#1 2018-03-04 07:52:07
rfgmm
Policykit Network-Manager-Applet Issue
if you are using this kind fo abomination ----> network-manager-applet/nm-applet from debian not devuan packages combined with Slim..
Today, last update of Policykit, Network-Manager-Applet started to missbehave, saying  you are not allowed to change or join a network the solution is this :
you need to create a file
filename:
org.freedesktop.NetworkManager.pkla
with this inside
[nm-applet]
Identity=unix-group:netdev
Action=org.freedesktop.NetworkManager.*
ResultAny=yes
ResultInactive=no
ResultActive=yes
in this folder
/etc/polkit-1/localauthority/50-local.d
The same error started to show up with removable drives, I will look  for a solution then.
