#1 2026-07-12 15:19:50
mr_sword97
[SOLVED] Network issues
Hi, I got a problem here related to the network and connection. I am completely new to this OS. Once I installed Devuan, everything was fine, Firefox worked fine with no issues, but when I tried to check for updates, it didn't let me connect to the official Devuan repo and I was stuck at 0%. I tried pinging DNS and HTTPS addresses they worked fine but when I tried to ping any HTTP site, it just didn't show up at all. For the clarification, yes I do know that the official repo is HTTP based. I simply need a solution on how do I permit a connection on HTTP sites
#2 2026-07-12 15:35:34
Re: [SOLVED] Network issues
What does "check for updates" mean for you?
Some people would use the command  sequence in a terminal, as root:
# apt-get update
# apt-get -s upgrade
which would report on available package upgrades.
#3 2026-07-12 16:23:55
mr_sword97
I used this:
sudo apt update
Just to check apt package updates
Couldn't connect to http://deb.devuan.org. It showed only this:
0% [Connecting to deb.devuan.org]
And stayed frozen like this, HTTP doesn't work at all
#4 2026-07-12 18:26:28
Hi and welcome to Devuan!
Sometimes DNS issues can interfere with how the default system works, you can usually bypass this by changing /etc/apt/sources.list to use a mirror directly. There is a current list here: https://pkgmaster.devuan.org/mirror_list.txt
Try one that's closest to you and has good bandwidth. In the US I use gnlug, in Europe I hear sledjhamr works good. If you need help modding sources.list let me know.
#5 2026-07-13 09:37:58
Calamity
Yep. A mirror should fix this. I also had problem with the defaults, tried to update and synaptic threw errors at me - switched to sledjhamr and everything worked well since then.
Re-examine all that you have been told. Dismiss that which insults your soul.  - Walt Whitman
Dump shampoo and hair dye
Global Skywatch・Subliminal Manipulation
#6 2026-07-14 03:38:08
mr_sword97
Thanks greenjeans. It actually worked. Changed the mirror to sledjhamr and it worked, for now it is the only mirror I can use with no issues for now.
