#1 2026-05-19 17:07:53
F_Sauce
alsa_out
Hello everyone.
Simple question, is the «alsa_out» command/feature removed in Excalibur?
Cheers,
Olav
I'm on Devuan with KDE
#2 2026-05-19 22:09:38
Re: alsa_out
Try using https://pkginfo.devuan.org though with the (too subtile?) "File:" search variant.
(There is a hint about that on its fromt page.)
#3 2026-05-20 15:51:00
F_Sauce
Re: alsa_out
Thanks for answering.
I think I understood, hence the search wasn't exactly too sublime.
I'm trying too have browsers use JACK as sound-server, this, using alsa_out, was one approach I was exploring.
#4 2026-05-20 16:39:55
Re: alsa_out
I've used this in the past as /etc/asoundrc to get firefox to use jack. Haven't tried it lately.
pcm.!default {
    type plug
    slave { pcm "jack" }
pcm.jack {
    type jack
    playback_ports {
        0 system:playback_1
        1 system:playback_2
    capture_ports {
        0 system:capture_1
        1 system:capture_2
ctl.mixer0 {
    type hw
    card 0
#5 2026-05-20 19:20:36
F_Sauce
Re: alsa_out
Thank you!
I will look into that.
I have 'fumbled around' «.asoundrc» quite a bit earlier, and I have absolutely not comprehended it all.
Thanks,
Olav
PS
Browser are but one thing, I need to reassure the functionality as a whole smile
