#1 2018-03-24 20:18:42
[Solved] eudev issues during upgrade to ASCII
Fresh Jessie console mode only install, upgrading to ASCII (different PC)
Have eudev 3.2.2-12 received during dist-upgrade, got error messages like:
- insserv rejected the script header
- service udev is already installed
Fails to update the initramfs, issues with initramfs-tools etc.
What is wrong, what can I do?
apt install eudev
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
eudev ist schon die neueste Version (3.2.2-12).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
6 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
Möchten Sie fortfahren? [J/n]
eudev (3.2.2-12) wird eingerichtet ...
calling: test
version 3.2.2
=== trie on-disk ===
tool version:          3
file size:         7195445 bytes
header size             80 bytes
strings            1846053 bytes
nodes              5349312 bytes
Load module index
timestamp of '/etc/udev/rules.d' changed
timestamp of '/lib/udev/rules.d' changed
Reading rules file: /lib/udev/rules.d/50-firmware.rules
Reading rules file: /lib/udev/rules.d/50-udev-default.rules
Reading rules file: /lib/udev/rules.d/55-dm.rules
Reading rules file: /lib/udev/rules.d/56-lvm.rules
Reading rules file: /lib/udev/rules.d/60-block.rules
Reading rules file: /lib/udev/rules.d/60-cdrom_id.rules
Reading rules file: /lib/udev/rules.d/60-drm.rules
Reading rules file: /lib/udev/rules.d/60-evdev.rules
Reading rules file: /lib/udev/rules.d/60-persistent-alsa.rules
Reading rules file: /lib/udev/rules.d/60-persistent-input.rules
Reading rules file: /lib/udev/rules.d/60-persistent-storage-dm.rules
Reading rules file: /lib/udev/rules.d/60-persistent-storage-tape.rules
Reading rules file: /lib/udev/rules.d/60-persistent-storage.rules
Reading rules file: /lib/udev/rules.d/60-persistent-v4l.rules
Reading rules file: /lib/udev/rules.d/60-sensor.rules
Reading rules file: /lib/udev/rules.d/60-serial.rules
Reading rules file: /lib/udev/rules.d/64-btrfs.rules
Reading rules file: /lib/udev/rules.d/69-lvm-metad.rules
Reading rules file: /lib/udev/rules.d/70-mouse.rules
Reading rules file: /etc/udev/rules.d/70-persistent-net.rules
Reading rules file: /lib/udev/rules.d/70-touchpad.rules
Reading rules file: /lib/udev/rules.d/73-idrac.rules
Reading rules file: /lib/udev/rules.d/73-special-net-names.rules
Reading rules file: /lib/udev/rules.d/73-usb-net-by-mac.rules
Reading rules file: /lib/udev/rules.d/75-net-description.rules
Reading rules file: /lib/udev/rules.d/75-persistent-net-generator.rules
Reading rules file: /lib/udev/rules.d/75-probe_mtd.rules
Reading rules file: /lib/udev/rules.d/78-sound-card.rules
Reading rules file: /lib/udev/rules.d/80-drivers.rules
Reading rules file: /lib/udev/rules.d/80-ifupdown.rules
Reading rules file: /lib/udev/rules.d/80-net-name-slot.rules
Reading rules file: /lib/udev/rules.d/80-networking.rules
Reading rules file: /lib/udev/rules.d/85-hwclock.rules
Reading rules file: /lib/udev/rules.d/90-console-setup.rules
rules contain 24576 bytes tokens (2048 * 12 bytes), 11178 bytes strings
1544 strings (20185 bytes), 977 de-duplicated (9575 bytes), 568 trie nodes used
NAME 'eth0' /etc/udev/rules.d/70-persistent-net.rules:8
IMPORT builtin 'net_id' /lib/udev/rules.d/75-net-description.rules:6
IMPORT builtin 'hwdb' /lib/udev/rules.d/75-net-description.rules:12
RUN 'ifupdown-hotplug' /lib/udev/rules.d/80-ifupdown.rules:5
RUN 'net.agent' /lib/udev/rules.d/80-networking.rules:1
created db file '/run/udev/data/n2' for '/devices/pci0000:00/0000:00:04.0/0000:02:00.0/net/eth0'
Unload module index
calling: test
version 3.2.2
tool version:          3
nodes              5349312 bytes
Load module index
created empty file '/run/udev/data/n1' for '/devices/virtual/net/lo'
Unload module index
[....] Stopping enhanced syslogd: rsyslogd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting enhanced syslogd: rsyslogd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
insserv: script eudev: service udev already provided!
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
Fehler beim Bearbeiten des Paketes eudev (--configure):
 Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zurück
Abhängigkeitsprobleme verhindern Konfiguration von udev:
 udev hängt ab von eudev; aber:
  Paket eudev ist noch nicht konfiguriert.
Fehler beim Bearbeiten des Paketes udev (--configure):
 Abhängigkeitsprobleme - verbleibt unkonfiguriert
Abhängigkeitsprobleme verhindern Konfiguration von initramfs-tools-core:
 initramfs-tools-core hängt ab von udev; aber:
  Paket udev ist noch nicht konfiguriert.
  Paket eudev, das udev bereitstellt, ist noch nicht konfiguriert.
Fehler beim Bearbeiten des Paketes initramfs-tools-core (--configure):
Abhängigkeitsprobleme verhindern Konfiguration von initramfs-tools:
 initramfs-tools hängt ab von initramfs-tools-core (= 0.130); aber:
  Paket initramfs-tools-core ist noch nicht konfiguriert.
Fehler beim Bearbeiten des Paketes initramfs-tools (--configure):
 Abhängigkeitsprobleme verhindern Konfiguration von linux-image-4.9.0-6-amd64:
 linux-image-4.9.0-6-amd64 hängt ab von initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; aber:
  Paket initramfs-tools ist noch nicht konfiguriert.
  Paket linux-initramfs-tool ist nicht installiert.
  Paket initramfs-tools, das linux-initramfs-tool bereitstellt, ist noch nicht konfiguriert.
Fehler beim Bearbeiten des Paketes linux-image-4.9.0-6-amd64 (--configure):
Abhängigkeitsprobleme verhindern Konfiguration von linux-image-amd64:
 linux-image-amd64 hängt ab von linux-image-4.9.0-6-amd64; aber:
  Paket linux-image-4.9.0-6-amd64 ist noch nicht konfiguriert.
Fehler beim Bearbeiten des Paketes linux-image-amd64 (--configure):
Fehler traten auf beim Bearbeiten von:
 eudev
 udev
 initramfs-tools
 linux-image-amd64
Sub-process /usr/bin/dpkg returned an error code (1)
Tried apt install eudev -f, autoremoved old stuff, apt update, dpkg --configure -a, no help so far.
Thanks, rolfie
#2 2018-03-25 03:52:12
nixer
Re: [Solved] eudev issues during upgrade to ASCII
Try as root user,
rm /etc/init.d/udev
and then,
apt-get dist-upgrade
You may get a notice about apt "wanting to do more" but I just disregarded that.  I updated a few installs in this manner.
#3 2018-03-25 13:21:03
Thanks, that did the job. Upgrade to ASCII finished successfully.
#4 2018-04-03 05:50:35
psb777
Thanks! Same problem solved.
