#1 2026-06-29 01:22:19
grunchy
Xorg devuan forks
i just did an update and two Xorg packages were included: xserver-common and xserver-xorg-core
all the X11 packages i have installed (devuan excalibur, kde) are maintained by debian (Debian X Strike Force) except for the two packages above, which are forked by devuan (Maintainer: Devuan Developers).
does anybody know why these two packages need to be forked?
is debian adding systemd hooks into these packages?
are these packages already systemd-ised when debian gets them?
this is not causing any problem, just curious.
#2 2026-06-29 07:13:46
blackhole
Re: Xorg devuan forks
There seems to be a dependency for xserver-xorg-core on "libsystemd0".
Not sure what the issue was with xserver-common.
#3 2026-06-29 10:48:30
They were forked so as to add seatd as alterantive to logind for device mediation.
#4 2026-06-29 16:10:38
grunchy
thanks for this. good to know it is not directly systemd related. binding X11 to systemd did not make any sense to me, but i forgot about [e]logind.
i wonder, will the same mod be made to the xlibre packages?
#5 2026-06-29 17:39:10
There are xlibre packages that are especially made for Devuan.
#6 2026-06-29 18:43:22
seatd support was added to xlibre a few months ago. I made a freia test live iso with seatd and without elogind or consolekit. Also there's no display manager. Use 'startx' to get a graphical session.
https://get.refracta.org/files/experime … 4_1517.iso
login: user, password: user
root password is root
