#1 2016-12-12 04:34:40
vdev and pulse
This is an advisory note if you happen to use pulseaudio and want to trial vdev.
The issue is that pulseaudio has a builtin dependency on udev via its module  module-udev-detect.so (e.g. /usr/lib/pulse-7.1/modules/module-udev-detect.so), and the associated stanza in /etc/pulse/default.pa, perhaps at lines 53-60:
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
You should thus rename or remove module-udev-detect.so, or make the stanza be just:
Either way should be enough to keep sound working.
#2 2017-11-20 05:47:45
fungus
Re: vdev and pulse
Interesting note on pulseaudio from debian
pulseaudio (11.1-2) unstable; urgency=medium
  * Since this version, pulseaudio disables autospawn by default on linux
    systems, and replaces that with systemd socket activation. If you are not
    using systemd, then please edit or remove
    /etc/pulse/client.conf.d/00-disable-autospawn.conf
    to reenable it.
-- Felipe Sateler <fsateler@debian.org>  Fri, 17 Nov 2017 20:13:57 -0300
#3 2017-11-20 09:55:40
nixer
Re: vdev and pulse
If you are not using systemd, then please edit or remove
    to reenable it.
In ceres (ascii and jessie too?), I am using the Pulse Audio Volume Control to control volume within the xfce panel.  This broke after a recent update and I had to follow the directive above to get it working again.
