Pages: 1
which wall
/usr/bin/wallIn ancient times (xdm, X11, EDIT:fvwm*) I used to send myself messages out of scripts using /usr/bin/wall .
So I knew that e.g. a job is finished or some action to be taken.
This message showed up on all consoles and xterms or similar.
Recently I tested with wall to learn about progress of a script, but lightdm traps the message .
Does not show up on an open mate terminal.
Actually lightdm traps the message.
It shows then up on logout EDIT: /login from Xorg and keeps the xserver to restart.
Manually I must do
service lightdm restart to get a fresh login window until I logout again. Same game.
wall used to inform users from impending administration actions like shutdown or restart.
This function has been destroyed from the new habit of lightdm.
Apart from being a bug.
Now I have to find where this messages hang and they should be deleted on a restart of xserver.
It seems that the new generation of maintainers has no idea about multiuser systems.
broken by design :
Never used [wall] or [lightdm].
I am a [SLiM] enthusiast on a single-user WS.
That said and only to see if an [AI] answer can be (?) useful (I do not like it nor do I use it, this is just a test), out of curiosity I searched with Google and it came up with this without giving me an option to avoid it:
Terms used: [lightdm traps wall message]
Reply:
If your system hangs, delays, or traps a wall broadcast message when LightDM is active, it is typically because LightDM's greeter session listens to standard system log channels or terminal broadcasts, but lacks a standard terminal emulator to output the text cleanly.
Why the Trap Happens
Greeter Isolation:
LightDM's greeter runs under its own isolated unprivileged account (lightdm). If a system event (like a scheduled shutdown) fires a wall message, the system tries to inject it into all open pseudo-terminals (/dev/pts/*).TTY/STDOUT Redirection:
The lightdm user owns a sub-process session that grabs TTY streams. Because it lacks a proper graphical notification daemon to catch terminal broadcasts, the text stream can buffer natively or loop inside systemd's logs (journalctl -u lightdm)
There's more, but this may get you on your way.
I am not sure about getting it done while using [lightdm].
Turning off lightdm and using startx doesn't help. I still get the wall message on a console where I'm logged in but not in the desktop terminal.
Not sure if this helps. From 'man wall'
NOTES
Some sessions, such as wdm(1x), that have in the beginning of utmp(5) ut_type data a ':' character will not get
the message from wall. This is done to avoid write errors.
@Altoid, you do what you want at home, but stop immediately to post AI slop instead of knowledge.
If you don't know anything about the subject, then keep away. Noone is helped by AI slop whether it might be related or incidentally correct even. Since you don't know, you can't curate, and you just posted it because it looks convincing.
Stop that!
... stop immediately to post AI slop ...
... you can't curate ...
... posted it because it looks convincing.
Note taken.
Will not happen again.
That said, please do read the whole bit, especially these caveats*:
... and only to see if an [AI] answer can be (?) useful ...
... this is just a test), out of curiosity I searched ...
* my fault, I should I have posted [CAVEAT] in capital letters somewhere.
Having made clear that I did not use [wall] or [lightdm], how could it possibly look convincing to me?
I did not look like anything but AI generated stuff, something I disclosed from the start of my post.
As such, my intention was for someone else (ie: who actually knew about the subject) to opine so that a check against what this AI thing actually spewed could be made.
Actually thought it was a good idea. 8^°
Yes I realized your intention. But it's bad enough to try to run focussed discourse with "people that know" (also usually intended to be helpful), so when you don't know, just stay out of it... "listen and learn" so to speak.
Perhaps this thread can return to the wall program and how it behaves now versus in ancient times. (see eg post #3 above)
if i dare say, the issue is not so much a program named wall but rather the need for a program to send messages from other programs in a way the user can get them.
Well, wall is a traditional program, see man wall and afaiui the issue is that it behaves differently now from how it has behaved; perhaps most probably because utmp database (another traditional thing, see man utmp) has change format, and in fact might also be one of those things that the kids have deprecated.
Certainly has little or nothing to do with wall papers.
How about waiting for someone that knows something about wall? I realise it can be really tempting to flaunt your ignorance just to have a post made, but it really isn't helpful.
worry not i have no problem sharing my ignorance with the world, that was the first thing i was taught about engineering at university
tangent aside, my point is not about ignorance but rather on function over a specific program, if a traditional program no longer works in the expected traditional way it did then it comes the question of is it the program or the setup around it
wall from the util-linux package should have the function of writing a message onto the terminals of all currently logged users, how does wall "get" the list of terminals associated with current users, on my system when i run who i get a list that contains my current terminal emulators (pts/N where N is an int starting at 0) but also contains tty7, the tty where the lightdm greeter spawns to initate the x11 server, the w command produces a similar list also showing the leader process inside each terminal, however no tty device is listed, doing a quick test running just wall "test" in my main machine on devuan 6 did produce the expected traditional behaviour of broadcasting a message to every running terminal i have
so it isn't much the program that isn't behaving traditionally but the setup around it, which begs the question if some specific program IS affecting the detection that wall should be able to do or is rather eating the message preventing it from propagating to the user terminals
all i can ask is what is bai4Iej2need's setup, a Desktop Environment, a window manager? which lightdm greeter?
i have lightdm with the slick greeter, i use a window manager but got some custom tooling so that my .xsession is a file that just launchs a program i wrote myself to be the session process which spawns my window manager, pulse audio daemons, picom and more, yet when i run wall from any regular running terminal it works
this is a standard daedalus install with mate as desktop.
aptitude show lightdm
Paket: lightdm
Version: 1.26.0-8+devuan1
aptitude show mate-desktop
Paket: mate-desktop
Version: 1.26.0-2
aptitude show mate-terminal
Paket: mate-terminal
Version: 1.26.0-2Repeated test : sent wall-message from root, arrived at 2 consoles (Alt-F2, owned by me), did not arrive at mate terminal.
broken by design :
tested the same on an excalibur virtual machine (under oracle virtualization) consoles are not accessible :
mate terminals do not show test message
broken by design :
bai4Iej2need,
I think we're using the wrong terminal. I just tried it with xterm and it works. Does not matter if I use startx for openbox or openbox-session or if I use lightdm to start a full xfce destkop. Wall is happy to talk to xterm but does not work with xfce-terminal or qterminal. I didn't try any others.
Following on from EDX-0, I tested wall in a lightdm + xfwm4 setup, as a non-root user as well as root.
From what I can gather wall will only write the message to root owned ttyN and pty/N. This is the same for both root and non-root, though of course also that it needs write permissing to the device; e.g. in my setup, non-root users in the tty group have such write access.
X11 terminal emulators are the ones setting up the pty.
I suppose it remains unclear whether wall has got revised decision logic, and/or different terminal emulators offer different pty handling.
Just to confirm:
... tried it with xterm and it works.
Does not work with [xfce-terminal], [lxterminal] or [tilix].
Please re-read the posts further above. E.g. wall "works with" xfce-terminal quite well.
It really isn't down to a choice of which (virtual) terminal is used but most significantly that the tty/pty must be owned by root. I have not used wall regularly enugh to be certain, but that particular restriction might be a newish thing (at the timescale of wall).
The other restriction is that the user of wall must have write access to the device being written to. As mentioned above, wall will consider all /dev/ttyN and /dev/pts/N, and then write to those with applicable write access and owner being root.
The interested reader may experiment with, say
$ echo foobar > /dev/pts/3to see which of their virtual terminal that ends up in. Or to be more targeted, they may first run
$ ttyin a shell to determin which pty device node to use for that shell, and then go crazy writing to it.
what I understand until now :
wall (root) writes to all open tty1 - tty7
Does not write to ptys not owned by root
ps aux | grep tty7
root 1369 2.1 0.2 26629380 192864 tty7 Ssl+ 08:57 0:04 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitchthis is owned by root.
The user (uid>=1000) logs out of his x session.
lightdm is restarted owned by user lightdm (111:118) from init process
User (uid>=1000) logs in again through the login window.
Then pam? or some authorization process kills the lightdm process, because the writing by wall has confused the rights.
The wall messages of the past show up in the tty7 and no x-session appears.
lightdm must be restarted to get a fresh lightdm login window.
This time the login of uid=1000 is successful, but after the logout above procedure repeats.
The wall messages are still there, augmented by all test messages in the mean time.
I can confirm, that xterm opened by uid 1000 receives the wall message from root, but mate terminal not
It looks like i must trace a failed login session to find its cause.
broken by design :
at this point it begs the question if it would not be better to just write a program to do what wall(1) is supposed to do but in a less obtuse way, i do not think it would be too difficult to write something that has a correct and predictable behaviour, after all i quickly cobbled together this snippet out of code that exists in pywal
#!/bin/python3
# SPDX-License-Identifier: MIT
import logging
import os
import platform
import glob
import sys
import subprocess
def setup_logging():
"""Logging config."""
logging.basicConfig(
format=(
"[%(levelname)s\033[0m] "
"\033[1;31m%(module)s\033[0m: "
"%(message)s"
level=logging.INFO,
stream=sys.stdout,
logging.addLevelName(logging.ERROR, "\033[1;31mE")
logging.addLevelName(logging.INFO, "\033[1;32mI")
logging.addLevelName(logging.WARNING, "\033[1;33mW")
setup_logging()
OS = platform.uname()[0]
has_fcntl = False
fcntl_warning = ""
try:
import fcntl
has_fcntl = True
except ImportError:
fcntl_warning = "{}, {}".format(
"can't skip blocking io in current platform",
"program could hang indefinitely",
def create_dir(directory):
"""Alias to create the cache dir."""
os.makedirs(directory, exist_ok=True)
def save_file(data, export_file):
"""Write data to a file."""
create_dir(os.path.dirname(export_file))
if has_fcntl:
try:
with open(export_file, "w") as file:
# Get the current flags and add non-blocking mode
# to skip TTYs suspended by Flow Control
# https://www.gnu.org/software/libc/manual/html_node/Getting-File-Status-Flags.html
# https://www.gnu.org/software/libc/manual/html_node/Open_002dtime-Flags.html
flags = fcntl.fcntl(file, fcntl.F_GETFL)
fcntl.fcntl(file, fcntl.F_SETFL, flags | os.O_NONBLOCK)
file.write(data)
except PermissionError:
logging.warning("Couldn't write to %s.", export_file)
except BlockingIOError:
logging.warning(
"Couldn't write to %s, not accepting data", export_file
else:
try:
file.write(data)
def send_to_term(message, to_send=True):
"""Send colors to all open terminals."""
if OS == "Darwin":
devices = glob.glob("/dev/ttys00[0-9]*")
elif OS == "OpenBSD":
devices = subprocess.check_output(
"ps -o tty | sed -e 1d -e s#^#/dev/# | sort | uniq",
shell=True,
universal_newlines=True,
).split()
else:
devices = []
patterns = ["/dev/pts/[0-9]*", "/dev/tty[1-6]"]
for pattern in patterns:
devices.extend(glob.glob(pattern))
if not has_fcntl:
logging.warning(fcntl_warning)
# Send data to open terminal devices.
if to_send:
for dev in devices:
if dev == "/dev/pts/0":
if (
os.environ.get("XDG_CURRENT_DESKTOP") == "KDE"
or os.environ.get("DESKTOP_SESSION") == "plasma"
continue
if dev == "/dev/tty7":
continue
save_file(message, dev)
def main():
send_to_term(sys.argv[1])
if __name__ == "__main__":
main()the snippet is intentionally naive as a showcase of some quickly thrown together thing, it cares not for differentiating root from regular user just writes to whichever file it can open in "w" mode, the glob pattern intentionally avoids /dev/tty7 and just in case when writing to all terminal devices it explicitly avoids /dev/tty7 for good measure
the script could be made configurable (again this is just a quick cobbled together idea) to write only to specific patterns and add more filters to exclude any tty where a display manager lives
since this script already only cares that it can write to the target file, a shell wrapper could be put around to launch the script under it's own user, call it something like write_to_all_terminals and add a udev rule to give write permissions over all terminal devices (/dev/tty* and /dev/pts/*), then when the wrapper is called it will send whichever message is passed to all terminals
again this is just an idea.
edit: did not notice that the whole logging setup was initiated AFTER the first time the logging function could be called, anyway it is fixed
EDX-0
1. Totally agree! Make do or make new. ![]()
2. neat script but : #!/bin/python3 ?
i guess it should be #!/usr/bin/python3 but since usrmerge it makes no difference whatsoever as /bin is the same as /usr/bin
Well in Daedalus it does. And since there's no more /bin in Excalibur anyway looks like everything is /usr/bin now.
The use case "write a message to all my terminals" is similar to "write a message to all", in other words wall(1) broadcasts a message to all currently logged in users. An example (well remembered by Gü;-) is the check of an EBS (nowadays EAS) in case the UPS has to handle a current powerfail on LAN: The UPS signals the server via /dev/ttySx: watch out the power outage. The sysV initiates a shutdown -h. That in turn broadcasts to all users: save your work instantly. The clients got the message via EtherShare or PC-NFS, the alert displays like xmessage(1).
That said the problem seems NOT "who is the display manager?" NOR the existing difference between "terminal" or "console". BUT it may have to do with the write access to the terminal device by group "tty" (BTW: debian uses GID 5).
Tthe following checks with the xfce environment (BTW thanks to devuan! The usual xorg tools are available by default! Other distribution may request extra packages to install:-( show three different possibilities to use the wall utility.
1. Sending from xfce-terminal to an receiving xterm is OK, but OTHER xfce-terminals do NOT get the message, there is only a beep.
2. Sending from xterm to other virtual terminals works only if the following access rules for the devices apply:
ls -l /dev/pts/*creates the device node with added g+w permissions:
crw--w---- 1 guuml tty 136, 3 2026-09-07 01:05 /dev/pts/3
does NOT change the rights of group "tty":
crw------- 1 guuml tty 136, 4 2026-09-07 01:04 /dev/pts/4
==> Addendum for su -, doas -s: the ownership of the device changes, but the source of the broadcast send is still guuml at pts/6 …
crw--w---- 1 root tty 136, 6 2026-09-07 01:04 /dev/pts/6
3. The situation is different on console:
ll /dev/tty{1..7}crw------- 1 guuml tty 4, 1 2026-09-07 01:15 /dev/tty1
crw------- 1 root tty 4, 2 2026-09-07 01:15 /dev/tty2
crw------- 1 gumml tty 4, 3 2026-09-07 01:15 /dev/tty3
crw--w---- 1 root tty 4, 4 2026-09-06 11:10 /dev/tty4
crw--w---- 1 root tty 4, 5 2026-09-06 11:10 /dev/tty5
crw--w---- 1 root tty 4, 6 2026-09-06 11:10 /dev/tty6
crw--w---- 1 root tty 4, 7 2026-09-06 11:10 /dev/tty7
BTW about my setup: The login manager slim is used only on other users' machines. Personally I prefer a more traditional setup with update-rc.d slim disable and a modified /etc/inittab if neccessary. After console login my ~/.profile checks for a hushlogin otherwise the default GUI is exec startx.
Ok, my /dev/tty1 is xfce4 with the xfwm4 display manager but any GUI with freedesktop support may behave similar? Please note the dropped write privileges for "tty" after login.
At /dev/tty2 a root login happend. (BTW the root password is very different from users' password;-) getty(8) prompts for a login name and then invokes login(1). That drops write access g-w, too. BUT wall broadcasts are received nethertheless!
And /dev/tty3 is a hushlogin just to check out the all of the wall.
On devuan the /dev/console is used by kernel/eudev/xorg at the same time. So xconsole(1) is not of much help here.
Does the terminal emulator xterm(1) changing mode and ownership of the assigned device by own means or by some library used by kernels' console driver, too?
A) You can wall from xfce-terminal to both xterm and console, but you receive the broadcast only on xterm or console.
B) xfce-terminal do not get the message beside a beep. Other GTK+ terminals may be affected, too.
C) A wall from root is send to all logged in user on all xterm and console. A xfce-terminal only beeps.
The session management of some "Desktop Environment" may differ because …
This is xfdesktop version 4.16.0, running on Xfce 4.16.
Built with GTK+ 3.24.24, linked with GTK+ 3.24.24.
… requesting a unique user experience … Arrrggghhh .
I have mentioned the "beep only" for an older xfce-terminal, newer versions may have added features. Note the difference to xterm: one process spawns multiple virtual terminals in different windows and/or tabs, see help about terminal options.
xfce4-terminal 0.8.10 (Xfce 4.16)
Running `xfce4-notifyd-config` indicates there are many … more bells and whistles and turning wheels … not onlykids … a bridge to cross … No pun intended, rumours are that other GUIs have similar features. (BTW: the said shutdowm message was delievered via RPC, but the SMB/NMB clients didn't get the message :-)
Hopefully this sheds some light on the root causes of the topic.
--Gü
PS: finding the device names of all childs spawned by a terminal emulator like xfce-terminal:
ps --ppid $(pgrep xfce4-terminal) -o %y |
sed -E -n 's%^(pts/[0-9]+)%/dev/\1%p' pgrep gets the PID of a process by pattern.
ps --ppid PPID -o %y prints the attached tty of all childs of parent PPID.
The sed does some reformating of previsious output.
Using the resulting device list with the echo workaround (see #15 ralph.ronnquist) is left as an exercise to the reader.
seeing the pattern that xfce-terminal, tilix and lxterminal all are reported to fail to get messages from wall i decided to try with mate-terminal and surprise surprise it also fails to receive the messages from wall, do you guys know that those 4 got in common? all are libvte terminals and wouldn't you know libvte INTENTIONALLY dropped support for the utmp file, since wall relies on the utmp file (/run/utmp) to find the terminal pointers of all currently logged users it is completely unable to find ANY libvte terminal whatsoever...
refference: https://bugzilla.xfce.org/show_bug.cgi?id=13710
Very good find ...
With a very mislaid reply.
> Egmont, do I understand correctly that you have no plans on restoring utmp support in vte?
Yup.
> What about using libutempter which you've mentioned?
Not planning this one either.
And that was that.
Why am I not surprised?
gotta love how the gnome "engineering" decisions affect the downstreams people actually rely on
Good news for the weekend: xfce-terminal is able to receive broadcasts from wall at will! But there is a grain of salt: It lasts around a week of thought (and five days of work;-( Eventually I have con-figured it out on MY up-to-date chimaera with the xfce desktop.
BTW: There was a time before jessie: Every user who wants my help for running his own "personal computer" has to use the mate desktop, the last gtk2 … Sorry this thread should NOT evolve into a sequel to the "sequel of xbill" (2015). But at some point in the not to far future I may want to install excalibur and/or Xlibre … Re-reading my notes may be helpful to me, for others too.
My previous post was about the environment I'm working with …
While I am preparing to write the script about the hole Cave of the white rabbit an error occured with “up-to-date”:
E: Failed to fetch … 404 Not Found [IP: 2a04:4e42:400::644 80]
Same may say Excalibur while others are watching monthy python's quest for the holy grail, and other others listen to musik …
That there's no way to delay /
that trouble comin' every day /
No way to delay /
The internet is dead, isn't it? Man comes next week, monday, when ready …
Pages: 1
