#1 2026-07-08 19:23:44
Invisible_Pineapple
[SOLVED] Missing AMD GPU Firmware, *ip_discovery.bin
In my case, I need raven_ip_discovery.bin as per the kernel errors I'm seeing, it tries and fails to find the file and the gpu init has a fatal error as a result and I'm stuck in a pure text terminal with the desktop unable to load.
A search for "ip_discovery" turns up nothing at all on my system, hence the post title. Supposedly this driver is provided by the linux-firmware package, which doesn't appear to exist in the Devuan repositories. By default my system had installed firmware-amd-graphics which is also supposed to provide this driver but evidently doesn't. I also manually installed firmware-linux, firmware-linux-free, and firmware-linux-nonfree. None of them provided this driver. So now I'm not sure what to do short of figuring out how to manually find, download and place that one driver in the system myself and see if that fixes anything.
#2 2026-07-08 19:30:09
Uityyy
Re: [SOLVED] Missing AMD GPU Firmware, *ip_discovery.bin
What are the actual error messages you are seeing?
~ Start theming my apps ~
#3 2026-07-08 19:49:21
It probably would make sense to show the output from
inxi -Fzxr
to get some basic understanding what we are talking about.
inxi may need to be installed first of all.
BTW: I looked into my firmware folder and did not see any "raven_ip_discovery.bin" in there, being on Excalibur.
#4 2026-07-08 20:13:35
Invisible_Pineapple
Here's everything to hopefully save time, system info, the Xorg log file, and the dmesg output grepped for "amdgpu". I did bnotice a possibly new error involving invalid PCI headers in dmesg this time, not sure if that's because I installed the other firmware packages though. Eitgher that or I just missed it, as I am visually impaired,
SYSTEM INFO
[c]System:
  Kernel: 6.12.90+deb13.1-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
    clocksource: tsc
  Console: tty 1 DM: LightDM v: 1.32.0 Distro: Devuan GNU/Linux 6
    (excalibur)
Machine:
  Type: Laptop System: Dell product: Inspiron 5575 v: 1.3.3
    serial: <superuser required> Chassis: type: 10 v: 1.3.3
  Mobo: Dell model: 0DRVH0 v: X01 serial: <superuser required> part-nu: 0812
    uuid: <superuser required> UEFI-[Legacy]: Dell v: 1.3.3 date: 10/31/2019
Battery:
  ID-1: BAT1 charge: 32.4 Wh (100.0%) condition: 32.4/42.0 Wh (77.2%)
    volts: 12.8 min: 11.4 model: Simplo 0x59,0x36,0x42,0x53,0x00,0x00,0x00
    type: Li-ion serial: <filter> status: full
CPU:
  Info: quad core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP smt: enabled arch: Zen rev: 0 cache: L1: 384 KiB
    L2: 2 MiB L3: 4 MiB
  Speed (MHz): avg: 1600 min/max: 1600/2000 boost: enabled cores: 1: 1600
    2: 1600 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31941
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
    / Radeon Mobile Series] vendor: Dell driver: N/A arch: GCN-5 pcie:
    speed: 8 GT/s lanes: 16 bus-ID: 03:00.0 chip-ID: 1002:15dd class-ID: 0300
  Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 0bda:568a class-ID: 0e02
    serial: <filter>
  Display: server: X.org driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: N/A tty: 80x25
  API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
    inactive: gbm,wayland,x11
  API: OpenGL v: 4.5 vendor: mesa v: 25.0.7-2 note: console (EGL sourced)
    renderer: llvmpipe (LLVM 19.1.7 256 bits)
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio vendor: Dell driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
    lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: Dell driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
    bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.90+deb13.1-amd64 status: kernel-api with: apulse
    type: pulse-emulator
  Server-1: PulseAudio v: 17.0 status: off
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: eth0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF: wlan0 state: up mac: <filter>
Bluetooth:
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 3-2.4:5 chip-ID: 0cf3:e009 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 sub-v: 25a hci-v: 8 class-ID: 40010c
Drives:
  Local Storage: total: 931.51 GiB used: 33.62 GiB (3.6%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
    speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM2
    scheme: MBR
Partition:
  ID-1: / size: 30.5 GiB used: 15.31 GiB (50.2%) fs: ext4 dev: /dev/dm-1
    mapped: spellbook--vg-root
  ID-2: /boot size: 942.3 MiB used: 104.9 MiB (11.1%) fs: ext4
    dev: /dev/sda1
  ID-3: /home size: 418.7 GiB used: 18.21 GiB (4.3%) fs: ext4 dev: /dev/dm-3
    mapped: spellbook--vg-home
Swap:
  ID-1: swap-1 type: partition size: 7.64 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-2 mapped: spellbook--vg-swap_1
Sensors:
  System Temperatures: cpu: 65.1 C mobo: 65.0 C
  Fan Speeds (rpm): fan-1: 2700
Repos:
  Packages: 2696 pm: dpkg pkgs: 2689 pm: flatpak pkgs: 7
  Active apt repos in: /etc/apt/sources.list
    1: deb [url]http://ca.deb.devuan.org/merged[/url] excalibur main non-free-firmware
    2: deb-src [url]http://ca.deb.devuan.org/merged[/url] excalibur main non-free-firmware
    3: deb [url]http://ca.deb.devuan.org/merged[/url] excalibur-security main non-free-firmware
    4: deb-src [url]http://ca.deb.devuan.org/merged[/url] excalibur-security main non-free-firmware
    5: deb [url]http://ca.deb.devuan.org/merged[/url] excalibur-updates main non-free-firmware
    6: deb-src [url]http://ca.deb.devuan.org/merged[/url] excalibur-updates main non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/mullvad.list
    1: deb [signed-by=/usr/share/keyrings/mullvad-keyring.asc arch=amd64] [url]https://repository.mullvad.net/deb/stable[/url] stable main
  No active apt repos in: /etc/apt/sources.list.d/steam-beta.list
  Active apt repos in: /etc/apt/sources.list.d/steam-stable.list
    1: deb [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] [url]https://repo.steampowered.com/steam/[/url] stable steam
    2: deb-src [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] [url]https://repo.steampowered.com/steam/[/url] stable steam
  Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.sources
    1: deb [arch=amd64 arm64] [url]https://brave-browser-apt-release.s3.brave.com[/url] stable main
  Active apt repos in: /etc/apt/sources.list.d/xlibre-deb.sources
    1: deb deb-src [arch=amd64] [url]https://xlibre-deb.github.io/devuan/[/url] excalibur main
Info:
  Memory: total: 8 GiB note: est. available: 7.41 GiB used: 546 MiB (7.2%)
  Processes: 227 Power: uptime: 19m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: runit v: N/A runlevel: 2 default: 2
  Compilers: gcc: 14.2.0 Shell: Bash (login) v: 5.2.37 running-in: tty 1
    inxi: 3.3.38
[/c]
XORG LOG FILE
[c][2026-07-04 16:12:09]
XLibre X Server 1.25.0
[2026-07-04 16:12:09] Current Operating System: Linux spellbook 6.12.94+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.94-1 (2026-06-20) x86_64
[2026-07-04 16:12:09] Kernel command line: BOOT_IMAGE=/vmlinuz-6.12.94+deb13-amd64 root=/dev/mapper/spellbook--vg-root ro quiet splash
[2026-07-04 16:12:09] Current version of pixman: 0.44.0
[2026-07-04 16:12:09] 	Before reporting problems, check [url]https://github.com/X11Libre/xserver[/url]
[2026-07-04 16:12:09] Markers: (--) probed, (**) from config file, (==) default setting,
[2026-07-04 16:12:09] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul  4 16:12:09 2026
[2026-07-04 16:12:09] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[2026-07-04 16:12:09] (==) No Layout section.  Using the first Screen section.
[2026-07-04 16:12:09] (==) No screen section available. Using defaults.
[2026-07-04 16:12:09] (**) |-->Screen "Default Screen Section" (0)
[2026-07-04 16:12:09] (**) |   |-->Monitor "<default monitor>"
[2026-07-04 16:12:09] (==) No monitor specified for screen "Default Screen Section".
[2026-07-04 16:12:09] (==) Automatically adding devices
[2026-07-04 16:12:09] (==) Automatically enabling devices
[2026-07-04 16:12:09] (==) Automatically adding GPU devices
[2026-07-04 16:12:09] (==) Automatically binding GPU devices
[2026-07-04 16:12:09] (==) Max clients allowed: 256, resource mask: 0x1fffff
[2026-07-04 16:12:09] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[2026-07-04 16:12:09] 	Entry deleted from font path.
[2026-07-04 16:12:09] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[2026-07-04 16:12:09] (==) ModulePath set to "/usr/lib/xorg/modules"
[2026-07-04 16:12:09] (II) The server relies on udev to provide the list of input devices.
[2026-07-04 16:12:09] (II) Module ABI versions:
[2026-07-04 16:12:09] 	X.Org ANSI C Emulation: 1.4
[2026-07-04 16:12:09] 	X.Org Video Driver: 28.0
[2026-07-04 16:12:09] 	X.Org XInput driver : 26.0
[2026-07-04 16:12:09] 	X.Org Server Extension : 11.0
[2026-07-04 16:12:09] (--) PCI:*(3@0:0:0) 1002:15dd:1028:812 rev 196, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xe0900000/524288, I/O @ 0x1000/256, BIOS @ 0x????????/131072
[2026-07-04 16:12:09] (II) LoadModule: "glx"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/extensions/libglx.so
[2026-07-04 16:12:09] (II) Module glx: vendor="X.Org Foundation"
[2026-07-04 16:12:09] 	compiled for 1.25.0, module version = 1.0.0
[2026-07-04 16:12:09] 	ABI class: X.Org Server Extension, version 11.0
[2026-07-04 16:12:09] (==) Matched ati as autoconfigured driver 0
[2026-07-04 16:12:09] (==) Matched modesetting as autoconfigured driver 1
[2026-07-04 16:12:09] (==) Matched fbdev as autoconfigured driver 2
[2026-07-04 16:12:09] (==) Matched vesa as autoconfigured driver 3
[2026-07-04 16:12:09] (==) Assigned the driver to the xf86ConfigLayout
[2026-07-04 16:12:09] (II) LoadModule: "ati"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[2026-07-04 16:12:09] (II) Module ati: vendor="X.Org Foundation"
[2026-07-04 16:12:09] 	compiled for 1.25.0, module version = 22.0.0
[2026-07-04 16:12:09] 	Module class: X.Org Video Driver
[2026-07-04 16:12:09] 	ABI class: X.Org Video Driver, version 28.0
[2026-07-04 16:12:09] (II) LoadModule: "radeon"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[2026-07-04 16:12:09] (II) Module radeon: vendor="X.Org Foundation"
[2026-07-04 16:12:09] (II) LoadModule: "modesetting"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/drivers/modesetting_drv.so
[2026-07-04 16:12:09] (II) Module modesetting: vendor="X.Org Foundation"
[2026-07-04 16:12:09] 	compiled for 1.25.0, module version = 1.25.0
[2026-07-04 16:12:09] (II) LoadModule: "fbdev"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[2026-07-04 16:12:09] (II) Module fbdev: vendor="X.Org Foundation"
[2026-07-04 16:12:09] 	compiled for 1.25.0, module version = 0.5.1
[2026-07-04 16:12:09] (II) LoadModule: "vesa"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[2026-07-04 16:12:09] (II) Module vesa: vendor="X.Org Foundation"
[2026-07-04 16:12:09] 	compiled for 1.25.0, module version = 2.6.0
[2026-07-04 16:12:09] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[2026-07-04 16:12:09] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[2026-07-04 16:12:09] (II) FBDEV: driver for framebuffer: fbdev
[2026-07-04 16:12:09] (II) VESA: driver for VESA chipsets: vesa
[2026-07-04 16:12:09] (++) using VT number 1[/c]
[c][2026-07-04 16:12:09] (EE) open /dev/dri/card0: No such file or directory
[2026-07-04 16:12:09] (WW) Falling back to old probe method for modesetting
[2026-07-04 16:12:09] (II) Loading sub module "fbdevhw"
[2026-07-04 16:12:09] (II) LoadModule: "fbdevhw"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/libfbdevhw.so
[2026-07-04 16:12:09] (II) Module fbdevhw: vendor="X.Org Foundation"
[2026-07-04 16:12:09] 	compiled for 1.25.0, module version = 0.0.2
[2026-07-04 16:12:09] (EE) Unable to find a valid framebuffer device
[2026-07-04 16:12:09] (WW) Falling back to old probe method for fbdev
[2026-07-04 16:12:09] (EE) open /dev/fb0: No such file or directory
[2026-07-04 16:12:09] (EE) Screen 0 deleted because of no matching config section.
[2026-07-04 16:12:09] (II) UnloadModule: "modesetting"
[2026-07-04 16:12:09] (II) UnloadModule: "fbdev"
[2026-07-04 16:12:09] (II) UnloadSubModule: "fbdevhw"
[2026-07-04 16:12:09] (II) Loading sub module "vbe"
[2026-07-04 16:12:09] (II) LoadModule: "vbe"
[2026-07-04 16:12:09] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/libint10.so
[2026-07-04 16:12:09] (II) Module int10: vendor="X.Org Foundation"
[2026-07-04 16:12:09] (II) Loading sub module "int10"
[2026-07-04 16:12:09] (II) LoadModule: "int10"
[2026-07-04 16:12:09] (II) VESA(0): initializing int10
[2026-07-04 16:12:09] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[2026-07-04 16:12:09] (II) VESA(0): VESA BIOS detected
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE Version 3.0
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE Total Mem: 49152 kB
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE OEM: AMD ATOMBIOS
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE OEM Software Rev: 16.2
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE OEM Vendor: (C) 1988-2010, Advanced Micro Devices, Inc.
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE OEM Product: RAVEN
[2026-07-04 16:12:09] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[2026-07-04 16:12:27] (II) VESA(0): Creating default Display subsection in Screen section
[2026-07-04 16:12:27] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[2026-07-04 16:12:27] (==) VESA(0): RGB weight 888
[2026-07-04 16:12:27] (==) VESA(0): Default visual is TrueColor
[2026-07-04 16:12:27] (==) VESA(0): Using gamma correction (1.00, 1.00, 1.00)
[2026-07-04 16:12:27] (II) Loading sub module "ddc"
[2026-07-04 16:12:27] (II) LoadModule: "ddc"
[2026-07-04 16:12:27] (II) Module "ddc" already built-in
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE DDC supported
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE DDC Level 2
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE DDC read successfully
[2026-07-04 16:12:27] (II) VESA(0): Manufacturer: AUO  Model: 38ed  Serial#: 0
[2026-07-04 16:12:27] (II) VESA(0): Year: 2015  Week: 0
[2026-07-04 16:12:27] (II) VESA(0): EDID Version: 1.4
[2026-07-04 16:12:27] (II) VESA(0): Digital Display Input
[2026-07-04 16:12:27] (II) VESA(0): 6 bits per channel
[2026-07-04 16:12:27] (II) VESA(0): Digital interface is DisplayPort
[2026-07-04 16:12:27] (II) VESA(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[2026-07-04 16:12:27] (II) VESA(0): Gamma: 2.20
[2026-07-04 16:12:27] (II) VESA(0): No DPMS capabilities specified
[2026-07-04 16:12:27] (II) VESA(0): Supported color encodings: RGB 4:4:4
[2026-07-04 16:12:27] (II) VESA(0): First detailed timing is preferred mode
[2026-07-04 16:12:27] (II) VESA(0): Preferred mode is native pixel format and refresh rate
[2026-07-04 16:12:27] (II) VESA(0): redX: 0.58 redY: 0.34   greenX: 0.34 greenY: 0.56
[2026-07-04 16:12:27] (II) VESA(0): blueX: 0.16 blueY: 0.12   whiteX: 0.31 whiteY: 0.33
[2026-07-04 16:12:27] (II) VESA(0): Manufacturer's mask: 0
[2026-07-04 16:12:27] (II) VESA(0): Supported detailed timing:
[2026-07-04 16:12:27] (II) VESA(0): clock: 142.00 MHz   Image Size:  344 x 193 mm
[2026-07-04 16:12:27] (II) VESA(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2100 h_border: 0
[2026-07-04 16:12:27] (II) VESA(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1126 v_border: 0
[2026-07-04 16:12:27] (II) VESA(0): clock: 113.60 MHz   Image Size:  344 x 193 mm
[2026-07-04 16:12:27] (II) VESA(0):  28H80B156HTN
[2026-07-04 16:12:27] (II) VESA(0): Unknown vendor-specific block 0
[2026-07-04 16:12:27] (II) VESA(0): EDID (in hex):
[2026-07-04 16:12:27] (II) VESA(0): 	00ffffffffffff0006afed3800000000
[2026-07-04 16:12:27] (II) VESA(0): 	00190104952213780251259358578f28
[2026-07-04 16:12:27] (II) VESA(0): 	1f505400000001010101010101010101
[2026-07-04 16:12:27] (II) VESA(0): 	010101010101783780b470382e406c30
[2026-07-04 16:12:27] (II) VESA(0): 	aa0058c11000001a602c80b470382e40
[2026-07-04 16:12:27] (II) VESA(0): 	6c30aa0058c11000001a000000fe0032
[2026-07-04 16:12:27] (II) VESA(0): 	38483830804231353648544e00000000
[2026-07-04 16:12:27] (II) VESA(0): 	0000410296001000000a010a20200009
[2026-07-04 16:12:27] (II) VESA(0): EDID vendor "AUO", prod id 14573
[2026-07-04 16:12:27] (II) VESA(0): Printing DDC gathered Modelines:
[2026-07-04 16:12:27] (II) VESA(0): Modeline "1920x1080"x0.00  142.00  1920 2028 2076 2100  1080 1090 1100 1126 +hsync -vsync (67.62 kHz eP)
[2026-07-04 16:12:27] (II) VESA(0): Modeline "1920x1080"x0.00  113.60  1920 2028 2076 2100  1080 1090 1100 1126 +hsync -vsync (54.10 kHz e)
[2026-07-04 16:12:27] (II) VESA(0): Searching for matching VESA mode(s):
[2026-07-04 16:12:27] Mode: 110 (640x480)
[2026-07-04 16:12:27] 	ModeAttributes: 0xbb
[2026-07-04 16:12:27] 	WinAAttributes: 0x7
[2026-07-04 16:12:27] 	WinBAttributes: 0x0
[2026-07-04 16:12:27] 	WinGranularity: 64
[2026-07-04 16:12:27] 	WinSize: 64
[2026-07-04 16:12:27] 	WinASegment: 0xa000
[2026-07-04 16:12:27] 	WinBSegment: 0x0
[2026-07-04 16:12:27] 	WinFuncPtr: 0xc0004cab
[2026-07-04 16:12:27] 	BytesPerScanline: 1280
[2026-07-04 16:12:27] 	XResolution: 640
[2026-07-04 16:12:27] 	YResolution: 480
[2026-07-04 16:12:27] 	XCharSize: 8
[2026-07-04 16:12:27] 	YCharSize: 16
[2026-07-04 16:12:27] 	NumberOfPlanes: 1
[2026-07-04 16:12:27] 	BitsPerPixel: 16
[2026-07-04 16:12:27] 	NumberOfBanks: 1
[2026-07-04 16:12:27] 	MemoryModel: 6
[2026-07-04 16:12:27] 	BankSize: 0
[2026-07-04 16:12:27] 	NumberOfImages: 75
[2026-07-04 16:12:27] 	RedMaskSize: 5
[2026-07-04 16:12:27] 	RedFieldPosition: 10
[2026-07-04 16:12:27] 	GreenMaskSize: 5
[2026-07-04 16:12:27] 	GreenFieldPosition: 5
[2026-07-04 16:12:27] 	BlueMaskSize: 5
[2026-07-04 16:12:27] 	BlueFieldPosition: 0
[2026-07-04 16:12:27] 	RsvdMaskSize: 0
[2026-07-04 16:12:27] 	RsvdFieldPosition: 0
[2026-07-04 16:12:27] 	DirectColorModeInfo: 0
[2026-07-04 16:12:27] 	PhysBasePtr: 0xd0000000
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 1280
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 75
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 75
[2026-07-04 16:12:27] 	LinRedMaskSize: 5
[2026-07-04 16:12:27] 	LinRedFieldPosition: 10
[2026-07-04 16:12:27] 	LinGreenMaskSize: 5
[2026-07-04 16:12:27] 	LinGreenFieldPosition: 5
[2026-07-04 16:12:27] 	LinBlueMaskSize: 5
[2026-07-04 16:12:27] 	LinBlueFieldPosition: 0
[2026-07-04 16:12:27] 	LinRsvdMaskSize: 0
[2026-07-04 16:12:27] 	LinRsvdFieldPosition: 0
[2026-07-04 16:12:27] 	MaxPixelClock: 400000000
[2026-07-04 16:12:27] Mode: 111 (640x480)
[2026-07-04 16:12:27] 	RedFieldPosition: 11
[2026-07-04 16:12:27] 	GreenMaskSize: 6
[2026-07-04 16:12:27] 	LinRedFieldPosition: 11
[2026-07-04 16:12:27] 	LinGreenMaskSize: 6
[2026-07-04 16:12:27] Mode: 113 (800x600)
[2026-07-04 16:12:27] 	BytesPerScanline: 1664
[2026-07-04 16:12:27] 	XResolution: 800
[2026-07-04 16:12:27] 	YResolution: 600
[2026-07-04 16:12:27] 	YCharSize: 14
[2026-07-04 16:12:27] 	NumberOfImages: 47
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 1664
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 47
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 47
[2026-07-04 16:12:27] Mode: 114 (800x600)
[2026-07-04 16:12:27] Mode: 116 (1024x768)
[2026-07-04 16:12:27] 	BytesPerScanline: 2048
[2026-07-04 16:12:27] 	XResolution: 1024
[2026-07-04 16:12:27] 	YResolution: 768
[2026-07-04 16:12:27] 	NumberOfImages: 29
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 2048
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 29
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 29
[2026-07-04 16:12:27] Mode: 117 (1024x768)
[2026-07-04 16:12:27] Mode: 119 (1280x1024)
[2026-07-04 16:12:27] 	BytesPerScanline: 2560
[2026-07-04 16:12:27] 	XResolution: 1280
[2026-07-04 16:12:27] 	YResolution: 1024
[2026-07-04 16:12:27] 	NumberOfImages: 17
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 2560
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 17
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 17
[2026-07-04 16:12:27] Mode: 11a (1280x1024)
[2026-07-04 16:12:27] Mode: 165 (1280x960)
[2026-07-04 16:12:27] 	YResolution: 960
[2026-07-04 16:12:27] 	NumberOfImages: 19
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 19
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 19
[2026-07-04 16:12:27] *Mode: 166 (1280x960)
[2026-07-04 16:12:27] 	BytesPerScanline: 5120
[2026-07-04 16:12:27] 	BitsPerPixel: 32
[2026-07-04 16:12:27] 	NumberOfImages: 9
[2026-07-04 16:12:27] 	RedMaskSize: 8
[2026-07-04 16:12:27] 	RedFieldPosition: 16
[2026-07-04 16:12:27] 	GreenMaskSize: 8
[2026-07-04 16:12:27] 	GreenFieldPosition: 8
[2026-07-04 16:12:27] 	BlueMaskSize: 8
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 5120
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 9
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 9
[2026-07-04 16:12:27] 	LinRedMaskSize: 8
[2026-07-04 16:12:27] 	LinRedFieldPosition: 16
[2026-07-04 16:12:27] 	LinGreenMaskSize: 8
[2026-07-04 16:12:27] 	LinGreenFieldPosition: 8
[2026-07-04 16:12:27] 	LinBlueMaskSize: 8
[2026-07-04 16:12:27] *Mode: 121 (640x480)
[2026-07-04 16:12:27] 	NumberOfImages: 39
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 39
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 39
[2026-07-04 16:12:27] *Mode: 122 (800x600)
[2026-07-04 16:12:27] 	BytesPerScanline: 3328
[2026-07-04 16:12:27] 	NumberOfImages: 23
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 3328
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 23
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 23
[2026-07-04 16:12:27] *Mode: 123 (1024x768)
[2026-07-04 16:12:27] 	BytesPerScanline: 4096
[2026-07-04 16:12:27] 	NumberOfImages: 14
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 4096
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 14
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 14
[2026-07-04 16:12:27] *Mode: 124 (1280x1024)
[2026-07-04 16:12:27] 	NumberOfImages: 8
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 8
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 8
[2026-07-04 16:12:27] Mode: 145 (1400x1050)
[2026-07-04 16:12:27] 	BytesPerScanline: 2816
[2026-07-04 16:12:27] 	XResolution: 1400
[2026-07-04 16:12:27] 	YResolution: 1050
[2026-07-04 16:12:27] 	NumberOfImages: 15
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 2816
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 15
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 15
[2026-07-04 16:12:27] *Mode: 146 (1400x1050)
[2026-07-04 16:12:27] 	BytesPerScanline: 5632
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 5632
[2026-07-04 16:12:27] Mode: 175 (1600x1200)
[2026-07-04 16:12:27] 	ModeAttributes: 0xba
[2026-07-04 16:12:27] 	BytesPerScanline: 3200
[2026-07-04 16:12:27] 	XResolution: 1600
[2026-07-04 16:12:27] 	YResolution: 1200
[2026-07-04 16:12:27] 	NumberOfImages: 12
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 3200
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 12
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 12
[2026-07-04 16:12:27] Mode: 176 (1600x1200)
[2026-07-04 16:12:27] 	BytesPerScanline: 6400
[2026-07-04 16:12:27] 	NumberOfImages: 5
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 6400
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 5
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 5
[2026-07-04 16:12:27] Mode: 1d2 (1920x1080)
[2026-07-04 16:12:27] 	BytesPerScanline: 3840
[2026-07-04 16:12:27] 	XResolution: 1920
[2026-07-04 16:12:27] 	YResolution: 1080
[2026-07-04 16:12:27] 	NumberOfImages: 11
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 3840
[2026-07-04 16:12:27] 	BnkNumberOfImagePages: 11
[2026-07-04 16:12:27] 	LinNumberOfImagePages: 11
[2026-07-04 16:12:27] *Mode: 1d4 (1920x1080)
[2026-07-04 16:12:27] 	BytesPerScanline: 7680
[2026-07-04 16:12:27] 	LinBytesPerScanLine: 7680
[2026-07-04 16:12:27] (II) VESA(0): Total Memory: 768 64KB banks (49152kB)
[2026-07-04 16:12:27] (II) VESA(0): <default monitor>: Using hsync range of 54.10-67.62 kHz
[2026-07-04 16:12:27] (II) VESA(0): <default monitor>: Using vrefresh range of 48.04-60.05 Hz
[2026-07-04 16:12:27] (WW) VESA(0): Unable to estimate virtual size
[2026-07-04 16:12:27] (II) VESA(0): Not using built-in mode "1400x1050" (no mode of this name)
[2026-07-04 16:12:27] (II) VESA(0): Not using built-in mode "1280x1024" (no mode of this name)
[2026-07-04 16:12:27] (II) VESA(0): Not using built-in mode "1280x960" (no mode of this name)
[2026-07-04 16:12:27] (II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
[2026-07-04 16:12:27] (II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
[2026-07-04 16:12:27] (II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
[2026-07-04 16:12:27] (II) VESA(0): Virtual size is 1920x1080 (pitch 1920)
[2026-07-04 16:12:27] (**) VESA(0): *Built-in mode "1920x1080"
[2026-07-04 16:12:27] (**) VESA(0): Display dimensions: (340, 190) mm
[2026-07-04 16:12:27] (**) VESA(0): DPI set to (143, 144)
[2026-07-04 16:12:27] (**) VESA(0): Using "Shadow Framebuffer"
[2026-07-04 16:12:27] (II) Loading sub module "shadow"
[2026-07-04 16:12:27] (II) LoadModule: "shadow"
[2026-07-04 16:12:27] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/libshadow.so
[2026-07-04 16:12:27] (II) Module shadow: vendor="X.Org Foundation"
[2026-07-04 16:12:27] 	compiled for 1.25.0, module version = 1.1.0
[2026-07-04 16:12:27] 	ABI class: X.Org ANSI C Emulation, version 1.4
[2026-07-04 16:12:27] (II) Loading sub module "fb"
[2026-07-04 16:12:27] (II) LoadModule: "fb"
[2026-07-04 16:12:27] (II) Module "fb" already built-in
[2026-07-04 16:12:27] (II) UnloadModule: "radeon"
[2026-07-04 16:12:27] (II) Unloading radeon
[2026-07-04 16:12:27] (II) Loading sub module "int10"
[2026-07-04 16:12:27] (II) LoadModule: "int10"
[2026-07-04 16:12:27] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/libint10.so
[2026-07-04 16:12:27] (II) Module int10: vendor="X.Org Foundation"
[2026-07-04 16:12:27] 	compiled for 1.25.0, module version = 1.0.0
[2026-07-04 16:12:27] 	ABI class: X.Org Video Driver, version 28.0
[2026-07-04 16:12:27] (II) VESA(0): initializing int10
[2026-07-04 16:12:27] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[2026-07-04 16:12:27] (II) VESA(0): VESA BIOS detected
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE Version 3.0
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE Total Mem: 49152 kB
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE OEM: AMD ATOMBIOS
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE OEM Software Rev: 16.2
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE OEM Vendor: (C) 1988-2010, Advanced Micro Devices, Inc.
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE OEM Product: RAVEN
[2026-07-04 16:12:27] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[2026-07-04 16:12:27] (II) VESA(0): virtual address = 0x7fe494800000, VGAbase = 0x7fe497b7f000
	physical address = 0xd0000000, size = 50331648
[2026-07-04 16:12:28] (II) VESA(0): Setting up VESA Mode 0x1d4 (1920x1080)
[2026-07-04 16:12:28] (II) VESA(0): VBESetVBEMode failed, mode set without customized refresh.
[2026-07-04 16:12:28] (==) VESA(0): Default visual is TrueColor
[2026-07-04 16:12:28] (==) VESA(0): Backing store enabled
[2026-07-04 16:12:28] (==) VESA(0): DPMS enabled
[2026-07-04 16:12:28] (II) Output(s) initialized
[2026-07-04 16:12:28] (II) Initializing extension Generic Event Extension
[2026-07-04 16:12:28] (II) Initializing extension SHAPE
[2026-07-04 16:12:28] (II) Initializing extension MIT-SHM
[2026-07-04 16:12:28] (II) Initializing extension XInputExtension
[2026-07-04 16:12:28] (II) Initializing extension XTEST
[2026-07-04 16:12:28] (II) Initializing extension BIG-REQUESTS
[2026-07-04 16:12:28] (II) Initializing extension SYNC
[2026-07-04 16:12:28] (II) Initializing extension XKEYBOARD
[2026-07-04 16:12:28] (II) Initializing extension XC-MISC
[2026-07-04 16:12:28] (II) Initializing extension SECURITY
[2026-07-04 16:12:28] (II) Initializing extension XFIXES
[2026-07-04 16:12:28] (II) Initializing extension RENDER
[2026-07-04 16:12:28] (II) Initializing extension RANDR
[2026-07-04 16:12:28] (II) Initializing extension COMPOSITE
[2026-07-04 16:12:28] (II) Initializing extension DAMAGE
[2026-07-04 16:12:28] (II) Initializing extension MIT-SCREEN-SAVER
[2026-07-04 16:12:28] (II) Initializing extension DOUBLE-BUFFER
[2026-07-04 16:12:28] (II) Initializing extension RECORD
[2026-07-04 16:12:28] (II) Initializing extension DPMS
[2026-07-04 16:12:28] (II) Initializing extension Present
[2026-07-04 16:12:28] (II) Initializing extension DRI3
[2026-07-04 16:12:28] (II) Initializing extension X-Resource
[2026-07-04 16:12:28] (II) Initializing extension XVideo
[2026-07-04 16:12:28] (II) Initializing extension XVideo-MotionCompensation
[2026-07-04 16:12:28] (II) Initializing extension SELinux
[2026-07-04 16:12:28] (II) SELinux: Disabled on system
[2026-07-04 16:12:28] (II) Initializing extension GLX
[2026-07-04 16:12:28] (II) AIGLX: Screen 0 is not DRI2 capable
[2026-07-04 16:12:29] (II) IGLX: Loaded and initialized swrast
[2026-07-04 16:12:29] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[2026-07-04 16:12:29] (II) Initializing extension XFree86-VidModeExtension
[2026-07-04 16:12:29] (II) Initializing extension XFree86-DGA
[2026-07-04 16:12:29] (II) Initializing extension XFree86-DRI
[2026-07-04 16:12:29] (II) Initializing extension DRI2
[2026-07-04 16:12:29] (II) Extensions initialized
[2026-07-04 16:12:29] (II) Screen(s) initialized
[2026-07-04 16:12:29] (II) config/udev: Adding input device Power Button (/dev/input/event10)
[2026-07-04 16:12:29] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:29] (II) LoadModule: "libinput"
[2026-07-04 16:12:29] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[2026-07-04 16:12:30] (II) Module libinput: vendor="X.Org Foundation"
[2026-07-04 16:12:30] 	compiled for 1.25.0, module version = 1.5.0
[2026-07-04 16:12:30] 	Module class: X.Org XInput Driver
[2026-07-04 16:12:30] 	ABI class: X.Org XInput driver, version 26.0
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'Power Button'
[2026-07-04 16:12:30] (**) Power Button: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event10"
[2026-07-04 16:12:30] (II) event10 - Power Button: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event10 - Power Button: device is a keyboard
[2026-07-04 16:12:30] (II) event10 - Power Button: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input14/event10"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[2026-07-04 16:12:30] (**) Option "xkb_model" "pc105"
[2026-07-04 16:12:30] (**) Option "xkb_layout" "us"
[2026-07-04 16:12:30] (II) config/udev: Adding input device Video Bus (/dev/input/event1)
[2026-07-04 16:12:30] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'Video Bus'
[2026-07-04 16:12:30] (**) Video Bus: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event1"
[2026-07-04 16:12:30] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event1  - Video Bus: device is a keyboard
[2026-07-04 16:12:30] (II) event1  - Video Bus: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:00/input/input2/event1"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[2026-07-04 16:12:30] (II) config/udev: Adding input device Power Button (/dev/input/event7)
[2026-07-04 16:12:30] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event7"
[2026-07-04 16:12:30] (II) event7  - Power Button: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event7  - Power Button: device is a keyboard
[2026-07-04 16:12:30] (II) event7  - Power Button: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input11/event7"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[2026-07-04 16:12:30] (II) config/udev: Adding input device Lid Switch (/dev/input/event9)
[2026-07-04 16:12:30] (II) No input driver specified, ignoring this device.
[2026-07-04 16:12:30] (II) This device may have been added with another device file.
[2026-07-04 16:12:30] (II) config/udev: Adding input device Sleep Button (/dev/input/event8)
[2026-07-04 16:12:30] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'Sleep Button'
[2026-07-04 16:12:30] (**) Sleep Button: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event8"
[2026-07-04 16:12:30] (II) event8  - Sleep Button: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event8  - Sleep Button: device is a keyboard
[2026-07-04 16:12:30] (II) event8  - Sleep Button: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input12/event8"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[2026-07-04 16:12:30] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event13)
[2026-07-04 16:12:30] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event14)
[2026-07-04 16:12:30] (II) config/udev: Adding input device HD-Audio Generic Headphone Mic (/dev/input/event15)
[2026-07-04 16:12:30] (II) config/udev: Adding input device DELL0812:00 044E:120A Mouse (/dev/input/event2)
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Mouse: Applying InputClass "libinput pointer catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'DELL0812:00 044E:120A Mouse'
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Mouse: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event2"
[2026-07-04 16:12:30] (II) event2  - DELL0812:00 044E:120A Mouse: is tagged by udev as: Mouse
[2026-07-04 16:12:30] (II) event2  - DELL0812:00 044E:120A Mouse: device is a pointer
[2026-07-04 16:12:30] (II) event2  - DELL0812:00 044E:120A Mouse: device removed
[2026-07-04 16:12:30] (II) libinput: DELL0812:00 044E:120A Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-DELL0812:00/0018:044E:120A.0001/input/input7/event2"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "DELL0812:00 044E:120A Mouse" (type: MOUSE, id 10)
[2026-07-04 16:12:30] (**) Option "AccelerationScheme" "none"
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Mouse: (accel) selected scheme none/0
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Mouse: (accel) acceleration factor: 2.00
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Mouse: (accel) acceleration threshold: 4
[2026-07-04 16:12:30] (II) config/udev: Adding input device DELL0812:00 044E:120A Mouse (/dev/input/mouse0)
[2026-07-04 16:12:30] (II) config/udev: Adding input device DELL0812:00 044E:120A Touchpad (/dev/input/event3)
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: Applying InputClass "libinput touchpad catchall"
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: Applying InputClass "touchpad catchall"
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: Applying InputClass "Default clickpad buttons"
[2026-07-04 16:12:30] (II) LoadModule: "synaptics"
[2026-07-04 16:12:30] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[2026-07-04 16:12:30] (II) Module synaptics: vendor="X.Org Foundation"
[2026-07-04 16:12:30] 	compiled for 1.25.0, module version = 1.10.0
[2026-07-04 16:12:30] (II) Using input driver 'synaptics' for 'DELL0812:00 044E:120A Touchpad'
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event3"
[2026-07-04 16:12:30] (II) synaptics: DELL0812:00 044E:120A Touchpad: found clickpad property
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: x-axis range 0 - 1223 (res 12)
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: y-axis range 0 - 923 (res 12)
[2026-07-04 16:12:30] (II) synaptics: DELL0812:00 044E:120A Touchpad: device does not report pressure, will use touch data.
[2026-07-04 16:12:30] (II) synaptics: DELL0812:00 044E:120A Touchpad: device does not report finger width.
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: buttons: left double triple
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: Vendor 44e Product 120a
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: invalid pressure range.  defaulting to 0 - 255
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: invalid finger width range.  defaulting to 0 - 15
[2026-07-04 16:12:30] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[2026-07-04 16:12:30] (--) synaptics: DELL0812:00 044E:120A Touchpad: touchpad found
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-DELL0812:00/0018:044E:120A.0001/input/input8/event3"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "DELL0812:00 044E:120A Touchpad" (type: TOUCHPAD, id 11)
[2026-07-04 16:12:30] (**) synaptics: DELL0812:00 044E:120A Touchpad: (accel) MinSpeed is now constant deceleration 2.50
[2026-07-04 16:12:30] (**) synaptics: DELL0812:00 044E:120A Touchpad: (accel) MaxSpeed is now 1.75
[2026-07-04 16:12:30] (**) synaptics: DELL0812:00 044E:120A Touchpad: (accel) AccelFactor is now 0.13
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: (accel) keeping acceleration scheme 1
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: (accel) acceleration profile 1
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: (accel) acceleration factor: 2.00
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: (accel) acceleration threshold: 4
[2026-07-04 16:12:30] (II) config/udev: Adding input device DELL0812:00 044E:120A Touchpad (/dev/input/mouse1)
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
[2026-07-04 16:12:30] (II) config/udev: Adding input device DELL0812:00 044E:120A UNKNOWN (/dev/input/event4)
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A UNKNOWN: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'DELL0812:00 044E:120A UNKNOWN'
[2026-07-04 16:12:30] (**) DELL0812:00 044E:120A UNKNOWN: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event4"
[2026-07-04 16:12:30] (II) event4  - DELL0812:00 044E:120A UNKNOWN: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event4  - DELL0812:00 044E:120A UNKNOWN: device is a keyboard
[2026-07-04 16:12:30] (II) event4  - DELL0812:00 044E:120A UNKNOWN: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-DELL0812:00/0018:044E:120A.0001/input/input9/event4"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "DELL0812:00 044E:120A UNKNOWN" (type: KEYBOARD, id 12)
[2026-07-04 16:12:30] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event12)
[2026-07-04 16:12:30] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[2026-07-04 16:12:30] (**) Dell WMI hotkeys: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event12"
[2026-07-04 16:12:30] (II) event12 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event12 - Dell WMI hotkeys: device is a keyboard
[2026-07-04 16:12:30] (II) event12 - Dell WMI hotkeys: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input16/event12"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 13)
[2026-07-04 16:12:30] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[2026-07-04 16:12:30] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[2026-07-04 16:12:30] (**) AT Translated Set 2 keyboard: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event0"
[2026-07-04 16:12:30] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[2026-07-04 16:12:30] (II) event0  - AT Translated Set 2 keyboard: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14)
[2026-07-04 16:12:30] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/event5)
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "libinput touchpad catchall"
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "touchpad catchall"
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "Default clickpad buttons"
[2026-07-04 16:12:30] (II) Using input driver 'synaptics' for 'AlpsPS/2 ALPS GlidePoint'
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event5"
[2026-07-04 16:12:30] (II) synaptics: AlpsPS/2 ALPS GlidePoint: found clickpad property
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: x-axis range 0 - 3200 (res 32)
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: y-axis range 0 - 2304 (res 31)
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: pressure range 0 - 127
[2026-07-04 16:12:30] (II) synaptics: AlpsPS/2 ALPS GlidePoint: device does not report finger width.
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: buttons: left double triple
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: Vendor 2 Product 8
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: invalid finger width range.  defaulting to 0 - 15
[2026-07-04 16:12:30] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input3/event5"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS GlidePoint" (type: TOUCHPAD, id 15)
[2026-07-04 16:12:30] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MinSpeed is now constant deceleration 2.50
[2026-07-04 16:12:30] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MaxSpeed is now 1.75
[2026-07-04 16:12:30] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) AccelFactor is now 0.05
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: (accel) keeping acceleration scheme 1
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration profile 1
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration factor: 2.00
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration threshold: 4
[2026-07-04 16:12:30] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/mouse2)
[2026-07-04 16:12:30] (**) AlpsPS/2 ALPS GlidePoint: Ignoring device from InputClass "touchpad ignore duplicates"
[2026-07-04 16:12:30] (II) config/udev: Adding input device PC Speaker (/dev/input/event16)
[2026-07-04 16:12:30] (II) config/udev: Adding input device Speakup (/dev/input/event6)
[2026-07-04 16:12:30] (**) Speakup: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'Speakup'
[2026-07-04 16:12:30] (**) Speakup: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event6"
[2026-07-04 16:12:30] (II) event6  - Speakup: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event6  - Speakup: device is a keyboard
[2026-07-04 16:12:30] (II) event6  - Speakup: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event6"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "Speakup" (type: KEYBOARD, id 16)
[2026-07-04 16:12:30] (II) config/udev: Adding input device DELL Wireless hotkeys (/dev/input/event11)
[2026-07-04 16:12:30] (**) DELL Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'DELL Wireless hotkeys'
[2026-07-04 16:12:30] (**) DELL Wireless hotkeys: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event11"
[2026-07-04 16:12:30] (II) event11 - DELL Wireless hotkeys: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event11 - DELL Wireless hotkeys: device is a keyboard
[2026-07-04 16:12:30] (II) event11 - DELL Wireless hotkeys: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/virtual/input/input15/event11"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "DELL Wireless hotkeys" (type: KEYBOARD, id 17)
[2026-07-04 16:12:30] (II) config/udev: Adding input device BRLTTY 6.7 Linux Screen Driver Keyboard (/dev/input/event17)
[2026-07-04 16:12:30] (**) BRLTTY 6.7 Linux Screen Driver Keyboard: Applying InputClass "libinput keyboard catchall"
[2026-07-04 16:12:30] (II) Using input driver 'libinput' for 'BRLTTY 6.7 Linux Screen Driver Keyboard'
[2026-07-04 16:12:30] (**) BRLTTY 6.7 Linux Screen Driver Keyboard: always reports core events
[2026-07-04 16:12:30] (**) Option "Device" "/dev/input/event17"
[2026-07-04 16:12:30] (II) event17 - BRLTTY 6.7 Linux Screen Driver Keyboard: is tagged by udev as: Keyboard
[2026-07-04 16:12:30] (II) event17 - BRLTTY 6.7 Linux Screen Driver Keyboard: device is a keyboard
[2026-07-04 16:12:30] (II) event17 - BRLTTY 6.7 Linux Screen Driver Keyboard: device removed
[2026-07-04 16:12:30] (**) Option "config_info" "udev:/sys/devices/virtual/input/input21/event17"
[2026-07-04 16:12:30] (II) XINPUT: Adding extended input device "BRLTTY 6.7 Linux Screen Driver Keyboard" (type: KEYBOARD, id 18)
[2026-07-04 16:12:30] (II) Input(s) initialized
[2026-07-04 16:13:12] (II) event10 - Power Button: device removed
[2026-07-04 16:13:12] (II) event1  - Video Bus: device removed
[2026-07-04 16:13:12] (II) event7  - Power Button: device removed
[2026-07-04 16:13:12] (II) event8  - Sleep Button: device removed
[2026-07-04 16:13:12] (II) event2  - DELL0812:00 044E:120A Mouse: device removed
[2026-07-04 16:13:12] (II) event4  - DELL0812:00 044E:120A UNKNOWN: device removed
[2026-07-04 16:13:12] (II) event12 - Dell WMI hotkeys: device removed
[2026-07-04 16:13:12] (II) event0  - AT Translated Set 2 keyboard: device removed
[2026-07-04 16:13:12] (II) event6  - Speakup: device removed
[2026-07-04 16:13:12] (II) event11 - DELL Wireless hotkeys: device removed
[2026-07-04 16:13:12] (II) event17 - BRLTTY 6.7 Linux Screen Driver Keyboard: device removed
[2026-07-04 16:13:36] (II) VESA(0): Setting up VESA Mode 0x1d4 (1920x1080)
[2026-07-04 16:13:36] Backtrace:
[2026-07-04 16:13:36] unw_get_proc_name failed: no unwind info found [-10]
[2026-07-04 16:13:36] 0: /usr/lib/xorg/Xorg (?+0x0) [0x55dcdfff8c9e]
[2026-07-04 16:13:36] 1: <signal handler called>
[2026-07-04 16:13:36] 2: /lib/x86_64-linux-gnu/libpciaccess.so.0 (?+0x0) [0x7fe49857c1dd]
[2026-07-04 16:13:36] 3: /usr/lib/xorg/modules/xlibre-25.0/libint10.so (?+0x0) [0x7fe497ac801e]
[2026-07-04 16:13:36] 4: /usr/lib/xorg/modules/xlibre-25.0/libint10.so (?+0x0) [0x7fe497acf52c]
[2026-07-04 16:13:36] 5: /usr/lib/xorg/modules/xlibre-25.0/libint10.so (xf86ExecX86int10+0x56) [0x7fe497ac76c6]
[2026-07-04 16:13:36] 6: /usr/lib/xorg/modules/xlibre-25.0/libint10.so (VBESetVBEMode+0x7d) [0x7fe497ac32cd]
[2026-07-04 16:13:36] 7: /usr/lib/xorg/modules/drivers/vesa_drv.so (?+0x0) [0x7fe497ea5390]
[2026-07-04 16:13:36] 8: /usr/lib/xorg/modules/drivers/vesa_drv.so (?+0x0) [0x7fe497ea559b]
[2026-07-04 16:13:36] 9: /usr/lib/xorg/Xorg (?+0x0) [0x55dce001da6b]
[2026-07-04 16:13:36] 10: /usr/lib/xorg/Xorg (?+0x0) [0x55dce0014d01]
[2026-07-04 16:13:36] 11: /usr/lib/xorg/Xorg (?+0x0) [0x55dcdff1a04d]
[2026-07-04 16:13:36] 12: /usr/lib/xorg/Xorg (?+0x0) [0x55dcdfff15c0]
[2026-07-04 16:13:36] 13: /usr/lib/xorg/Xorg (?+0x0) [0x55dcdff14844]
[2026-07-04 16:13:36] 14: /usr/lib/xorg/Xorg (?+0x0) [0x55dcdff195c6]
[2026-07-04 16:13:36] 15: /lib/x86_64-linux-gnu/libc.so.6 (?+0x0) [0x7fe49822aca8]
[2026-07-04 16:13:36] 16: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0x85) [0x7fe49822ad65]
[2026-07-04 16:13:36] 17: /usr/lib/xorg/Xorg (_start+0x21) [0x55dcdfed67c1]
[2026-07-04 16:13:36] Registers at frame #2:
[2026-07-04 16:13:36]   rax: 0xffffffff
[2026-07-04 16:13:36]   rbx: 0x7fe497ae5940
[2026-07-04 16:13:36]   rcx: 0x3244
[2026-07-04 16:13:36]   rdx: 0x1000
[2026-07-04 16:13:36]   rsi: 0x1000
[2026-07-04 16:13:36]   rdi: 0x55dce26fff40
[2026-07-04 16:13:36]   rbp: 0x7fe497ae6160
[2026-07-04 16:13:36]   rsp: 0x7fff69f107d0
[2026-07-04 16:13:36]    r8: 0x7fe497ae6984
[2026-07-04 16:13:36]    r9: 0x0
[2026-07-04 16:13:36]   r10: 0x1fe8
[2026-07-04 16:13:36]   r11: 0x55dce2710f86
[2026-07-04 16:13:36]   r12: 0x55dce270bb70
[2026-07-04 16:13:36]   r13: 0x55dce270d240
[2026-07-04 16:13:36]   r14: 0xb
[2026-07-04 16:13:36]   r15: 0x55dce01473e4
[2026-07-04 16:13:36] Segmentation fault at address 0x0
Fatal server error:
[2026-07-04 16:13:36] Caught signal 11 (Segmentation fault). Server aborting
Please consult the XLibre support
	 at [url]https://github.com/X11Libre/xserver[/url]
 for help.
[2026-07-04 16:13:36] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[/c]
DMESG | GREP AMDGPU
(I noticed a possibly new error near the bottom about PCI headers, don't think I saw that one before)
[c][    0.000000] Command line: BOOT_IMAGE=/vmlinuz-6.12.95+deb13-amd64 root=/dev/mapper/spellbook--vg-root ro quiet splash amdgpu.dpm=0 amdgpu.gpu_recovery=1
[    0.026369] Kernel command line: BOOT_IMAGE=/vmlinuz-6.12.95+deb13-amd64 root=/dev/mapper/spellbook--vg-root ro quiet splash amdgpu.dpm=0 amdgpu.gpu_recovery=1
[   42.039859] amdgpu: Virtual CRAT table created for CPU
[   42.039889] amdgpu: Topology: Add CPU node
[   42.044828] amdgpu 0000:03:00.0: firmware: failed to load amdgpu/raven_ip_discovery.bin (-2)
[   42.046135] amdgpu 0000:03:00.0: firmware: failed to load amdgpu/raven_ip_discovery.bin (-2)
[   42.047411] amdgpu 0000:03:00.0: firmware: failed to load amdgpu/raven_ip_discovery.bin (-2)
[   42.047418] amdgpu 0000:03:00.0: amdgpu: [drm] Optional firmware "amdgpu/raven_ip_discovery.bin" was not found
[   42.184122] amdgpu 0000:03:00.0: Invalid PCI ROM header signature: expecting 0xaa55, got 0xffff
[   42.184127] amdgpu 0000:03:00.0: amdgpu: Unable to locate a BIOS ROM
[   42.184305] amdgpu 0000:03:00.0: amdgpu: Fatal error during GPU init
[   42.184481] amdgpu 0000:03:00.0: amdgpu: amdgpu: finishing device.
[   42.184567] amdgpu 0000:03:00.0: probe with driver amdgpu failed with error -22
[/c]
#5 2026-07-08 20:34:48
Would be nice if you could post these console outputs in code tags, refer to the button labelled code in rectangular brackets above the editor window. Its better readable.
What I see is a discrepancy between the System Info and the real kernel version. I see you are on Excalibur, and you use xlibre instead of xorg.
dmesg says: "Optional firmware "amdgpu/raven_ip_discovery.bin" was not found" which I would read as not required but stops with error. In any case its not part of the amdgpu firmware package which I also have installed.
Also looked at the latest firmware package on kernel.org, there it is included. So it was added sometime between the Excalibur version and June this year. What you may try is to install the firmware-amd-graphics from backports, if there is any.
#6 2026-07-08 20:49:20
@Invisible_Pineapple: PLEASE USE "code" blocks for code ... you know: code  ... not c, but "code" ... it says "code" on the button.
There are two methods to use it, 1) is to click the button to make an emptycode block with the input cursor placed within it and then paste the code you want to pase. 2) is to paste first, then select that pasted text and click the code button which in that case will enclose that selected text.
The code but is the one saying "code".
Now I had to do this for you!! (probably not exactly right)
#7 2026-07-08 20:49:24
Invisible_Pineapple
Oh, the Xorg log was a few days old, I ran startx again to get a new one:
[c][2026-07-08 14:47:13]
[2026-07-08 14:47:13] Current Operating System: Linux spellbook 6.12.95+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.95-1 (2026-07-04) x86_64
[2026-07-08 14:47:13] Kernel command line: BOOT_IMAGE=/vmlinuz-6.12.95+deb13-amd64 root=/dev/mapper/spellbook--vg-root ro quiet splash amdgpu.dpm=0 amdgpu.gpu_recovery=1
[2026-07-08 14:47:13] Current version of pixman: 0.44.0
[2026-07-08 14:47:13] 	Before reporting problems, check [url]https://github.com/X11Libre/xserver[/url]
[2026-07-08 14:47:13] Markers: (--) probed, (**) from config file, (==) default setting,
[2026-07-08 14:47:13] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul  8 14:47:13 2026
[2026-07-08 14:47:13] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[2026-07-08 14:47:13] (==) No Layout section.  Using the first Screen section.
[2026-07-08 14:47:13] (==) No screen section available. Using defaults.
[2026-07-08 14:47:13] (**) |-->Screen "Default Screen Section" (0)
[2026-07-08 14:47:13] (**) |   |-->Monitor "<default monitor>"
[2026-07-08 14:47:13] (==) No monitor specified for screen "Default Screen Section".
[2026-07-08 14:47:13] (==) Automatically adding devices
[2026-07-08 14:47:13] (==) Automatically enabling devices
[2026-07-08 14:47:13] (==) Automatically adding GPU devices
[2026-07-08 14:47:13] (==) Automatically binding GPU devices
[2026-07-08 14:47:13] (==) Max clients allowed: 256, resource mask: 0x1fffff
[2026-07-08 14:47:13] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[2026-07-08 14:47:13] 	Entry deleted from font path.
[2026-07-08 14:47:13] (==) FontPath set to:
	built-ins
[2026-07-08 14:47:13] (==) ModulePath set to "/usr/lib/xorg/modules"
[2026-07-08 14:47:13] (II) The server relies on udev to provide the list of input devices.
[2026-07-08 14:47:13] (II) Module ABI versions:
[2026-07-08 14:47:13] 	X.Org ANSI C Emulation: 1.4
[2026-07-08 14:47:13] 	X.Org Video Driver: 28.0
[2026-07-08 14:47:13] 	X.Org XInput driver : 26.0
[2026-07-08 14:47:13] 	X.Org Server Extension : 11.0
[2026-07-08 14:47:13] (--) PCI:*(3@0:0:0) 1002:15dd:1028:812 rev 196, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xe0900000/524288, I/O @ 0x1000/256, BIOS @ 0x????????/131072
[2026-07-08 14:47:13] (II) LoadModule: "glx"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/extensions/libglx.so
[2026-07-08 14:47:13] (II) Module glx: vendor="X.Org Foundation"
[2026-07-08 14:47:13] 	compiled for 1.25.0, module version = 1.0.0
[2026-07-08 14:47:13] 	ABI class: X.Org Server Extension, version 11.0
[2026-07-08 14:47:13] (==) Matched ati as autoconfigured driver 0
[2026-07-08 14:47:13] (==) Matched modesetting as autoconfigured driver 1
[2026-07-08 14:47:13] (==) Matched fbdev as autoconfigured driver 2
[2026-07-08 14:47:13] (==) Matched vesa as autoconfigured driver 3
[2026-07-08 14:47:13] (==) Assigned the driver to the xf86ConfigLayout
[2026-07-08 14:47:13] (II) LoadModule: "ati"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[2026-07-08 14:47:13] (II) Module ati: vendor="X.Org Foundation"
[2026-07-08 14:47:13] 	compiled for 1.25.0, module version = 22.0.0
[2026-07-08 14:47:13] 	Module class: X.Org Video Driver
[2026-07-08 14:47:13] 	ABI class: X.Org Video Driver, version 28.0
[2026-07-08 14:47:13] (II) LoadModule: "radeon"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[2026-07-08 14:47:13] (II) Module radeon: vendor="X.Org Foundation"
[2026-07-08 14:47:13] (II) LoadModule: "modesetting"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/drivers/modesetting_drv.so
[2026-07-08 14:47:13] (II) Module modesetting: vendor="X.Org Foundation"
[2026-07-08 14:47:13] 	compiled for 1.25.0, module version = 1.25.0
[2026-07-08 14:47:13] (II) LoadModule: "fbdev"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[2026-07-08 14:47:13] (II) Module fbdev: vendor="X.Org Foundation"
[2026-07-08 14:47:13] 	compiled for 1.25.0, module version = 0.5.1
[2026-07-08 14:47:13] (II) LoadModule: "vesa"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[2026-07-08 14:47:13] (II) Module vesa: vendor="X.Org Foundation"
[2026-07-08 14:47:13] 	compiled for 1.25.0, module version = 2.6.0
[2026-07-08 14:47:13] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
[2026-07-08 14:47:13] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[2026-07-08 14:47:13] (II) FBDEV: driver for framebuffer: fbdev
[2026-07-08 14:47:13] (II) VESA: driver for VESA chipsets: vesa
[2026-07-08 14:47:13] (++) using VT number 1[/c]
[c][2026-07-08 14:47:13] (EE) open /dev/dri/card0: No such file or directory
[2026-07-08 14:47:13] (WW) Falling back to old probe method for modesetting
[2026-07-08 14:47:13] (II) Loading sub module "fbdevhw"
[2026-07-08 14:47:13] (II) LoadModule: "fbdevhw"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/libfbdevhw.so
[2026-07-08 14:47:13] (II) Module fbdevhw: vendor="X.Org Foundation"
[2026-07-08 14:47:13] 	compiled for 1.25.0, module version = 0.0.2
[2026-07-08 14:47:13] (EE) Unable to find a valid framebuffer device
[2026-07-08 14:47:13] (WW) Falling back to old probe method for fbdev
[2026-07-08 14:47:13] (EE) open /dev/fb0: No such file or directory
[2026-07-08 14:47:13] (EE) Screen 0 deleted because of no matching config section.
[2026-07-08 14:47:13] (II) UnloadModule: "modesetting"
[2026-07-08 14:47:13] (II) UnloadModule: "fbdev"
[2026-07-08 14:47:13] (II) UnloadSubModule: "fbdevhw"
[2026-07-08 14:47:13] (II) Loading sub module "vbe"
[2026-07-08 14:47:13] (II) LoadModule: "vbe"
[2026-07-08 14:47:13] (II) Loading /usr/lib/xorg/modules/xlibre-25.0/libint10.so
[2026-07-08 14:47:13] (II) Module int10: vendor="X.Org Foundation"
[2026-07-08 14:47:13] (II) Loading sub module "int10"
[2026-07-08 14:47:13] (II) LoadModule: "int10"
[2026-07-08 14:47:13] (II) VESA(0): initializing int10
[2026-07-08 14:47:13] (EE) VESA(0): No V_BIOS found
[2026-07-08 14:47:13] (II) UnloadModule: "vesa"
[2026-07-08 14:47:13] (II) UnloadSubModule: "int10"
[2026-07-08 14:47:13] (II) Unloading int10
[2026-07-08 14:47:13] (EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
[2026-07-08 14:47:13] no screens found
 for help.
[2026-07-08 14:47:13] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[2026-07-08 14:47:13] (EE) Server terminated with error (1). Closing log file.
[/c]
#8 2026-07-08 20:52:52
Re: [SOLVED] Missing AMD GPU Firmware, *ip_discovery.bin
Next one will be deleted.
#9 2026-07-08 20:55:07
Invisible_Pineapple
Oh okay sorry, I didn't see the code thing before, or your replies about it before posting the updated Xorg log, I'll do the proper code block from now on.
#10 2026-07-08 20:58:53
ovi
As I see xlibre has its own driver for AMD Radeon GPUs:
https://github.com/X11Libre/xf86-video-amdgpu
Xlibre driver for AMD Radeon GPUs using the amdgpu kernel driver
I also have an AMD GPU and I don't have such a file. I am running wayland, but I think it doesn't matter.
#11 2026-07-08 21:06:36
Invisible_Pineapple
Okay, thanks guys, I guess I have more things to look into now. I'm using the unofficial Devuan Xlibre repository for the moment because I figured it'd make it easier, maybe it didn't.
#12 2026-07-08 21:19:05
Invisible_Pineapple
Oh, and I generated a new system info since the other one was done before I updated today, Which is probably why the kernel versions were different. Dunno if it'll help but it's now in a proper code block!
inxi -Fxrz
System:
  Kernel: 6.12.95+deb13-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
  Console: tty 1 Distro: Devuan GNU/Linux 6 (excalibur)
Machine:
  Type: Laptop System: Dell product: Inspiron 5575 v: 1.3.3
    serial: <superuser required>
  Mobo: Dell model: 0DRVH0 v: X01 serial: <superuser required>
    UEFI-[Legacy]: Dell v: 1.3.3 date: 10/31/2019
Battery:
  ID-1: BAT1 charge: 32.4 Wh (100.0%) condition: 32.4/42.0 Wh (77.2%)
    volts: 12.9 min: 11.4 model: Simplo 0x59,0x36,0x42,0x53,0x00,0x00,0x00
    status: full
CPU:
  Info: quad core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP arch: Zen rev: 0 cache: L1: 384 KiB L2: 2 MiB
    L3: 4 MiB
  Speed (MHz): avg: 1600 min/max: 1600/2000 boost: enabled cores: 1: 1600
    2: 1600 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31940
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
    / Radeon Mobile Series] vendor: Dell driver: N/A arch: GCN-5
    bus-ID: 03:00.0
  Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB
    bus-ID: 1-4:2
  Display: server: X.org driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: N/A tty: 80x25
  API: EGL v: 1.5 drivers: swrast platforms: active: surfaceless,device
    inactive: gbm,wayland,x11
  API: OpenGL v: 4.5 vendor: mesa v: 25.0.7-2 note: console (EGL sourced)
    renderer: llvmpipe (LLVM 19.1.7 256 bits)
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xdriinfo,
    xdpyinfo, xprop, xrandr
Audio:
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 03:00.1
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 03:00.6
  API: ALSA v: k6.12.95+deb13-amd64 status: kernel-api
  Server-1: PulseAudio v: 17.0 status: off
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0
  IF: eth0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 02:00.0
  IF: wlan0 state: up mac: <filter>
Bluetooth:
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB bus-ID: 3-2.4:5
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8
Drives:
  Local Storage: total: 931.51 GiB used: 34.98 GiB (3.8%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
Partition:
  ID-1: / size: 30.5 GiB used: 16.67 GiB (54.7%) fs: ext4 dev: /dev/dm-1
    mapped: spellbook--vg-root
  ID-2: /boot size: 942.3 MiB used: 106.8 MiB (11.3%) fs: ext4
    dev: /dev/sda1
  ID-3: /home size: 418.7 GiB used: 18.21 GiB (4.3%) fs: ext4 dev: /dev/dm-3
    mapped: spellbook--vg-home
Swap:
  ID-1: swap-1 type: partition size: 7.64 GiB used: 0 KiB (0.0%)
    dev: /dev/dm-2 mapped: spellbook--vg-swap_1
Sensors:
  System Temperatures: cpu: 72.9 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2700
Repos:
  Packages: 2752
  Active apt repos in: /etc/apt/sources.list
    1: deb http://ca.deb.devuan.org/merged excalibur main non-free-firmware
    2: deb-src http://ca.deb.devuan.org/merged excalibur main non-free-firmware
    3: deb http://ca.deb.devuan.org/merged excalibur-security main non-free-firmware
    4: deb-src http://ca.deb.devuan.org/merged excalibur-security main non-free-firmware
    5: deb http://ca.deb.devuan.org/merged excalibur-updates main non-free-firmware
    6: deb-src http://ca.deb.devuan.org/merged excalibur-updates main non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/mullvad.list
    1: deb [signed-by=/usr/share/keyrings/mullvad-keyring.asc arch=amd64] https://repository.mullvad.net/deb/stable stable main
  No active apt repos in: /etc/apt/sources.list.d/steam-beta.list
  Active apt repos in: /etc/apt/sources.list.d/steam-stable.list
    1: deb [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] https://repo.steampowered.com/steam/ stable steam
    2: deb-src [arch=amd64,i386 signed-by=/usr/share/keyrings/steam.gpg] https://repo.steampowered.com/steam/ stable steam
  Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.sources
    1: deb [arch=amd64 arm64] https://brave-browser-apt-release.s3.brave.com stable main
  Active apt repos in: /etc/apt/sources.list.d/xlibre-deb.sources
    1: deb deb-src [arch=amd64] https://xlibre-deb.github.io/devuan/ excalibur main
Info:
  Memory: total: 8 GiB note: est. available: 7.41 GiB used: 649.3 MiB (8.6%)
  Processes: 222 Uptime: 36m Init: runit runlevel: 2
  Compilers: gcc: 14.2.0 Shell: Bash v: 5.2.37 inxi: 3.3.38
#13 2026-07-08 21:21:59
ovi
I tried also XLibre with OpenBox. And I found after installation a weird mouse cursor. Then I found that it was reported as bug. I think is still a young project. Probably is nice to run, but not on a main machine. I am running Wayland with labwc and I kind of like it. Despite some or other says, Wayland shows some improvements compared with X11. Is still have some limitations, that's true also.
#14 2026-07-08 21:38:55
Invisible_Pineapple
I use a screen reader for lots of stuff and from what I understand that means Wayland isn't an option.
#15 2026-07-08 21:46:49
Uityyy
I use XLibre on Excalibur too (but with an NVidia card), and I recall that NexusSFan's instructions for setting it up involve enabling backports. I don't know exactly what went wrong here, but if I had to guess I would guess it has something to do with upgrading to drivers from backports, and I would check if something along the lines of the following helps:
sudo dpkg-reconfigure firmware-amd-graphics
sudo update-initramfs -u
sudo reboot
If that sort of fiddling doesn't solve the issue for you, and you want to continue using XLibre, then you might consider asking over on their Matrix/Telegram if anyone there has insights. I haven't seen anyone else report this exact behaviour there yet.
~ Start theming my apps ~
#16 2026-07-08 22:11:04
Invisible_Pineapple
Not a bad idea, I tried what you said but it did nothing. When I was still on Devuan 5 everything worked perfectly, but since upgrading it doesn't. Only on the laptop though the desktop running the same stuff runs perfectly with no issues at all. Curiously, sometimes the laptop boots into the desktop just fine and everything works like it should. No idea why, but that's pretty rare.
#17 2026-07-08 22:48:26
Invisible_Pineapple
Okay, update. I added backports to my apt sources list, installed the firmware-amd-graphics package from that. That got rid of the missing raven_ip_discovery.bin error, however the PCI error still persists and it still won't load into the desktop. Which means the invalid PCI header thing must be the real issue and I must have not seen it before. Now I gotta figure out why that's happening.
#18 2026-07-08 23:27:26
Invisible_Pineapple
Since the driver pat of this issue is solved, and that's what the thread title is about, I'm going to mark this as solved and make another thread about the pci signature error. Tl;dr, add backports to your apt sources list and you can get the drivers.
