#1 2026-05-19 20:21:14
thes3pt3mb3r
[SOLVED] Socket file found at socket path /run/seatd.sock, refusing to start
Command 'ls -l' on /etc/seatd* showed that /run/seatd.sock is  owned by root  and  video group. User is in video group,yet I still get 'Socket file found at socket path /run/seatd.sock, refusing to start' after running 'seatd-launch dwl'. That message is not really telling me much.
#2 2026-05-19 22:22:19
Re: [SOLVED] Socket file found at socket path /run/seatd.sock, refusing to start
Presumably it means that there is a seatd running that uses that socket pathname.
#3 2026-05-20 07:06:24
thes3pt3mb3r
Yes,I know this much but the problem is that this message shows and compositor does not start.
#4 2026-05-20 10:33:43
Why do you want to use the command seatd-launch dwl.
Is seatd running already?
Is there a dwl running already?
#5 2026-05-20 14:30:59
thes3pt3mb3r
Sorry,It was my mistake becouse I have always used seatd like that and did not check 'dwl' by itself.
