Pages: 1
I have an application that's been developed when 64bit processors were unknown. Although in theory it should work as a 64bit app I rather not spend the time doing regression tests, so I drag it from system to system compiling it as a 32bit app.
After setting up and installing the multilib environment according to debian howtos (dpkg --add-architecture i386, apt-get install gcc-multilib) I get link errors for libraries that reside in in /usr/lib/i386-linux-gnu due to missing symlinks (libs in /lib/i386-linux-gnu are fine).
To use libpng and libfreetype after installing both I had to manually create the links marked "Fixed" below.
Fixed lrwxrwxrwx 1 root root 21 May 5 09:12 libfreetype.so -> libfreetype.so.6.12.3
lrwxrwxrwx 1 root root 21 Apr 27 2017 libfreetype.so.6 -> libfreetype.so.6.12.3
-rw-r--r-- 1 root root 731472 Apr 27 2017 libfreetype.so.6.12.3
Fixed lrwxrwxrwx 1 root root 11 May 5 09:11 libpng.so -> libpng16.so
Fixed lrwxrwxrwx 1 root root 19 May 5 09:10 libpng16.so -> libpng16.so.16.28.0
lrwxrwxrwx 1 root root 19 Jan 9 2017 libpng16.so.16 -> libpng16.so.16.28.0
-rw-r--r-- 1 root root 230708 Jan 9 2017 libpng16.so.16.28.0Apart from that I'm immensely pleased with the way devuan comes along.
Pages: 1
