#1 2026-05-20 23:28:24
grunchy
[SOLVED] MAC change and eudev
had to replace my motherboard yesterday and as a result the computer's MAC address changed.
as a result of the MAC change the computer could no longer connect to the LAN. ifup would fail as the DHCP broadcast failed. digging around i 'found' the file /etc/udev/rules.d/70-persistent-net.rules  where the MAC was hardcoded. manually editing this file, replacing the old MAC with the new MAC, then rebooting fixed the problem.
in the 70-persistent-net.rues file is mentions that it was generated by /lib/udev/write_net_rules. found a mention in stack-exchange (i know, i know) that it was possible to re-generate this file with this command-line
# export INTERFACE=eth0; export MATCHADDR="xx:xx:xx:xx:xx:xx"; /lib/udev/write_net_rules
did not try this as a manual edit worked, but it left me curious. what is the recommended way to update this file when the MAC changes?
#2 2026-05-21 00:40:15
viptux
Re: [SOLVED] MAC change and eudev
Interesting.. can also be set from the base network stanza.. either of the two eth0 iface option examples below should work.
# cat /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet dhcp
      hwaddress ether 11:22:33:44:55:66
      pre-up ip link set dev eth0 address 11:22:33:44:55:66
Regards
#3 2026-05-21 00:54:09
That /etc/network/interface block would be used to assign the MAC address, wherease the UDEV rule is a condition to only apply for the given MAC address.
Another way to change that udev rules file is by removing it and reboot.
#4 2026-05-21 06:54:19
PedroReina
This has been my course of action every time I've been in this situation (a lot of them).
#5 2026-05-21 17:29:26
grunchy
ok. this is satisfyingly simple.
thanks
