#1 2026-06-04 15:32:05
Gateway Neural Amp Modeler
Testing a linux port of Gateway VST3 by Steven Atkinson. iPlug2, the framework used by the original plugin, does not currently support Linux. Gateway is a Linux port built using JUCE
You can find it here https://sourceforge.net/projects/namix/  and the code here https://github.com/rations/NAMix
@Ralf Did you know that github is a Microsoft site? Yes. And that there are many FOSS alternatives one can use instead? Yes.
Some of my projects are on codeberg and given I use chat bots I don't use devuans git, I put it on github because it's ai slop.
edit updated img
galaxy test
SOURCEFORGE rations
#2 2026-06-04 19:38:43
JWM-Kit
Re: Gateway Neural Amp Modeler
This looks awesome! I'll have to check it out when I manage to find the time.
#3 2026-06-05 03:41:17
Looks nice! Thank you for the tip!
#4 2026-06-05 08:33:51
Fixed bugs, improved the look and added standalone version
SOURCEFORGE rations
#5 2026-06-05 14:45:30
kapqa
#6 2026-06-05 15:20:49
Holy cow that's gorgeous!
#7 2026-06-06 13:51:57
That look is taken from the original. Nam also supports bass not just guitar, it's a great open source project. You can find the nam files and captures here
https://www.tone3000.com/
I built version 0.3.0 on daedalus so it should work on any distro with glibc 2.35 or later
SOURCEFORGE rations
#8 2026-06-12 04:12:22
Reached out to the creator Steven, he asked if I don't use the name gateway and focused on NAM. So renamed it to NAMix.
Rebuilt version 0.4.0 is here https://sourceforge.net/projects/namix/ code is here https://github.com/rations/NAMix
Standalone
SOURCEFORGE rations
