#1 2026-05-19 14:19:52
jrico
libncurses5
I need libncurses5 to install Vivado.  Is there a "Devuan" way to install an old library?  Thanks.
#2 2026-05-19 19:15:03
kapqa
Re: libncurses5
have needed this sometime for "erformancetest"
not sure if this still applies but the trick  was like this
taken from performance-test forums (passmark)
sudo ln -s /usr/lib/x86_64-linux-gnu/libncurses.so.6 /usr/lib/x86_64-linux-gnu/libncurses.so.5
#3 2026-05-19 21:58:22
Re: libncurses5
libncurses5 is found in daedalus/main.
Assuming you are now on excalibur, one option is to add the old repository sources to your sources.list, e.g., by adding the following lines:
deb http://deb.devuan.org/merged daedalus main
deb http://deb.devuan.org/merged daedalus-security main
Then run
# apt-get upate aupdate
# apt-get install --no-install-recommends libncurses5
to get it installed (without including any "recommends" for it).
hth
#4 2026-05-20 09:39:36
jrico
Re: libncurses5
Thanks for the help.  Vivadio nstalled after installing libcurses5.
