#1 2026-04-24 15:20:40
DaveT
Fun and games with UPnP servers on Arm64 Raspberry Pi
I'm running devuan Arm64 on a Kunbus Raspberry Pi industrial computer.
It's job is to be a server for my hifi system.
After 15 years I waved godbye to Sonos and moved on to a Cambridge Audio CXN100 media player. Because 'reasons'.
The Cambridge Audio CXN100 cannot work with samba - Richer Sounds lied to me is all I have to say!
It needs a UPnP media server.
OK, they exist, let's go to it...
1) gerbera
easy install, terrible documentation on setting up the gerbera.conf file. ALL of the documentation is bad.
With a bit of faffing it was sort of running but the Web GUI would NOT work. No way to add the audio fiiles into the sqlite database it uses.
Searching turned up no useful info.
I purged it.
2) minidlna
easy install. very little to modify in minidlna.conf.
Works!
Logs some FLAC errors but we are looking good.
The Cambridge One StreamMagic app seems happy and away we go!
Except. Some folders are empty. Why? No-one knows. Very little info on fixing issues.
If I can't fix the 'No Content' problem in the Captain Beefheart directories then another purge is coming on!
I did meet him in the early 1980s. Met Winged Eel fingerling too. Very gentle soft-spoken man.
I suppose I might not be clever enough to follow obscure documentation, but if I can't get it to work then it is useless to me.
Watch this space for how it all turns out!
#2 2026-04-24 16:08:50
Re: Fun and games with UPnP servers on Arm64 Raspberry Pi
Tagging for updates! Always interested in getting good music up and running wink
#3 2026-04-28 08:03:45
DaveT
For completeness: The Kunbus I am using is based on a Raspberry Pi 3.
I installed minidlna on my OpenBSD laptop.
The results were much the same - many albums missing, but the logging is much better!
Both the Kunbus and OpenBSD got to about 3500 FLAC files before they gave up.
OpenBSD minidlna.conf allows 4096 open files. I didn't try to increase that number.
If you don't have thousands and thousands of media files or just want to play with UPnP servers to try it out then minidlna is ideal.
Small, light, very little in the way of setup. It really does 'just work'.
But not well enough for me!
So I purged it.
#4 2026-04-28 08:14:42
DaveT
That brings us to Jellyfin at jellyfin.org.
They have a debian version in their repository.
The online documentation is good.
I installed the 'extrepo' script and let it do its' thing.
The actual jellyfin install went without problems.
It expects to be stopped and started by systemd.
Hmm, what to do?
github.com/Labna/jellyfin-sysvinit
fixed that!
Jellyfin is mainly controlled using its comprehensive web interface.
I did that from my OpenBSD laptop.
It is taking hours to scan the external 500GB USB drive...
I left it running overnight, it had got to 87% this morning and I am certain it has crashed!
Some investigation to do then.
Possibly, just possibly, a Raspberry Pi 3 isn't quite up to running Jellyfin... We'll see!
#5 2026-04-28 12:40:26
DaveT
Yes Jellyfin crashed at 87% because it ran out of memory.
However, load of albums were there in the web interface and tracks could be played hrough my laptop speakers.
Jellyfin works on a Raspberry Pi 3, I quite like it, and I hope to get running as it should.
So I created a 1GB /swapfile and restarted jellyfin which is tootling along nicely if a bit slow because of having to use the swapfile.
If you can, get a Raspberry Pi with as much RAM as possible if you want to run Jellyfin!
Mine has 905MB of available RAM and is using 808MB of swap.
Permissions for external USB drives can be a pain. Adding this line in /etc/fstab solved that!
UUID=Your-USB-drive  /mnt/Verbatim   vfat    defaults,noatime,users,umask=000,rw,auto 0 0
I'm using a 500GB Verbatim USB drive for my media files. I mount it on /mnt feel free to bung it somewhere else.
Because of the 500+ albums and 6000+ tracks I'm not sure of an easy way to work out if anything is missing.
#6 2026-04-28 13:50:16
DaveT
Jellyfin is serving audio to my laptop.
But does it work with the Cambridge Audio CXN100 Network media player?
No.
What?
It's a feature!
DNLA capability for Jellyfin has been removed from the base install and is now a Plugin.
In the web interface click on Plugins.
The page opens up and shows what is installed.
Click on Available.
Scroll down to DNLA and click on it.
It works! First time use is a lot slow. Might speed up for 2nd etc use.
Not a really bad problem if the interface is slow, just a bit tedious. Nothing money and a more powerful Raspberry Pi won't fix!
I am generally pleased with how things have worked out.
Jellyfin has found all the album art etc. I could do with something better than an old iPhone to control it now!
#7 2026-04-28 17:28:50
DaveT
The DNLA plugin has known problems.
It doesn't find all the music files.
For example my Artist list stops at 'Sex Pistols' and so doesn't show 'Soft Machine' or 'Stockhausen Karlheinz'.
There is much chatter on the forums. The DLNA Plugin is believed to be the problem not Jellyfin.
I can see me going back to just plugging the USB drive into the Cambridge Audio CXN100.
Or using another Raspberry PI with a DAC to play audio via Jellyfin... and sell the CXN100 player on ebay!
#8 2026-05-02 11:57:18
DaveT
Edited all previous posts in this thread to change the Cambridge Audio player to the CXN100.
#9 2026-05-02 12:08:55
DaveT
Jellyfin can 'Cast' the media to the Cambridge Audio CXN100!
That means instead of trying to work with fat fingers on a tiny iPhone screen that doesn't show everything I can control it from my laptop complete with album artwork.
Niggles: the dnla doesn't want to show some artists whose names begin with TUVWXYZ,
Thelonious Monk is there but not Zoot Horn Rollo.
But the 'We Saw A Bozo Under The Sea' album by Zoot Horn Rollo is there!
I'm still trying to make sure everything is there sooo...
Anyway, Jellyfin is a definite 9 out of 10 from me.
#10 2026-05-13 11:35:37
DaveT
UPDATE: while you might think your media library is OK and works properly because you can play it on various devices as I have been doing for many years be aware that the Media Streamers and players likeJellyfin and minidlna etc are VERY picky about the metadata for the files being correct!
There are a number of 'TAG' editors available, most work with just about any media format you care to mention. Some do mp3 etc but not FLAC.
Kid3 is unpleasant to use IMHO, I deleted it.
MusicBrainz Picard is slightly clunky in how you select files and I can find no way to unselect files. I just exit and then start it up again and move onto the next files I need to faff with! Seems powerful and good though. It refused to have anything to do with two Tangerine Dream tracks from the ripped Cyclone CD. Said the size the file claimed it was and the size it actually was were different. fsck on the external USB drive didn't fix it so I am ripping the CD again!
#11 2026-06-01 17:15:16
DaveT
3 weeks of faffing about later...
Jellyfin likes multi-CD albums to be inside one directory, not a directory for each disc.
So Tangerine Dream The Virgin Years is handled best by Jellyfin with all of the tracks inside the  'Virgin Years' Directory and NOT 'Virgin years Disc1' etc.
ALL discs are found as far as I can tell but not all Artists.
So 'We Saw A Bozo Under The Sea' is there but does not appear under Zoot Horn Rollo in Artists. No Artist appears after Terry Riley with 'In C'.
I took to working on just Tangerine Dream until I got it the way I wanted it - namely as the 5 albums Phaedra Cyclone Rubycon Ricochet Stratosfear. I used MusicBrainz Picard to change the album from The Virgin Years to Phaedra etc. I did it on my MacBook Pro running Devuan Ceres because it is a lot faster than the Kunbus with its little Raspberry Pi!
Once I know everything is as it should be the USB drive will get transferred to the Kunbus, and Plan A is to copy the Jellyfin databases over to the Kunbus rather than do a slow re-scan.
I did a full backup of all the audio files and then formatted the USB drive to ext4. I'm working alphabetically backwards as I load up the USB drive so I can spot exactly where things go wrong and fix it. Zoot Horn Rollo is there!
