#1 2018-03-27 18:00:05
[Solved] Thunderbird and language packs
Looks like Thunderbird ist up to date with version 52.6.0-1, while the language packs are lower and won't install with dependency errors.
Is that a bug report or is there another solution?
Thanks, rolfie
#2 2018-03-27 20:54:33
Re: [Solved] Thunderbird and language packs
If you're using pkgmaster.devuan.org in your sources.list, try installing from jessie-security:
apt-get -t jessie-security install thunderbird-l10n-xx
If you're using auto.mirror.devuan.org or packages.devuan.org, wait until tomorrow (or start using pkgmaster).
     1:52.6.0-1~deb8u1 0
        500 http://pkgmaster.devuan.org/merged/ jessie-security/main amd64 Packages
     1:45.8.0-3~deb8u1 0
        500 http://pkgmaster.devuan.org/merged/ jessie/main amd64 Packages
        500 http://auto.mirror.devuan.org/merged/ jessie/main amd64 Packages
        500 http://auto.mirror.devuan.org/merged/ jessie-security/main amd64 Packages
        500 http://debian.csail.mit.edu/debian/ jessie/main amd64 Packages
#3 2018-03-28 16:57:59
Sorry, forgot to mention: I am on ASCII, and use auto.mirror.devuan.org.
Will wait until tomorrow or so.
Thanks, rolfie
#4 2018-03-29 11:36:49
There's some problem with jessie-security on the old amprolla. I don't know the details, but it's not a new problem. Change sources from auto.mirror.devuan.org to pkgmaster.devuan.org.
Another odd thing is that there are two versions in ascii/stretch security. I don't know if you'll need to specifiy the version you want, or if you'll just get the later version. To specify the version,
apt-get install thunderbird-l10n-xx=1:52.7.0-1~deb9u1
Replace xx with your country code.
#5 2018-03-29 16:44:11
The hint to switch to pkgmaster did the job. TB is up from 52.6 to 52.7, and the language packs fit.
Thanks, rolfie
