Pages: 1
Printer: Brother DCP-L3510CDW
$ neofetch
..,,;;;::;,.. alexk@ng3
`':ddd;:,. ---------
`'dPPd:,. OS: Devuan GNU/Linux 6 (excalibur) x86_64
`:b$$b`. Model: 90BJ008CUK Lenovo H30-05
'P$$$d` Kernel: 6.12.111+deb13-amd64
.$$$$$` Uptime: 29 mins
;$$$$$P Packages: 3419 (dpkg)
.:P$$$$$$` Shell: bash 5.2.37
.,:b$$$$$$$;' Resolution: 1920x1080
.,:dP$$$$$$$$b:' DE: Xfce 4.20
.,:;db$$$$$$$$$$Pd'` WM: Xfwm4
,db$$$$$$$$$$$$$$b:'` WM Theme: Default
:$$$$$$$$$$$$b:'` Theme: Clearlooks-Phenix-Sapphire [GTK2/3]
`$$$$$bd:''` Icons: oxygen [GTK2/3]
`'''` Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: AMD A8-7410 APU with AMD Radeon R5 Grap
GPU: AMD ATI Radeon R4/R5 Graphics
Memory: 1338MiB / 7362MiBThe printer is a LCD colour laser printer/scanner/copier that uses toner cartridges. It was bought via Amazon on 1 July 2019 & has worked flawlessly under Devuan using standard CUPS drivers ever since.
Very recently it reported "Toner Low for Y + M (yellow + magenta catridges; there are 4: CYMK [Cyan | Yellow | Magenta | Black]). This was the first ever change with the exception of changing the black catridge.
After the replacing the Y+M with non-Brother catridges it appeared to restart OK but still refused to print. lpstat -p reported "unplugged or turned off".
I then had a 4-day hair-pulling horror, which included struggling with a Brother online AI which lied to me by saying that it would connect me with a human, but did not do so.
I got a hint whilst searching that the printer needed to be rebooted.
In the end, I rebooted computer + printer both at the same time (remove the power socket from the printer & reconnect only when the computer booted up). Before the desktop came up I heard the printer print my Virgin statement. It worked! Afterwards:
$ lpstat -p
printer BRPPL3510CDW-CMYK is idle. enabled since Mon 12 Oct 2026 01:26:11 BST
printer DCP3510W-RGB disabled since Thu 09 Oct 2025 23:34:55 BST -
File "/usr/lib/cups/filter/brother_lpdwrapper_dcpl3510cdw" not available: No such file or directoryHTH
Pages: 1
