#1 2026-07-30 14:31:36
tukhalele
Huawei Freebuds
Work out of the box in Debian 13. Not so much in Devuan 6. They are connected in bluetooth. But no sound. I can not see where to change the output source. They must not be connected properly. Sometimes when I try to connect I get:  Conection unsucessfull - No sound end points registered.( thats my translation)
Address              34:D6:93:4F:2A:F0
Address type      public
Name                 HUAWEI FreeBuds SE 4 ANC
Alias                   HUAWEI FreeBuds SE 4 ANC
Class                  0x240418
Appearance       0x0000
Icon                    audio-headphones
Paired                 ja
Trusted               ja
Blocked              nej
Legacy Pairing   nej
Connected         nej
00001000-0000-1000-8000-00805f9b34fb ServiceDiscoveryServerServiceClassID
00001101-0000-1000-8000-00805f9b34fb Seriel port
0000110b-0000-1000-8000-00805f9b34fb Datamodtager for lyd
0000110c-0000-1000-8000-00805f9b34fb Fjernbetjeningsmål
0000110e-0000-1000-8000-00805f9b34fb Fjernbetjening
0000110f-0000-1000-8000-00805f9b34fb Videomøder
0000111e-0000-1000-8000-00805f9b34fb Håndfri
0000112e-0000-1000-8000-00805f9b34fb Telefonbogsadgang (PBAP) - PCE
00001133-0000-1000-8000-00805f9b34fb Server til underretning om beskeder
00001200-0000-1000-8000-00805f9b34fb PnP-information
00001203-0000-1000-8000-00805f9b34fb Generisk lyd
00007033-0000-1000-8000-00805f9b34fb Ukendt
Adapter             /org/bluez/hci0
In the sound app they are sof-hda-dsp, but thats also what the speakers are called.
Am interrested in all suggestions -thanks
#2 2026-07-30 16:54:38
Re: Huawei Freebuds
tukhalele wrote:
... must not be connected properly.
Don't use this type of hardware but it should (?) behave as any other BT harware.
eg: BT mouse with a USB receiver plugged in.
There may be more information in /var/log/[fill-in]
ie: [dmesg] and then [kern.log], [syslog], [messages] and [lsusb].
1. Boot the box without the [thinguies/USB whatever] plugged in.
2. Plug them in and check what [dmesg] tells you.
3. That should give you some data wrt the hardware.
Check to see what [lsusb] says.
Maybe it is a driver/configuration/pairing issue.
Edit:
A fast check on-line found that the earbuds have to be paired manually.
The lack of [systemd] in Devuan is (most probably) the key.
Maybe that the Huawei management apps are not Linux-able?
Google for [HUAWEI FreeBuds SE 4 ANC linux] and [HUAWEI FreeBuds SE 4 ANC linux Devuan].
#3 2026-07-30 17:22:48
Re: Huawei Freebuds
Maybe Audio Mixer > Volume Control > Output Devices - (Port).
#4 2026-07-30 22:55:41
Re: Huawei Freebuds
The error message is an indication that the computer does not run the required server, which is the one registering as an endpoint for the audio service. On a good day I would remember the TLAs involved.
Bluetooth audio invloves firstly a connectiivty daemon, typically bluez, which sits as a broker between the device connection handling (the link level, so to speak) and the audio protocol(s) handler. The latter depends on your choice in audio setup. For a "pure alsa" setup you would need bluealsa daemon, and that afaik has been shit-ified so may require a bit of hands-on in its dbus linking. I'm not aware about a direct point-n-click solution, but mayby there is.
#5 2026-07-31 08:38:11
kapqa
Re: Huawei Freebuds
rubbish never comes for free.
#6 2026-08-01 08:11:35
tukhalele
Re: Huawei Freebuds
kapqa
Yesterday 10:38:11
Is that a suggestion???
#7 2026-08-01 08:14:08
tukhalele
Re: Huawei Freebuds
Update
Was using Cinnamon DE.
Changed to KDE and they now work fine.
So it was a Cinnamon problem - not a Devuan problem.
