#1 2018-05-11 09:58:08
opknow
no wifi working
Hi guys, after installation I've got no wifi working.
When I start wicd it doesn't see wifi around the pc. Can you help me to figure it out how to solve this problem?
#2 2018-05-11 12:14:56
siva
Re: no wifi working
If you're using wicd, make sure your wifi interface is the same wireless interface in its settings.
You can list your network devices with ifconfig -a as root.
You can find your network card with lspci -vv | grep -i Network as root.  For some devices, you may need proprietary/nonfree software.
the thomos project
thomos support thread
cynwulf wrote: "You should get some more sleep and spend less time on forums."
#3 2018-05-11 12:18:01
Panopticon
Re: no wifi working
what does...
iwconfig
show
#4 2018-05-13 11:46:22
14158
Re: no wifi working
I had this issue, as advised check what the interfaces are named with sudo ifconfig -a.  Then update the Wicd preferences accordingly. smile
Not sure if I should log this as a bug?
#5 2018-05-15 21:51:07
opknow
Re: no wifi working
Hi there. Thank you for your answer. Here all the informations you asked me.
with root user
# ifconfig -a
wlan0     Link encap:Ethernet  HWaddr 74:de:2b:07:a9:be
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
# lspci -vv | grep -i Network
02:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
# iwconfig
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
What do you suggest???
#6 2018-05-16 02:13:07
0xf4b10
Re: no wifi working
I have neither ifconfig nor iwconfig installed in my system. What package should I install to add them?
#7 2018-05-16 11:36:21
Panopticon
Re: no wifi working
with root user
# ifconfig -a
# iwconfig
          Encryption key:off
Have a look at this link, may help you to manage your wifi from the command line.
https://www.blackmoreops.com/2014/09/18 … -in-linux/
#8 2018-05-16 11:53:24
Panopticon
Re: no wifi working
You need the iw package and net-tools i think.
