#1 2018-05-27 01:03:02
siva
A journey thorugh ASCII
Sup everyone,
I upgraded my devuan build host to ASCII today and wanted to document my experience for archaeologists who study our culture thousands of years from now.
-Upgrade took about 35 mins, give or take.  I'm excluding the time it took to run to the grocery store and back.  I don't use the default devuan desktop, only a simple dwm session, so I don't see a lot of the changes that other users might have.  I did notice that suckless-tools changed their default font sizes; dmenu is thicc.
-There were a surprising amount of packages to be autoremoved.  I think that was related to the next issue: that X wouldn't boot, which was weird, but it did after the second reboot, which was also weird.
-I used the dist-upgrade command out of Debian habits, and I wonder if this is the culprit of my woes, because it installed dbus and slim; shame on me for not reading through the 800+ upgraded packages.  Also in this episode: dbus and slim are now pinned to never download.
-It's using about 10-15mb more ram than jessie and I'm not really sure why.  This isn't an unreasonable amount, but it is noticeable.  Did anyone else experience this after they upgraded?
-Talks back.  The artificial intelligence that's built into ASCII's kernel makes some very sarcastic and inappropriate comments.  I had to mute my computer while company was over.
Other than that, it works just as fine as jessie, and I mean that as a compliment because I prefer stability.  Enjoy this screenshot.
#2 2018-05-27 15:58:38
Re: A journey thorugh ASCII
You must use dist-upgrade or the equivalent (aptitude full-upgrade) to get to the next release. Warning: pinning ain't what it used to be. Stuff that's blocked on install is not necessarily (or maybe not at all) blocked on dist-upgrade. I've seen libsystemd0 come in like that on upgrading from jessie to ascii.
Yes, I experienced this on upgrades from lenny to squeeze to wheezy to jessie to ascii. I don't recall what happened from sarge to etch to lenny, but I'll bet it was similar.
#3 2018-05-27 18:58:35
siva
Do you know if there's a better way to prevent them from showing up?
Makes sense.  It isn't my primary system, so I'm not upset, but it is a little weird.
#4 2018-05-28 15:29:59
I don't know a way around that problem. Debian "fixed" pinning last year, and some things that used to work no longer do.
