#1 2026-09-18 21:15:47
JnvSor
[SOLVED] xdg-desktop-portal xdg-open and mimetypes
Recently I noticed xdg-open fails. This is the first time since switching to devuan that I've tried to use it, so I suspect it's related.
I'm on xfce4 trying to open a steam:// link.
~/.local/share/applications/steam.desktop
is a symlink to
~/.steam/deb-installer/steam.desktop
and contains the all important line:
MimeType=x-scheme-handler/steam;x-scheme-handler/steamlink;
Still, when opening a steam link from a browser I get the xdg-desktop-portal-gtk "No Apps available" popup, with a broken button trying to start gnome-software for some reason.
Trying to find the cause I have this strange result:
$ gio mime x-scheme-handler/steam
No default applications for “x-scheme-handler/steam”
$ xdg-mime query default x-scheme-handler/steam
steam.desktop
On top of all this a check with pstree shows xdg-desktop-portal being a direct child process of init, but I can't find it anywhere in /etc/init.d
So in summary I have two questions:
  • How do I get xdg-open working again, or some replacement?
  • How does xdg-desktop-portal start up anyway?
#2 2026-09-19 01:36:12
Mercury
Re: [SOLVED] xdg-desktop-portal xdg-open and mimetypes
Try these first:
sudo update-desktop-database
update-desktop-database ~/.local/share/applications/
That should pick up mimetype changes. (Though it should've been already done automatically.)
If that has no effect, you can try to manually set the handler:
xdg-mime default '/home/JnvSor/.local/share/applications/steam.desktop' x-scheme-handler/steam
I don't have answers to your questions beyond this.
#3 2026-09-20 14:29:40
JnvSor
That worked, awesome thanks!
