#1 2018-06-10 03:09:18
Ron
[SOLVED] Something is shutting off signal to monitor after 10 minutes
I'm running Miyo with Mate desktop. I have the Mate screensaver to kick in after 5 minutes of inactivity. But then after another 5 minutes (10 minutes total), the computer shuts off the signal to the monitor. I don't think this is something in Mate doing this, as I think this is a function of a power manager, and Mate's power manager is dependent on systemd so it's not installed. I've deleted everything Openbox and LXDE so it can't be something from them doing this. I still have a few Xfce things: libexo-1-0, libxfce4ui-1-0, libxfce4ui-common, libxfce4util-common, libxfce4util7, libxfconf-0-2, and xfconf. Could it be one of these things that's shutting off the signal to the monitor? Or something else? I'd like to either edit it to a longer time, or to never shut off the monitor's signal. Thanks for any input on this.
BTW, is it safe to delete the Xfce remnants left on my system?
#2 2018-06-10 04:20:01
MiyoLinux
Re: [SOLVED] Something is shutting off signal to monitor after 10 minutes
Hi Ron! I'm guessing that you don't have the xfce4-power-manager installed?
Sounds like xset is what is causing the situation. Let's try this first...open your terminal and enter...
xset dpms 0 0 0
...then see if the screen turns off after 10 minutes of no activity.
#3 2018-06-10 17:46:50
Ron
Thanks, that worked. So how do I go about editing this? Or will what I ran in the terminal stick after a reboot?
#4 2018-06-11 00:57:56
MiyoLinux
Hi Ron...sorry for the late reply. Our family has been out of town all day.
Anyway...let's see if this works...
If I remember correctly, you changed to LightDM instead of Slim. Open your terminal, and enter the following command...substitute leafpad with your text editor...
sudo leafpad /etc/lightdm/lightdm.conf
When the file opens, scroll down until you find the line [Seat Defaults]
After finding that line, look for the line #xserver-command=X
Remove the # from in front of the line, and change the line to read xserver-command=X -s 0 dpms
Save and close the file. Reboot for it to take effect...hopefully take effect.
Hope that helps!
#5 2018-06-11 01:45:21
Ron
I did, but when I reinstalled Miyo I kept Slim. So how do I change it with Slim?
#6 2018-06-11 02:44:25
MiyoLinux
Okay. It works basically the same with slim. Give me a few minutes...had to go to a store for a few items. Sorry. I'll be back soon. While I was at it, I stinkin' should've given directions for slim too... tongue LOLOLOL!
#7 2018-06-11 03:07:21
MiyoLinux
Okay...
This is actually my preferred way of stopping the monitor from turning off...don't need a power manager using resources to do the same thing. tongue
Open your terminal, and issue this command (substitute leafpad with your text editor)...
sudo leafpad /etc/slim.conf
When the file opens, the line you want to edit is close to the top. It looks like this...
xserver_arguments   -nolisten tcp
Edit that line so that it now looks like this...
xserver_arguments   -s 0 dpms -nolisten tcp
Save and close the file. Then Reboot...it might work with just a log out/log in, but I'm not sure.
Hope that helps!
#8 2018-06-11 04:27:32
Ron
Thanks, that seemed to work. smile
If later I want to change it to a longer time for the signal to be shut off (instead of not at all), how would I do that? Everything in the line you had me edit is puzzling to me. hmm
#9 2018-06-11 16:49:10
MiyoLinux
Sure thing!
If you want it to turn off, just change the 0 (zero) to the number of MINUTES that you want to transpire before turning off the monitor. Such as, if I want it to turn off after 2 hours of inactivity, I would convert that to minutes in the command (2 x 60 = 120)...which would be...
xserver_arguments   -s 120 dpms -nolisten tcp
#10 2018-06-11 17:24:08
Ron
Thanks MiyoLinux. Marking this thread as solved.
Out of curiosity, what does "dpms" stand for?
#11 2018-06-11 17:42:36
MiyoLinux
Sure thing! smile
dpms = Display Power Management Signaling
It's basically a "built-in" energy saver for X.
#12 2018-06-11 23:49:22
MiyoLinux
Ron, I apologize for not addressing this earlier...got all wrapped up in the monitor situation. tongue
Yes, to my knowledge, it should be safe to delete those items. You have a list of them, so keep that list until after you delete them...just in case something goes all whack-a-doodle on you...you'll know what you deleted and can reinstall them. Since you're using Mate, I see no reason to keep them...but I'm not proficient in Mate-ism. wink
smile
