Excrypted Excalibur with Cinnamon DE, static wired network defined in /etc/network/interfaces, no network manager used.
With increasing frequency it looks like the network is no more available after hibernation. How can I easily reset the network w/o rebooting?
~$ inxi -Fxzr
System:
Kernel: 6.12.94+deb13-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
Desktop: Cinnamon v: 6.4.10 Distro: Devuan GNU/Linux 6 (excalibur)
Machine:
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5031
date: 01/13/2025
CPU:
Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+
rev: 2 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M /
Pro 5500M] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1
bus-ID: 0c:00.0
Display: x11 server: X.Org v: 21.1.16 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
resolution: 2560x1440~60Hz
Network:
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: f000 bus-ID: 06:00.0
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Swap:
ID-1: swap-1 type: partition size: 183.11 GiB used: 0 KiB (0.0%)
dev: /dev/dm-2 mapped: vg--exc--sys-2_swap
Sensors:
System Temperatures: cpu: 39.0 C mobo: 43.0 C gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Repos:
Packages: 1837
Active apt repos in: /etc/apt/sources.list.d/signal-xenial.list
1: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.sources
1: deb [arch=amd64] https://brave-browser-apt-release.s3.brave.com stable main
Active apt repos in: /etc/apt/sources.list.d/devuan.sources
1: deb http://deb.devuan.org/merged/ excalibur excalibur-security excalibur-updates excalibur-backports main contrib non-free non-free-firmware
Info:
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 5.56 GiB (8.9%)
Processes: 590 Uptime: 4h 21m Init: SysVinit runlevel: 2
Compilers: gcc: 14.2.0 Shell: Bash v: 5.2.37 inxi: 3.3.38Online
hello rolfie,
i used this trick on a Optiplex that used to have not network manager after a software update ~
this has functioned reliably, glad i found it.
sudo dhclient -r eth0
sudo dhclient eth0https://unix.stackexchange.com/question … -not-found
had this problem today that i nedded/wanted to install packages from devuan repository via recovery-mode
but was surprised that the recovery-mode did not find any network connection;
since i knew of this trick here, wanted to remedy via
dhclient eth0only to find out that dhclient is not/no longer included by default (it seems even abandoned according to linked post above).
however, it would be very good if it could be included by default as paackage in devuan-netinstall and iso. to allow for exactly such situations to easily be mended.
my proposal hence to include the package that includes dhclient into devuan.iso for failsafe & debug network issues.
isc-dhcp-clientis the package in question.
thank you very much.
