#1 2026-07-13 23:12:21
deepforest
how unlock refresh rates at radeon opensource driver?
i have only 1920-1080 at 60hz only
i am try apply several calculated by CRU windows utility, under windows this modes working good but under Linux monitor go to "out of range" why??
xrandr --newmode "1920x1080_75" 167.85 1920 1928 1960 2000 1080 1105 1113 1119 +HSync -Vsync
xrandr --newmode "1920x1080_75-2" 167.85 1920 1928 1960 2000 1080 1105 1113 1119 +HSync -Vsync
xrandr --newmode "1920x1080_75.00"  220.64  1920 2056 2264 2608  1080 1081 1084 1128  -HSync +Vsync
freeartist-devuan@devuan:~$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
   1920x1080     60.00*+  50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1600x900      60.00
   1280x1024     75.02    60.02
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x576i      50.00
   720x480       60.00    59.94
   720x480i      60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
   1920x1080R   119.88
   1920x1080_75  75.00
   1920x1080_75-2  75.00
   1920x1080_75.00  75.00
DVI-0 connected (normal left inverted right x axis y axis)
   1920x1200     59.95 +
   1920x1080     60.00    50.00    59.94
   1600x1200     60.00
   1680x1050     59.88
   1280x1024     60.02
   1440x900      59.90
   1280x960      60.00
   1280x800      59.91
   1024x768      60.00
   800x600       60.32    56.25
   720x576       50.00
   720x480       60.00    59.94
   640x480       60.00    59.94
DVI-1 disconnected (normal left inverted right x axis y axis)
freeartist-devuan@devuan:~$ xrandr --verbose
	Identifier: 0x54
	Timestamp:  4564091
	Subpixel:   horizontal rgb
	Clones:
	CRTCs:      0 1 2 3 4 5
	Transform:  1.000000 0.000000 0.000000
	            0.000000 1.000000 0.000000
	            0.000000 0.000000 1.000000
	           filter:
	TearFree: auto
		supported: off, on, auto
	audio: auto
	scaling mode: None
		supported: None, Full, Center, Full aspect
	dither: off
		supported: off, on
	underscan vborder: 0
		range: (0, 128)
	underscan hborder: 0
		range: (0, 128)
	underscan: off
	coherent: 1
		range: (0, 1)
	link-status: Good
		supported: Good, Bad
	CONNECTOR_ID: 55
		supported: 55
	non-desktop: 0
		range: (0, 1)
HDMI-0 connected primary 1920x1080+0+0 (0x59) normal (normal left inverted right x axis y axis) 527mm x 296mm
	Identifier: 0x55
	Timestamp:  4564091
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0 1 2 3 4 5
	           filter:
	EDID:
		00ffffffffffff0010ac6da142593930
		171e010380351e78ea72b5a75552a027
		105054a54b00714f8180a9c0d1c00101
		010101010101023a801871382d40582c
		45000f282100001e000000ff00354438
		544c32330a2020202020000000fc0044
		454c4c205332343231484746000000fd
		0030901eaa22000a20202020202001ff
		02032ff1519005040302071601141f12
		130611153f4023090707830100006703
		0c0020000044681a000001013090e686
		6f80a070384040302035000f28210000
		1ad88380a070383040302035000f2821
		00001a00000000000000000000000000
		00000000000000000000000000000000
		0000000000000000000000000000004b
	TearFree: auto
	audio: auto
	scaling mode: None
	dither: off
		supported: off, on
		range: (0, 128)
		range: (0, 128)
	underscan: off
	coherent: 1
		range: (0, 1)
	link-status: Good
	CONNECTOR_ID: 57
		supported: 57
	non-desktop: 0
		range: (0, 1)
  1920x1080 (0x59) 148.500MHz +HSync +VSync *current +preferred
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1920x1080 (0x5a) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1920x1080 (0x5b) 148.352MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.43KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  59.94Hz
  1920x1080i (0x5c) 74.250MHz +HSync +VSync Interlace
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  33.75KHz
        v: height 1080 start 1084 end 1094 total 1125           clock  60.00Hz
  1920x1080i (0x5d) 74.250MHz +HSync +VSync Interlace
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  28.12KHz
        v: height 1080 start 1084 end 1094 total 1125           clock  50.00Hz
  1920x1080i (0x5e) 74.176MHz +HSync +VSync Interlace
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  33.72KHz
        v: height 1080 start 1084 end 1094 total 1125           clock  59.94Hz
  1600x900 (0x5f) 108.000MHz +HSync +VSync
        h: width  1600 start 1624 end 1704 total 1800 skew    0 clock  60.00KHz
        v: height  900 start  901 end  904 total 1000           clock  60.00Hz
  1280x1024 (0x60) 135.000MHz +HSync +VSync
        h: width  1280 start 1296 end 1440 total 1688 skew    0 clock  79.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  75.02Hz
  1280x1024 (0x61) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1152x864 (0x62) 108.000MHz +HSync +VSync
        h: width  1152 start 1216 end 1344 total 1600 skew    0 clock  67.50KHz
        v: height  864 start  865 end  868 total  900           clock  75.00Hz
  1280x720 (0x63) 74.250MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  45.00KHz
        v: height  720 start  725 end  730 total  750           clock  60.00Hz
  1280x720 (0x64) 74.250MHz +HSync +VSync
        h: width  1280 start 1720 end 1760 total 1980 skew    0 clock  37.50KHz
        v: height  720 start  725 end  730 total  750           clock  50.00Hz
  1280x720 (0x65) 74.176MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  44.96KHz
        v: height  720 start  725 end  730 total  750           clock  59.94Hz
  1024x768 (0x66) 78.750MHz +HSync +VSync
        h: width  1024 start 1040 end 1136 total 1312 skew    0 clock  60.02KHz
        v: height  768 start  769 end  772 total  800           clock  75.03Hz
  1024x768 (0x67) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x68) 49.500MHz +HSync +VSync
        h: width   800 start  816 end  896 total 1056 skew    0 clock  46.88KHz
        v: height  600 start  601 end  604 total  625           clock  75.00Hz
  800x600 (0x69) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  720x576 (0x6a) 27.000MHz -HSync -VSync
        h: width   720 start  732 end  796 total  864 skew    0 clock  31.25KHz
        v: height  576 start  581 end  586 total  625           clock  50.00Hz
  720x576i (0x6b) 13.500MHz -HSync -VSync Interlace
        h: width   720 start  732 end  795 total  864 skew    0 clock  15.62KHz
        v: height  576 start  580 end  586 total  625           clock  50.00Hz
  720x480 (0x6c) 27.027MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.50KHz
        v: height  480 start  489 end  495 total  525           clock  60.00Hz
  720x480 (0x6d) 27.000MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.47KHz
        v: height  480 start  489 end  495 total  525           clock  59.94Hz
  720x480i (0x6e) 13.514MHz -HSync -VSync Interlace
        h: width   720 start  739 end  801 total  858 skew    0 clock  15.75KHz
        v: height  480 start  488 end  494 total  525           clock  60.00Hz
  720x480i (0x6f) 13.500MHz -HSync -VSync Interlace
        h: width   720 start  739 end  801 total  858 skew    0 clock  15.73KHz
        v: height  480 start  488 end  494 total  525           clock  59.94Hz
  640x480 (0x70) 31.500MHz -HSync -VSync
        h: width   640 start  656 end  720 total  840 skew    0 clock  37.50KHz
        v: height  480 start  481 end  484 total  500           clock  75.00Hz
  640x480 (0x71) 25.200MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.50KHz
        v: height  480 start  490 end  492 total  525           clock  60.00Hz
  640x480 (0x72) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  720x400 (0x73) 28.320MHz -HSync +VSync
        h: width   720 start  738 end  846 total  900 skew    0 clock  31.47KHz
        v: height  400 start  412 end  414 total  449           clock  70.08Hz
  1920x1080R (0x404) 285.250MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock 137.14KHz
        v: height 1080 start 1083 end 1088 total 1144           clock 119.88Hz
  1920x1080_75 (0x44a) 174.570MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  83.93KHz
        v: height 1080 start 1083 end 1088 total 1119           clock  75.00Hz
  1920x1080_75-2 (0x454) 167.850MHz +HSync -VSync
        h: width  1920 start 1928 end 1960 total 2000 skew    0 clock  83.92KHz
        v: height 1080 start 1105 end 1113 total 1119           clock  75.00Hz
  1920x1080_75.00 (0x45f) 220.640MHz -HSync +VSync
        h: width  1920 start 2056 end 2264 total 2608 skew    0 clock  84.60KHz
        v: height 1080 start 1081 end 1084 total 1128           clock  75.00Hz
	Identifier: 0x56
	Timestamp:  4564091
	Clones:
	CRTCs:      0 1 2 3 4 5
	           filter:
	EDID:
		00ffffffffffff004c2d87053432594d
		09140103803420782aee91a3544c9926
		0f5054230800a9408180814081009500
		b30001010101283c80a070b023403020
		360006442100001a000000fd00323f1e
		5111000a202020202020000000fc0053
		796e634d61737465720a2020000000ff
		004839585a3330303334380a202001bf
		02010400023a801871382d40582c4500
		06442100001e023a80d072382d40102c
		458006442100001e011d007251d01e20
		6e28550006442100001e011d00bc52d0
		1e20b828554006442100001e8c0ad090
		204031200c4055000644210000188c0a
		d08a20e02d10103e9600064421000018
		00000000000000000000000000000096
	TearFree: auto
	load detection: 1
		range: (0, 1)
	audio: auto
	scaling mode: None
	dither: off
		supported: off, on
		range: (0, 128)
		range: (0, 128)
	underscan: off
	coherent: 1
		range: (0, 1)
	link-status: Good
	CONNECTOR_ID: 59
		supported: 59
	non-desktop: 0
		range: (0, 1)
  1920x1200 (0x74) 154.000MHz +HSync -VSync +preferred
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  74.04KHz
        v: height 1200 start 1203 end 1209 total 1235           clock  59.95Hz
  1600x1200 (0x75) 162.000MHz +HSync +VSync
        h: width  1600 start 1664 end 1856 total 2160 skew    0 clock  75.00KHz
        v: height 1200 start 1201 end 1204 total 1250           clock  60.00Hz
  1680x1050 (0x76) 119.000MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.67KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.88Hz
  1440x900 (0x77) 88.750MHz +HSync -VSync
        h: width  1440 start 1488 end 1520 total 1600 skew    0 clock  55.47KHz
        v: height  900 start  903 end  909 total  926           clock  59.90Hz
  1280x960 (0x78) 108.000MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  60.00KHz
        v: height  960 start  961 end  964 total 1000           clock  60.00Hz
  1280x800 (0x79) 71.000MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  49.31KHz
        v: height  800 start  803 end  809 total  823           clock  59.91Hz
  800x600 (0x7a) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
	Identifier: 0x57
	Timestamp:  4564091
	Clones:
	CRTCs:      0 1 2 3 4 5
	           filter:
	TearFree: auto
	load detection: 1
		range: (0, 1)
	audio: auto
	scaling mode: None
	dither: off
		supported: off, on
		range: (0, 128)
		range: (0, 128)
	underscan: off
	coherent: 1
		range: (0, 1)
	link-status: Good
	CONNECTOR_ID: 62
		supported: 62
	non-desktop: 0
		range: (0, 1)
root@devuan:/home/freeartist-devuan# glxinfo -B
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Mesa (0x1002)
    Device: AMD JUNIPER (DRM 2.50.0 / 6.12.90+deb13.1-amd64, LLVM 19.1.7) (0x68b8)
    Version: 25.0.7
    Accelerated: yes
    Video memory: 1024MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 4.5
    Max compat profile version: 4.5
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.1
Memory info (GL_ATI_meminfo):
    VBO free memory - total: 1023 MB, largest block: 1023 MB
    VBO free aux. memory - total: 1021 MB, largest block: 1021 MB
    Texture free memory - total: 1023 MB, largest block: 1023 MB
    Texture free aux. memory - total: 1021 MB, largest block: 1021 MB
    Renderbuffer free memory - total: 1023 MB, largest block: 1023 MB
    Renderbuffer free aux. memory - total: 1021 MB, largest block: 1021 MB
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 1024 MB
    Total available memory: 2045 MB
    Currently available dedicated video memory: 1023 MB
OpenGL vendor string: Mesa
OpenGL renderer string: AMD JUNIPER (DRM 2.50.0 / 6.12.90+deb13.1-amd64, LLVM 19.1.7)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 25.0.7-2
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.5 (Compatibility Profile) Mesa 25.0.7-2
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 25.0.7-2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
smile
pyzNi 3.14zDa! smile
