#1 2026-07-14 17:30:50
Micronaut
Sudden change in repositories
Just today, as I check every time I boot my system, which is daily, I got a series of errors from APT.
Skipping acquire of configured file 'non-free-firmware/dep11/icons-48x48.tar' as repository 'http://deb.devuan.org/merged daedalus-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
Now, simply plugging this into Google, I got an "AI" response that I needed to edit my source.list and remove the reference to firmware. Not hard to do, but WHY was there this sudden change? Is there some technical reason? It seems like change for its own sake.
#2 2026-07-14 18:56:09
Re: Sudden change in repositories
It's not listed here for daedalus-security like it is for the other daedalus repos.
https://pkgmaster.devuan.org/merged/dis … /InRelease
Origin: Devuan
Label: Devuan-Security
Suite: oldstable-security
Version: 5.0
Codename: daedalus-security
Date: Tue, 14 Jul 2026 18:50:06 UTC
Valid-Until: Tue, 21 Jul 2026 18:15:06 UTC
Architectures: amd64 arm64 armel armhf i386 ppc64el
Components: main contrib non-free          <---- missing "non-free-firmware"
I'm guessing it got left out by mistake. You didn't spell it wrong.
#3 2026-07-14 21:55:20
Micronaut
But up till yesterday it was on that line in sources.list and DID NOT cause any error messages. What changed and why?
#4 2026-07-14 23:57:15
Maintenance of bookworm-security got moved to the LTS team. They'll probably hear about it soon and fix it. FWIW, you can still do upgrades, and the nonfree firmware doesn't change often, so you're probably not missing anything.
https://lists.debian.org/debian-announc … 00007.html
#5 2026-07-15 07:45:11
Andre4freedom
Here comes another "inconsistency" of another package- and patch-mirror:
The repository ch.deb.devuan.org is no longer working, since a few days ago - at all.
Before that, a re-issuing the apt update / apt upgrade command solved the thing momentarily.
I did switch to de.deb.devuan.org and this works well.
andre@sapporo:~$ sudo apt update
[sudo] password for andre:
Ign:1 http://ch.deb.devuan.org/merged excalibur InRelease
Ign:2 http://ch.deb.devuan.org/merged excalibur-security InRelease
Ign:3 http://ch.deb.devuan.org/merged excalibur-updates InRelease
Err:4 http://ch.deb.devuan.org/merged excalibur Release
  404  Not Found [IP: 147.78.194.22 80]
Err:5 http://ch.deb.devuan.org/merged excalibur-security Release
Err:6 http://ch.deb.devuan.org/merged excalibur-updates Release
Error: The repository 'http://ch.deb.devuan.org/merged excalibur Release' no longer has a Release file.
Notice: Updating from such a repository can't be done securely, and is therefore disabled by default.
Notice: See apt-secure(8) manpage for repository creation and user configuration details.
Error: The repository 'http://ch.deb.devuan.org/merged excalibur-security Release' no longer has a Release file.
Error: The repository 'http://ch.deb.devuan.org/merged excalibur-updates Release' no longer has a Release file.
Whom must I send this message to?
Have a good day,
André
#6 2026-07-15 16:09:08
I would point a web browser at  http://ch.deb.devuan.org/ and start looking around for a name or address to contact. Or any other clue.
#7 2026-07-15 17:01:52
daedalus-security is fixed.
Components: main contrib non-free non-free-firmware
