#1 2026-09-02 09:31:08
mclien
[SOLVED] tomtomgo navigation device
I have this old TomTom Navigation device, which has quite outdated maps.
Those seem to be only updatable with a WindowsPC.
I don't mid the old maps, as I found hints that it should be possible to just upload tracks. For that the device "should" be able to be recognized as a mass storage device.
But it seems to be missing something and I don't get it.
tail -f /var/log/syslog
2026-09-02T11:23:47.601753+02:00 eline kernel: usb 3-6: USB disconnect, device number 41
2026-09-02T11:23:47.601769+02:00 eline kernel: rndis_host 3-6:1.0 usb0: unregister 'rndis_host' usb-0000:00:14.0-6, RNDIS device
2026-09-02T11:23:57.445942+02:00 eline kernel: usb 3-6: new high-speed USB device number 42 using xhci_hcd
2026-09-02T11:23:57.585774+02:00 eline kernel: usb 3-6: New USB device found, idVendor=1390, idProduct=5a01, bcdDevice= 3.10
2026-09-02T11:23:57.585797+02:00 eline kernel: usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2026-09-02T11:23:57.585816+02:00 eline kernel: usb 3-6: Product: TomTom GO Essential
2026-09-02T11:23:57.585896+02:00 eline kernel: usb 3-6: Manufacturer: TomTom
2026-09-02T11:23:57.585940+02:00 eline kernel: usb 3-6: SerialNumber: ZN7398I04757
2026-09-02T11:23:57.589818+02:00 eline kernel: rndis_host 3-6:1.0 usb0: register 'rndis_host' at usb-0000:00:14.0-6, RNDIS device, 1e:2e:42:82:a6:94
2026-09-02T11:23:57.591950+02:00 eline mtp-probe: checking bus 3, device 42: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6"
2026-09-02T11:23:57.592531+02:00 eline mtp-probe: bus: 3, device: 42 was not an MTP device
2026-09-02T11:23:57.610810+02:00 eline mtp-probe: checking bus 3, device 42: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6"
2026-09-02T11:23:57.611203+02:00 eline mtp-probe: bus: 3, device: 42 was not an MTP device
I fail to figure out what is missing.
lsusb gives me:
Bus 003 Device 042: ID 1390:5a01 TOMTOM B.V. TomTom GO Essential
but nothing appears in lsblk.
#2 2026-09-02 10:35:45
mclien
Re: [SOLVED] tomtomgo navigation device
Found a workaround via sdcard.
Sadly the TomTomGo wants to be smart and re-routes the track, if it doesn't knows the roads.
So the question ist, how do I find out if the 45,- update of the map will actually know all the tracks in the wood I want to use?
#3 2026-09-02 11:41:23
mclien
Yeah the support sucks (as usual by using an AI assistant instead of an official E-Mail address).
Nevermind, the initial problem ist solved via sdcard proxy
#4 2026-09-04 19:37:03
ovi
I also have a  TomTom Navigation. Is one of the reasons I still need a Windows system and dual-boot. I need MyDrive Connect to update the device. I don't know if is possible in Linux, but is not easy I think.
