#1 2026-07-01 19:20:12
kapqa
[SOLVED] upgrade to Excalibure partly succesful
Hello ,
hvae updated another box to latest Devuan 6.0
this time however incurred some  rrproblems, now there is string of errors and i am not
sure if it save to remove those packages.
the issue most likely arose after updating i did run "sudo tasksel" and let remove "cinnamon" and install "mate" instead;
the "xfce" was already installed and running;
now there are some error still
like
sudo apt -f install
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
  7 not fully installed or removed.
  Space needed: 0 B / 37.3 GB available
dpkg: dependency problems prevent configuration of libpam-elogind:amd64:
 libpam-elogind:i386 (255.17-2) breaks libpam-systemd and is installed.
  libpam-elogind:amd64 (255.17-2) provides libpam-systemd.
dpkg: error processing package libpam-elogind:amd64 (--configure):
dpkg: dependency problems prevent configuration of network-manager:
 network-manager depends on default-logind | logind; however:
  Package default-logind is not installed.
  Package libpam-elogind:amd64 which provides default-logind is not configured y
et.
  Package logind is not installed.
  Package libpam-elogind:amd64 which provides logind is not configured yet.
dpkg: error processing package network-manager (--configure):
dpkg: dependency problems prevent configuration of nm-connection-editor:
 nm-connection-editor depends on network-manager; however:
  Package network-manager is not configured yet.
dpkg: error processing package nm-connection-editor (--configure):
dpkg: dependency problems prevent configuration of network-manager-applet:
 network-manager-applet depends on nm-connection-editor (= 1.36.0-3+b1); however
  Package nm-connection-editor is not configured yet.
 network-manager-applet depends on network-manager; however:
dpkg: error processing package network-manager-applet (--configure):
dpkg: dependency problems prevent configuration of libpolkit-qt5-1-1:amd64:
 libpolkit-qt5-1-1:amd64 depends on default-logind | logind; however:
et.
dpkg: error processing package libpolkit-qt5-1-1:amd64 (--configure):
dpkg: dependency problems prevent configuration of udisks2:
 udisks2 depends on default-logind | logind; however:
et.
dpkg: error processing package udisks2 (--configure):
dpkg: dependency problems prevent configuration of kdiskmark:
 kdiskmark depends on libpolkit-qt5-1-1 (>= 0.112.0); however:
  Package libpolkit-qt5-1-1:amd64 is not configured yet.
dpkg: error processing package kdiskmark (--configure):
 network-manager
 udisks2
 kdiskmark
Error: Sub-process /usr/bin/dpkg returned an error code (1)
is this "libpam-elogind:amd64" needed or ccan i safely remove§?
have already removed the :i386 version of it or elogind only;
would like to clear up and continue with the OS since it function well;
thank you.
#2 2026-07-01 19:23:08
kapqa
Re: [SOLVED] upgrade to Excalibure partly succesful
sudo apt install logind
Package logind is a virtual package provided by:
  libpam-elogind 255.17-2
  dummy-logind 255.17-2
You should explicitly select one to install.
Error: Package 'logind' has no installation candidate
sudo apt install libpam-elogind
libpam-elogind is already the newest version (255.17-2).
libpam-elogind set to manually installed.
Summary:
Continue? [Y/n]
et.
et.
et.
 network-manager
 udisks2
 kdiskmark
#3 2026-07-01 19:30:07
kapqa
now i have install "dummy-logind" and it seemed to go through (tasksel > mate-desktop) however at the end there was still error
sudo apt upgrade
Summary:
  2 not fully installed or removed.
  Space needed: 0 B / 37.0 GB available
Continue? [Y/n]
 libpam-elogind:i386 (255.17-2) breaks libpam-systemd and is unpacked but not co
nfigured.
dpkg: dependency problems prevent configuration of libpam-elogind:i386:
 libpam-elogind:amd64 (255.17-2) breaks libpam-systemd and is unpacked but not c
onfigured.
  libpam-elogind:i386 (255.17-2) provides libpam-systemd.
dpkg: error processing package libpam-elogind:i386 (--configure):
 libpam-elogind:i386
afterwards
Summary:
  14 not fully installed or removed.
Continue? [Y/n]
et.
et.
dpkg: dependency problems prevent configuration of gvfs-daemons:
 gvfs-daemons depends on udisks2; however:
  Package udisks2 is not configured yet.
dpkg: error processing package gvfs-daemons (--configure):
dpkg: dependency problems prevent configuration of gvfs-backends:
 gvfs-backends depends on gvfs-daemons (= 1.57.2-2+deb13u1); however:
  Package gvfs-daemons is not configured yet.
dpkg: error processing package gvfs-backends (--configure):
dpkg: dependency problems prevent configuration of gvfs:amd64:
 gvfs:amd64 depends on gvfs-daemons (<< 1.57.2-2+deb13u1.1~); however:
 gvfs:amd64 depends on gvfs-daemons (>= 1.57.2-2+deb13u1); however:
dpkg: error processing package gvfs:amd64 (--configure):
dpkg: dependency problems prevent configuration of mate-desktop-environment-core
 mate-desktop-environment-core depends on gvfs-backends; however:
  Package gvfs-backends is not configured yet.
dpkg: error processing package mate-desktop-environment-core (--configure):
dpkg: dependency problems prevent configuration of caja:
 caja depends on gvfs; however:
  Package gvfs:amd64 is not configured yet.
dpkg: error processing package caja (--configure):
dpkg: dependency problems prevent configuration of mate-desktop-environment:
 mate-desktop-environment depends on mate-desktop-environment-core (= 1.26.0+2);
 however:
  Package mate-desktop-environment-core is not configured yet.
dpkg: error processing package mate-desktop-environment (--configure):
dpkg: dependency problems prevent configuration of task-mate-desktop:
 task-mate-desktop depends on mate-desktop-environment; however:
  Package mate-desktop-environment is not configured yet.
dpkg: error processing package task-mate-desktop (--configure):
dpkg: dependency problems prevent configuration of gvfs-fuse:
 gvfs-fuse depends on gvfs (= 1.57.2-2+deb13u1); however:
dpkg: error processing package gvfs-fuse (--configure):
dpkg: dependency problems prevent configuration of mate-applets:
 mate-applets depends on gvfs; however:
dpkg: error processing package mate-applets (--configure):
 network-manager
 udisks2
 gvfs-daemons
 gvfs-backends
 gvfs:amd64
 caja
 task-mate-desktop
 gvfs-fuse
 mate-applets
#4 2026-07-02 10:51:25
This is what I have for programs with logind in the name after a recent upgrade to excalibur. Make sure you have all of these.
$ dpkg -l | grep logind
ii  elogind                                   255.17-2                                     amd64        user, seat and session management daemon
ii  libelogind-compat:amd64                   255.17-2                                     amd64        user, seat and session management library compatibility
ii  libelogind0:amd64                         255.17-2                                     amd64        user, seat and session management library
ii  libpam-elogind:amd64                      255.17-2                                     amd64        elogind PAM module
ii  libpolkit-gobject-elogind-1-0:amd64       126-2devuan1+excalibur1                      amd64        polkit Authorization API
