Panopticon
As devuser says, should be the same as Jessie unless you are choosing the expert setup which i think has a few differences.
This may help here: https://friendsofdevuan.org/doku.php/co … 1.0_jessie
Bit more info might help here david.
#4 2018-06-27 12:24:50
david
It look a likes refracta installer
#5 2018-06-27 12:30:47
Start the installer and select Help or else read /usr/share/doc/refractainstaller-base/readme.refractainstaller.txt (same thing).
#6 2018-06-28 00:04:53
Caluser2000
David just follow the instructions given by the installation routine. Its fairly a fairly straight forward process and you should be up and running in 20 minutes or so.
