#1 2026-07-20 10:20:20
VirtualBox autostart
I use a headless VirtualBox VM to run a stripped down Devuan Chimaera with Pi-hole + unbound.
Has worked without issues but these days I am having some issues with it coming on-line.
eg: stalling
To spin up the VM, I use its own start-up service to which I can add a delay but for some reason (another topic) sometimes it does not work. so I thought about being consistent with Devuan and having this VM (only one needed at boot) start-up via [sysvinit].
A search on the web got me this:
### BEGIN INIT INFO
# Provides:          vbox-autostart
# Required-Start:    $local_fs $syslog $network vboxdrv
# Required-Stop:     $local_fs $syslog $network vboxdrv
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Autostart VirtualBox VMs on Devuan SysVinit
### END INIT INFO
case "$1" in
    start)
        echo "Starting VirtualBox VMs for user $VM_USER..."
        for VM in $VMS; do
            echo "Booting $VM..."
            su - $VM_USER -c "/usr/bin/VBoxManage startvm \"$VM\" --type headless"
        done
    stop)
        echo "Stopping VirtualBox VMs gracefully..."
        for VM in $VMS; do
            echo "Sending ACPI shutdown to $VM..."
            su - $VM_USER -c "/usr/bin/VBoxManage controlvm \"$VM\" acpipowerbutton"
        done
        # Give the VMs a few seconds to flush disk cache and turn off
        echo "Waiting for VMs to close..."
        sleep 10
    restart)
        $0 stop
        $0 start
    status)
        echo "Currently running VMs:"
        su - $VM_USER -c "/usr/bin/VBoxManage list runningvms"
        echo
  exit 1
esac
exit 0
The rest is the making the script executable and registering it, which I recall having done at some time with some script.
As root: chmod +x /etc/init.d/vbox-autostart and update-rc.d vbox-autostart defaults 99 10
I have no trust in this AI thing and don't want to screw up anything so I'd appreciate some input.
eg: the [99 10] at the end of the [update-rc.d] line.
I only need to make sure the network is up for the VM to start so that Conky can fetch my IPv4 address.
Does that not get taken care of with the [Required-start] line in the script?
Shouldn't Conky have its own script (?) to make sure it does not start before the VM is upand not depend on a delay?
#2 2026-07-20 16:10:48
Re: VirtualBox autostart
chmod +x /etc/init.d/vbox-autostart looks OK.
Try man update-rc.d to see what the second command will do. I'd try update-rc.d -n vbox-autostart defaults 99 10 first (the -n means just say what it would do).
#3 2026-07-20 17:26:30
The numbers are just the start and kill sequence numbers, where/when in the process you want them to start/stop, as some things depend on other things already being started. So the 99 indicates you want it to start after everything else when booting, and kill early in the shutdown process.
The start/stop run-levels are now contained in the LSB info at the top of the script rather than in the update-rc.d command like they used to back in the day, thus "defaults" means use the lsb data.
#4 2026-07-20 17:42:39
... man update-rc.d to see ...
Yes, I knew what those numbers were for but I did not want to go too far with the delay in starting.
eg: it could be that [99] is too much, maybe [44] would be enough.
greenjeans wrote:
99 indicates you want it to start after everything else ...
... kill early in the shutdown process.
Right.
I wrote:
... taken care of with the [Required-start] line in the script?
greenjeans wrote:
... start/stop run-levels are now contained in the LSB info ...
I see.
So [99] and [10] not needed?
Good to know.
And what about Conky ...
A [sysvinit] script to make sure it starts (with no delays) only if the network is up or stay as it is with a delay that does not always work?
Any one have a [sysvinit] script for Conky?
Thanks you both for your input.
#5 2026-07-20 18:07:12
I see.
Good to know.
Maybe yes, maybe no, if no number is specified the system defaults to giving it a priority of 20, which may not work for you.
Never used an init script for conky before, I start it from the openbox autostart file, and in fact I just moved the nm-applet there too out of /etc/xdg/autostart, and set it to start before conky.  Xdg also has an autostart config file if you make one but I never did.
#6 2026-07-20 21:44:47
I don't mess with init scripts. I have a vague memory of making desktop buttons to start specific virtual machines with some vbox command that I don't remember. You could probably start it with a command right after user autologin after all necessary services are running.
(Warning. This was so long ago, I might be remembering something with vmware.)
#7 2026-07-21 21:50:53
Please excuse the belated reply.
greenjeans wrote:
... no number is specified the system defaults to giving it a priority of 20 ...
I see ...
greenjeans wrote:
Never used an init script for conky ...
Same here.
I use the [Session and Startup] section in XFCE.
Neither do I, unless something comes up.
fsmithred wrote:
... making desktop buttons to start specific virtual machines ...
If for whatever reason I have to stop / restart the headless VM running [Pi-hole], I do it from the command line.
If not, I use the VBox GUI.
Thank you both for your input.
