#1 2026-07-07 09:40:26
WEBDEVDESTROYER2000
[SOLVED] Failed to check for processor microcode upgrades(x86_64)
.$$$$$`    Uptime: 2 hours, 29 mins
                         ;$$$$$P    Packages: 2359 (dpkg), 6 (flatpak)
                      .:P$$$$$$`    Shell: bash 5.2.37
                  .,:b$$$$$$$;'     Display (CMN1388): 1920x1080 @ 60 Hz in 13" [Built-in]   .,:dP$$$$$$$$b:'
      .,:;db$$$$$$$$$$Pd'`          DE: Xfce4 4.20
,db$$$$$$$$$$$$$$b:'`              WM: Xfwm4 (X11)
:$$$$$$$$$$$$b:'`                   WM Theme: Clearlooks-Phenix-Sapphire
`$$$$$bd:''`                       Theme: Clearlooks-Phenix-Sapphire [GTK2/3/4]
   `'''`                            Icons: Deepsea [GTK2/3/4]
                                    Font: Sans (10pt) [GTK2/3/4]
                                    Cursor: DMZ-White
                                    Terminal: xfce4-terminal 1.1.4
                                    Terminal Font: CodeNewRoman Nerd Font Mono (12pt)
                                    CPU: Intel(R) Core(TM) i5-1035G1 (8) @ 3.60 GHz
                                    GPU: Intel Iris Plus Graphics G1 (Ice Lake) @ 1.05 GHz [Integrated]
                                    Memory: 2.45 GiB / 7.44 GiB (33%)
                                    Swap: 0 B / 7.67 GiB (0%)
                                    Disk (/): 15.57 GiB / 225.18 GiB (7%) - ext4
                                    Local IP (wlan0): 192.168.1.135/24
                                    Battery (UX325): 90% (2 hours, 56 mins remaining) [Discharging]
                                    Locale: en_US.UTF-8
How to fix?
Hi, I'm a beginner programmer who's into web development!
I'm learning PHP as my first programming language.
<?php
echo "I love PHP!"
#2 2026-07-07 09:41:00
WEBDEVDESTROYER2000
Re: [SOLVED] Failed to check for processor microcode upgrades(x86_64)
lscpu output:
Architecture:                x86_64
  CPU op-mode(s):            32-bit, 64-bit
  Address sizes:             39 bits physical, 48 bits virtual
  Byte Order:                Little Endian
CPU(s):                      8
  On-line CPU(s) list:       0-7
Vendor ID:                   GenuineIntel
  Model name:                Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz
    CPU family:              6
    Model:                   126
    Thread(s) per core:      2
    Core(s) per socket:      4
    Socket(s):               1
    Stepping:                5
    CPU(s) scaling MHz:      28%
    CPU max MHz:             3600.0000
    CPU min MHz:             400.0000
    BogoMIPS:                2380.80
    Flags:                   fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pg
                             e mca cmov pat pse36 clflush dts acpi mmx fxsr sse
                             sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm cons
                             tant_tsc art arch_perfmon pebs bts rep_good nopl xt
                             opology nonstop_tsc cpuid aperfmperf tsc_known_freq
                              pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ss
                             se3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2ap
                             ic movbe popcnt tsc_deadline_timer aes xsave avx f1
                             6c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb
                              ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flex
                             priority ept vpid ept_ad fsgsbase tsc_adjust bmi1 a
                             vx2 smep bmi2 erms invpcid avx512f avx512dq rdseed
                             adx smap avx512ifma clflushopt intel_pt avx512cd sh
                             a_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsav
                             es split_lock_detect dtherm ida arat pln pts hwp hw
                             p_notify hwp_act_window hwp_epp hwp_pkg_req vnmi av
                             x512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpcl
                             mulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq r
                             dpid fsrm md_clear flush_l1d arch_capabilities
Virtualization features:
  Virtualization:            VT-x
Caches (sum of all):
  L1d:                       192 KiB (4 instances)
  L1i:                       128 KiB (4 instances)
  L2:                        2 MiB (4 instances)
  L3:                        6 MiB (1 instance)
NUMA:
  NUMA node(s):              1
  NUMA node0 CPU(s):         0-7
Vulnerabilities:
  Gather data sampling:      Vulnerable: No microcode
  Indirect target selection: Mitigation; Aligned branch/return thunks
  Itlb multihit:             KVM: Mitigation: Split huge pages
  L1tf:                      Not affected
  Mds:                       Not affected
  Meltdown:                  Not affected
  Mmio stale data:           Vulnerable: Clear CPU buffers attempted, no microco
                             de; SMT vulnerable
  Reg file data sampling:    Not affected
  Retbleed:                  Mitigation; Enhanced IBRS
  Spec rstack overflow:      Not affected
  Spec store bypass:         Mitigation; Speculative Store Bypass disabled via p
                             rctl
  Spectre v1:                Mitigation; usercopy/swapgs barriers and __user poi
                             nter sanitization
  Spectre v2:                Mitigation; Enhanced / Automatic IBRS; IBPB conditi
                             onal; PBRSB-eIBRS SW sequence; BHI SW loop, KVM SW
                             loop
  Srbds:                     Vulnerable: No microcode
  Tsa:                       Not affected
  Tsx async abort:           Not affected
  Vmscape:                   Not affected
<?php
echo "I love PHP!"
#3 2026-07-07 10:00:35
Please use code blocks for "code".
#4 2026-07-07 13:36:37
kapqa
funnily was about to post a similar topic than "destroyer"
have encountered this both on amd and intel computer, the software says
spec_store_bypass: Mitigation of SSB disabled via prctl
thought this might have caused myself since i had "secure boot" or similar in place, but disabled afterwards for some reason currently unknown.
here is the output for the intel computer; for amd it is similar;
OPERATING SYSTEM:       Devuan 6
    Kernel:               6.12.95+deb13-amd64 (x86_64)
    Display Server:       X Server 1.21.1.16
    Compiler:             GCC 14.2.0
    Security:             gather_data_sampling: Not affected
                          + indirect_target_selection: Not affected
                          + itlb_multihit: KVM: Mitigation of VMX unsupported
                          + l1tf: Mitigation of PTE Inversion
                          + mds: Vulnerable: Clear buffers attempted no microcode; SMT vulnerable
                          + meltdown: Mitigation of PTI
                          + mmio_stale_data: Unknown: No mitigations
                          + reg_file_data_sampling: Not affected
                          + retbleed: Not affected
                          + spec_rstack_overflow: Not affected
                          [b]+ spec_store_bypass: Mitigation of SSB disabled via prctl  [/b]
                          + spectre_v1: Mitigation of usercopy/swapgs barriers and __user pointer sanitization
                          + spectre_v2: Mitigation of Retpolines; IBPB: conditional; IBRS_FW; STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
                          + srbds: Not affected
                          + tsa: Not affected
                          + tsx_async_abort: Not affected
                          + vmscape: Mitigation of IBPB before exit userspace
#5 2026-07-07 19:38:21
This is just a guess, but maybe...
apt install intel-microcode
or if one had amd hardware...
apt install amd64-microcode
But like I said, that's a guess. I could be way off-base. Maybe I don't really know what the question is.
#6 2026-07-07 19:52:50
kapqa
sure , maybe the destroyer will let you know,
in the meantime, applied the "intel-microcode" , rebooted ;
small changes , but probably still inherently unsafe to run the said hardware /
                          + mds: Mitigation of Clear buffers; SMT vulnerable
                          + tsa: Not affected
#7 2026-07-08 18:05:00
WEBDEVDESTROYER2000
I simply installed the intel-microcode package. That was easy. But I searched online, and I'm amazed from how little info there is about this issue.
<?php
echo "I love PHP!"
#8 2026-07-08 20:26:12
kapqa
for fairness sake,
this is a quite a newer computer, with cpu from amd
whereis amd64-microcode
amd64-microcode:
 OPERATING SYSTEM:       Linuxmint 22.3
    Kernel:               6.17.0-35-generic (x86_64)
    Display Server:       X Server 1.21.1.11
    Compiler:             GCC 13.3.0
                          + ghostwrite: Not affected
                          + itlb_multihit: Not affected
                          + l1tf: Not affected
                          + mds: Not affected
                          + meltdown: Not affected
                          + mmio_stale_data: Not affected
                          + old_microcode: Not affected
                          + spec_rstack_overflow: Mitigation of IBPB on VMEXIT only
                          + spectre_v2: Mitigation of Enhanced / Automatic IBRS; IBPB: conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
                          + tsa: Not affected
                          + vmscape: Mitigation of IBPB on VMEXIT
not all software made easy.
#9 2026-07-09 07:01:02
WEBDEVDESTROYER2000
There is an amd64 microcode package. I reckon that you should install it. Sorry if I made a mistake, I don't have the best knowledge of hardware and firmware.
<?php
echo "I love PHP!"
