#1 2026-06-17 17:25:09
amaro
request for a new Zettelkasten assistant
Hello everybody,
I found a new note-taking package (for using the Zettelkasten method) and would like to ask to have it added to the repos. It's called 'zk'.
zk is a plain text note-taking assistant that leverages the power of the command line.
https://zk-org.github.io/zk/
I know that we have 'vimwiki' in the repos but this one is better.
Thank you in advance!
#2 2026-06-17 20:57:57
Re: request for a new Zettelkasten assistant
amaro wrote:
... new note-taking package ...
... added to the repos. It's called 'zk'.
zk is not available in the official Debian repositories, which is the reason for it not being in the Devuan repositories.
If and when it gets included in the Debian repositories and has no 'unfixable' dependencies on systemd, you will find it after a few days in the Devuan repositories.
Until then, you (most probably) have the option of building it from source.
