#1 2026-07-02 14:32:17
safari
How to set system time?
My system time is out. How do I fix that? hwclock, timedatectl, and ntp aren't available.
#2 2026-07-02 14:42:10
kapqa
Re: How to set system time?
sudo apt install ntpsec-ntpdate
is valid for devuan 6.0
sudo ntpdate-debian
2026-07-02 16:39:31.356971 (+0200) +0.170255 +/- 0.010254 0.debian.pool.ntp.org 37.247.53.178 s2 no-leap
but with dual-boot windows + linux there is still woes, at least on computers that i use.
#3 2026-07-02 14:54:14
safari
Thanks, that worked. Do you know if that sets OS time only, or hardware time too?
#4 2026-07-02 15:15:12
kapqa
would have to guess, but apparently i am able to mess up the time every other time i boot into windows and back , or so ~
there have been kind peopel on this forum who told me how to fix  time with windows tricks ]
but those have tricks not lasted that long also use several computer , and what function on one, seem not always stable on another. . it has probably to do aswell with the computers itself; and maybe also language, regional settings may interfere?
maybe some day we can get to to the bottom of it.
#5 2026-07-02 18:00:19
kapqa
i think the confusion stems also from the fact that during installation i set "language: englsish"
but i live somehwere else, and i am however constrained to select a region that has "english mapping" and hence everything goes tupsy turvy;
this is probably a limitating on the lclassic debian-inux installer.
#6 2026-07-02 19:27:02
ntp sets the HW clock. The rest is job of the operating system.
In Linux its standard to set the HW re. the bios clock to UTC. During installation you configure your location and timezone, and the OS then generates the local time from that.
Windows per default is running on local time, i.e. the bios clock is set to local time. This creates 2h time shifts on a Linux/Windows dual boot system. The best fix is to set Windows to UTC.
#7 2026-07-03 04:20:01
FM81
As fas as I know it doesn't. (And I'm not sure, if this was changed with ntpsec?)
NTP sets the systemtime only ...
If NTP would be depending on the HW-clock, how should it work with devices (e.g. singleborad-computers) without any such?
Best Regards, FM81
The most brilliant role in comedy is that of a fool, he must not be in order to make it seem. (Miguel de Cervantes)
#8 2026-07-03 05:49:45
RedGreen925
It has to do with windows always setting the system clock to local time. Most Linux installs default to Universal Time, the UTC method o doing it. A .reg file download to make the required change.
https://www.howtogeek.com/wp-content/up … C-Time.zip
From this page.
https://www.howtogeek.com/323390/how-to … l-booting/
#9 2026-07-03 11:21:47
I does indirectly. When I shut down my PC the HW clock is updated. ntp and ntpsec are the same.
I am pretty sure any device supporting a clock has a RTC on board.
#10 2026-07-03 12:12:33
FM81
In SYSVINIT this is done by /etc/init.d/hwclock.sh for example. But it works independent of what your systemtime was set.
It does it's job too, if there is no NTP or if you've changed your systemtime manually.
For example, Raspberry, at least up to models 4 (didn't know about 5) doesn't have a RTC. ("fake-hwclock" here is not the same)
But independent from all said before, you can go the way "vice versa" and set some type of hardware-vlock (for example DCF77, GPS or what ever) as source for NTP.
Greetings, FM81
#11 2026-07-04 21:37:36
ovi
To maintain accuracy of your system's clock you can use "chrony". It will enable also a dedicated service.
If you run only Devuan is enough to install the "chrony" package.
If you are dual-boot with Windows it's recommended to have both system set to UTC time. Windows does not use UTC by default, and if you are dual-booting, this will conflict with Devuan.  That's why the installer will see that you have Windows installed and will set the time as Windows to local time.
To  make the system time to UTC in Windows just download and run the registry file that RedGreen925 suggested.
In Devuan do this:
Check if the system time is set to UTC or not:
$ cat /etc/adjtime
Marks the hardware clock standard as UTC in Devuan and verify
$ sudo hwclock --systohc --utc
$ cat /etc/adjtime
Force chrony to  re-sync:
sudo chronyc makestep
#12 2026-07-05 01:15:35
abower
The kernel will set the hwclock itself if a time-keeper is running successfully.
All you needed to do was install ntpsec.
ntpsec-ntpdate is for single-shot use: that was wrong advice.
Yes, chrony will also work, but you don't need to switch software family to get this behaviour.
#13 2026-07-05 17:40:17
wert
my laptop's battery and BIOS battery both died.
I have to set date/time after every boot manually. i done it via 'date -s ...'
i do it manually because i dont want internet connected services set it automatically. eh my taste.
when date/time is wrong most sites refuses my connection attemps.
#14 2026-07-07 02:51:07
These days I set my motherboard to UTC, and use the world clock to set my time.
But when I used to struggle with it, the time changing from boot to boot, I used hwclock to make the system time hardware time and visa-vis.
Set the Hardware Clock to the current System Time.
# hwclock --systohc
Set the System Time from the Hardware Clock.
# hwclock --hctosys
# hwclock --set --date="8:20:05"
Check out hwclock --help for more info.
#15 2026-07-09 11:59:22
kapqa
Current default time zone: 'Europe/Rome'
Local time is now:      Thu Jul  9 13:45:59 CEST 2026.
Universal Time is now:  Thu Jul  9 11:45:59 UTC 2026.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
think the .reg file trick shared by Mr. RedGreen925 is very helpful;
it functioned on 1 computer that i use here quite reliably; however, it takes the windows machine about a half or minute or so to adjust; but otherwise it seem to function; but probably, it needs an internet connection to function.
where i live the UTC "universal" time seem not so much off, so i am not at odds with it;
very mjuch more so with the "current local time" which is affront, so calld "DST" "ora legale" "Sommerzeit" etc ~
basically in small room can get 3 different times depending on where i watch ~
TV gives me like                   07.39 (UTC)
my smartwatch on wrist        08.39 (local-time) > since have the wrist-watch not synced for along time.
radio-clock in kitchen-space 09-39 (local-"summer"-time) > the stupid does "align" itself via radio probably
the local-time is most true to the sun since it probaly 15min ahead of loca-tun-time~
and UTC is probably 45min behind suntime ~
whereas the "summer-time" "day-light-saving-time" if full 75minutes "ahead" of sun and a real bummer so doing my best to ignore it ~ but since it is ~ "legal" time, well, not fully to ignore, but thats for another topic.
it would be nice to set the time in BIOS, and that could be it.
#16 2026-07-26 09:24:15
Kiergan
*Glomp* Another package consumed.
"The classic ntp package has been removed in Debian 13 (Trixie).
Debian 13+ using systemd-timesyncd, which is already pre-installed and requires no additional packages. This is sufficient for the guide's use case (client-only time sync) and has a smaller attack surface since it doesn't listen on any port."
Installing:
  ntpsec-ntpdate
Installing dependencies:
libpython3-stdlib  libpython3.13-minimal  libpython3.13-stdlib  ntpsec-ntpdig  python3  python3-minimal  python3-ntp  python3.13  python3.13-minimal
Did ntp need all those python-packages before too?
#17 2026-07-26 15:56:11
FM81
If I remember correct, it doesn't. I dont have any install-logs anymore, but if I do
ldd /usr/local/sbin/ntpd
or
ldd /usr/local/bin/ntpq
I see no dependencies to python at all.
[irony]
Seems we live in a linux world, where nothing works anymore without python (or equal complex things).
[/irony]
Best regards, FM_81
