#1 2026-06-04 01:53:21
Red_Fir
[SOLVED] Unintended reboot
My Dell 9020 reboots on every shutdown  unless I explicitly hit the power button after shutdown since install of Devuan 6.
This is a multiboot machine running Artix an Salix, too.
It did not do this with Devuan 5, nor does it do it with the other distro's
I have gone through the bios and ensured every restart, or timed boot is disabled.
I usually shut it down during the week, and leave it running over the weekend to save wear on a hard drive
{sudo halt} will shut it down cleanly
Any ideas on how to address this?
#2 2026-06-04 09:38:10
kapqa
Re: [SOLVED] Unintended reboot
did you try to disable "fast boot"?
did you try to set BIOS do "default settings"?
is it a laptop or deksotp pc? ~ modern latop can have strange behaviours , also "thanks" to "internal" batteries.
EDIT: had a similar issue on a desktop if remember correctly; in my case it was the mouse that was causing "wakeup" calls unintendedly and made the desktop turn-on even if supposedly it wws turned off; changing to another mouse solvedt e issue.
#3 2026-06-04 09:38:37
pcalvert
What is the output produced by this command?:
apt show intel-microcode
Another one is called Luxxle.
#4 2026-06-04 11:11:33
Red_Fir wrote:
... Dell 9020 reboots on every shutdown unless I explicitly hit the power button after shutdown ...
I have had a similar issue with my Sun U24 WS for years, fortunately it is not at every shutdown but just when the %$#"¿ crap BIOS feels like it.
I have found that it occurs when there are sharp changes in ambient temperature between booting and shutting down, most probably due to a badly written BIOS + a faulty/wrong on-board sensor spec, so it is an issue I decided to ignore.
That said, yours seems to be a well known issue with that Dell rig.
A quick web search with the unsolicited Google IA intervention (?) brought up this*:
Google search wrote:
If your Dell OptiPlex 9020 is randomly rebooting on Linux, it is usually triggered by a kernel panic upon hardware conflict, failing storage, or power supply issues.
* to be taken with a few grains of salt. 8^°
See here.
If sudo halt works, you may want to write up a script to shut it down via sudo halt && sudo shutdown -now.
Check the respective man files for the proper syntax.
#5 2026-06-05 00:41:35
Red_Fir
$ apt show intel-microcode
Package: intel-microcode
Version: 3.20251111.1~deb13u1
#6 2026-06-05 20:49:41
pcalvert
I'm sorry, I should have asked you this instead:
aptitude show intel-microcode
Note: If aptitude is not installed, please install it first.
#7 2026-06-07 00:47:29
Red_Fir
State: not installed
Priority: standard
I will give it a whirl
