#1 2026-04-18 21:43:19
grunchy
[SOLVED] openvpn 2.7.1 and excalibur
openvpn 2.7.1 is now available in ceres repo. i want to try out this new version on my excalibur desktop, but am unsure how to go about this.
first question: once version 2.7 makes it to freia will it ever be back-ported?
relatedly, is there a way to check which packages are in the process of being back-ported?
second question: is there a best-practice for adding a single package from testing to stable?
my initial thought is to download the .deb and install via dpkg -i, overwriting the installed openvpn files. i would prefer to keep the existing version, 2.6.14-1+deb13u1devuan, and have the version 2.7 openvpn as a second option. is that doable?
#2 2026-04-18 22:07:48
abower
Re: [SOLVED] openvpn 2.7.1 and excalibur
The Freia version of openvpn is already backported to Excalibur-backports:
https://backports.debian.org/trixie-backports/overview/
To add the backports repository:
https://www.devuan.org/os/packages#add- … default-no
And to install the package:
https://dev1galaxy.org/viewtopic.php?pid=27079#p27079
#3 2026-04-18 22:30:51
You can setup your system to allow hand-picked packages from ceres, by a) pinning ceres packages to something less than 100 and then merely include ceres in your sources.
The pinning would be a file named, say, reluctant-ceres in /etc/apt/preferences.d/ with perhaps the foolwing content:
Package: *
Pin: release n=ceres
Pin-Priority: 90
Adding to sources could be, say, two lines in the file /etc/apt/sources.list with something like the following in it:
deb http://deb.devuan.org/merged ceres main
deb-src http://deb.devuan.org/merged ceres main
Following that preparation, you would first apt-get update and then selectively install by including the desired ceres version code, for example, for that openvpn, you may have:
apt-get install openvpn=2.7.1-1devuan1
The pinning will make it remain so that nothing gets installed from ceres "automatically", ever; including even updates of installed ceres packages. It must all be by hand. If the desired package requires a ceres version of something else, then apt will tell that and refuse installation.
Further, if you want to roll back a ceres package, you again install the package with the desired version code. Doing so will downgrade that package to the indicated version code. Always use apt-cache policy openvpn (or whichever package is concerned) to see which versions you, with your sources, have available for installation (or upgrade or downgrade).
hth, Ralph.
#4 2026-04-19 06:19:29
abower
But you should use backports rather than doing this. That said... the backport has NOT made it to Devuan:
https://pkginfo.devuan.org/cgi-bin/poli … n&x=submit
This is because it is a forked package - so some manual action is needed by a Devuan developer to fork the backport.
But to be honest I don't see why it needs to be forked. I think we should try building the unforked version and consider unforking it.
Edit: https://bugs.devuan.org/955
#5 2026-04-19 18:29:30
grunchy
thanks for the replies! will try both recommendations. marking as solved.
#6 2026-04-20 05:27:11
abower
Sorry, no need to try mine - I was wrong because forked package means the backport is not available in Devuan ywt.
#7 2026-04-26 20:28:47
grunchy
posting a follow-up for completeness.
i did not try installing from ceres as more than one package would be involved.
i was able to install the trixie-backports version, which worked! not sure why the devuan fork is needed.
note that i am using openvpn as a client NOT as a server, so maybe the result would be different when running as a server.
here are the details:
with the ceres version, apt wants to install 2 companion packages
/home/xyz> apt-get -s install openvpn=2.7.2-1devuan1
NOTE: This is only a simulation!
      apt-get needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
Solving dependencies... Error!
 openvpn : Depends: libnl-3-200 (>= 3.11.0) but 3.7.0-2 is to be installed
           Depends: libnl-genl-3-200 (>= 3.11.0) but 3.7.0-2 is to be installed
E: The following information from --solver 3.0 may provide additional context:
   Unable to satisfy dependencies. Reached two conflicting decisions:
   1. libnl-3-200:amd64=3.12.0-2 is not selected for install
   2. libnl-3-200:amd64=3.12.0-2 is selected as an upgrade because:
      1. openvpn:amd64=2.7.2-1devuan1 is selected as an upgrade
      2. openvpn:amd64=2.7.2-1devuan1 Depends libnl-3-200 (>= 3.11.0)
adding those two packages would work, but i do not want to deal with more than one package
/home/xyz> apt-get -s install openvpn=2.7.2-1devuan1 libnl-3-200=3.12.0-2 libnl-genl-3-200=3.12.0-2
  libnl-route-3-200 wpasupplicant
  libnl-3-200 libnl-genl-3-200 openvpn
3 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
Remv wpasupplicant [2:2.10-24]
Remv libnl-route-3-200 [3.7.0-2]
Inst libnl-genl-3-200 [3.7.0-2] (3.12.0-2 Devuan:1.0.0/unstable [amd64]) []
Inst libnl-3-200 [3.7.0-2] (3.12.0-2 Devuan:1.0.0/unstable [amd64])
Inst openvpn [2.7.1-1~bpo13+1] (2.7.2-1devuan1 Devuan:1.0.0/unstable [amd64])
Conf libnl-genl-3-200 (3.12.0-2 Devuan:1.0.0/unstable [amd64])
Conf libnl-3-200 (3.12.0-2 Devuan:1.0.0/unstable [amd64])
Conf openvpn (2.7.2-1devuan1 Devuan:1.0.0/unstable [amd64])
for the excalibur default, openvpn 2.6.14, ldd says this
/home/xyz> ldd /usr/sbin/openvpn
        linux-vdso.so.1 (0x00007884d4b96000)
        liblzo2.so.2 => /lib/x86_64-linux-gnu/liblzo2.so.2 (0x00007884d4a67000)
        liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x00007884d4a40000)
        libpkcs11-helper.so.1 => /lib/x86_64-linux-gnu/libpkcs11-helper.so.1 (0x00007884d4a1f000)
        libssl.so.3 => /lib/x86_64-linux-gnu/libssl.so.3 (0x00007884d4911000)
        libcrypto.so.3 => /lib/x86_64-linux-gnu/libcrypto.so.3 (0x00007884d42d6000)
        libnl-genl-3.so.200 => /lib/x86_64-linux-gnu/libnl-genl-3.so.200 (0x00007884d42cf000)
        libnl-3.so.200 => /lib/x86_64-linux-gnu/libnl-3.so.200 (0x00007884d42ac000)
        libcap-ng.so.0 => /lib/x86_64-linux-gnu/libcap-ng.so.0 (0x00007884d42a4000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007884d40b0000)
        libxxhash.so.0 => /lib/x86_64-linux-gnu/libxxhash.so.0 (0x00007884d409d000)
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007884d407b000)
        libzstd.so.1 => /lib/x86_64-linux-gnu/libzstd.so.1 (0x00007884d3fb1000)
        /lib64/ld-linux-x86-64.so.2 (0x00007884d4b98000)
for trixie-backports, openvpn 2.7.1, ldd says this
        linux-vdso.so.1 (0x00007654370a3000)
        libgtk3-nocsd.so.0 => /lib/x86_64-linux-gnu/libgtk3-nocsd.so.0 (0x0000765436f82000)
        libcap-ng.so.0 => /lib/x86_64-linux-gnu/libcap-ng.so.0 (0x0000765436f7a000)
        libnl-genl-3.so.200 => /lib/x86_64-linux-gnu/libnl-genl-3.so.200 (0x0000765436f73000)
        libnl-3.so.200 => /lib/x86_64-linux-gnu/libnl-3.so.200 (0x0000765436f50000)
        liblzo2.so.2 => /lib/x86_64-linux-gnu/liblzo2.so.2 (0x0000765436f2a000)
        liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x0000765436f03000)
        libpkcs11-helper.so.1 => /lib/x86_64-linux-gnu/libpkcs11-helper.so.1 (0x0000765436ee2000)
        libssl.so.3 => /lib/x86_64-linux-gnu/libssl.so.3 (0x0000765436dd4000)
        libcrypto.so.3 => /lib/x86_64-linux-gnu/libcrypto.so.3 (0x000076543679b000)
        libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007654366d8000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007654364e2000)
        /lib64/ld-linux-x86-64.so.2 (0x00007654370a5000)
        libxxhash.so.0 => /lib/x86_64-linux-gnu/libxxhash.so.0 (0x00007654364cf000)
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007654364af000)
        libzstd.so.1 => /lib/x86_64-linux-gnu/libzstd.so.1 (0x00007654363e5000)
        libcap.so.2 => /lib/x86_64-linux-gnu/libcap.so.2 (0x00007654363d9000)
the extra libraries in the trixie-backports version are libcap.so.2, libgtk3-nocsd.so.0 and libsystemd.so.0.
i do not think the first two libs are what requires the devuan fork, but perhaps i am mistaken.
the reference to libsystemd does seem like it would be the reason for a devuan fork. however, on the
excalibur machine i'm using libsystemd IS present
/home/xyz> ls -l /lib/x86_64-linux-gnu/libsystemd.so.0
lrwxrwxrwx 1 root root 15 Jan 21  2025 /lib/x86_64-linux-gnu/libsystemd.so.0 -> libelogind.so.0
i am curious to know what happens to this symlink when elogind is replaced by dummy-logind.
just guessing, but that symlink looks to be taking care of whatever openvpn wants from libsystemd.
the install of openvpn 2.7.1 from trixie-backports was successful, with no error reported
/home/xyz> sudo apt install /tmp/openvpn_2.7.1-1~bpo13+1_amd64.deb
Note, selecting 'openvpn' instead of '/tmp/openvpn_2.7.1-1~bpo13+1_amd64.deb'
Upgrading:
  openvpn
Summary:
  Upgrading: 1, Installing: 0, Removing: 0, Not Upgrading: 0
  Download size: 0 B / 684 kB
  Space needed: 77.8 kB / 26.1 GB available
Get:1 /tmp/openvpn_2.7.1-1~bpo13+1_amd64.deb openvpn amd64 2.7.1-1~bpo13+1 [684 kB]
Reading changelogs... Done
Preconfiguring packages ...
(Reading database ... 189146 files and directories currently installed.)
Preparing to unpack .../openvpn_2.7.1-1~bpo13+1_amd64.deb ...
Unpacking openvpn (2.7.1-1~bpo13+1) over (2.6.14-1+deb13u1devuan1) ...
Setting up openvpn (2.7.1-1~bpo13+1) ...
Installing new version of config file /etc/init.d/openvpn ...
Installing new version of config file /etc/network/if-down.d/openvpn ...
Installing new version of config file /etc/network/if-up.d/openvpn ...
Processing triggers for man-db (2.13.1-1) ...
and openvpn started-up in client mode without error
2026-04-25 23:52:12 OpenVPN 2.7.1 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO]
2026-04-25 23:52:12 library versions: OpenSSL 3.5.5 27 Jan 2026, LZO 2.10
2026-04-25 23:52:12 DCO version: 6.19.11+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.19.11-1~bpo13+1 (2026-04-13)
<snip>
2026-04-25 23:52:13 chroot to '/tmp/ovc' and cd to '/' succeeded
2026-04-25 23:52:13 UID set to nobody
2026-04-25 23:52:13 GID set to nogroup
2026-04-25 23:52:13 Capabilities retained: CAP_NET_ADMIN
2026-04-25 23:52:13 Initialization Sequence Completed
2026-04-25 23:52:13 Data Channel: cipher 'AES-256-GCM', peer-id: 1
2026-04-25 23:52:13 Timers: ping 10, ping-restart 60
#8 2026-04-27 12:26:05
Hund
May I ask why you bother with OpenVPN when we have WireGuard? smile
#9 2026-04-27 23:26:06
grunchy
laziness primarily :-)
but also customizability
wireguard is easier to set-up and is faster since most everything happens in kernel-space but openVPN offers considerably more flexibility. and my bandwidth needs are so limited there is no real benefit from a higher-speed connection.
openVPN is far more flexible: you can change port, choose from a wide range of cipher and key-exchange choices, have more knobs for authentication and policy control. and you can implement complex rules for split tunneling.
i have invested a lot of time and effort in my VPN configuration over the years - lots of scripts, lots of customizations - so it will require significant effort for me to move away. not too unlike the effort of the upcoming KDE x11-to-wayland transition, which i may avoid by dumping KDE for lxqt, also requiring lots of effort ...
and have also avoided the "apps" provided by the VPN providers, as i prefer to customize my openVPN configurations. not too certain, but recall reading that some VPN providers have a "unique" wireguard implementation that requires you to use their "app", which i will not do. (this is an old memory and may no longer be true)
as i understand it, wireguard's primary appeal is the ease of set-up, so you get what is functionally an IPSec tunnel but without the complexity.
this simplicity means you forgo lots of options, such as running over TCP (port 443) or choosing an encryption protocol.
one of the worrying aspects of wireguard (to me) is that debugging a non-working wireguard setup is difficult and means you need a good amount of networking knowledge. this is made more difficult as there are no logs to examine, so you need to look at routing tables, firewall rules, check for key mismatch, etc. also a wireguard tunnel may silently stop working and you will not know until you try to use it, as there is no error message, no notification that something went wrong.
#10 2026-05-01 13:50:11
MoonDog
My ISP completely blocks Wireguard.  No dns resolution when using it, can't ping anything and when I asked one of their tech support (a friend from Uni), was told the unofficial policy was to block all wireguard connections via some adaptive AI traffic analysis box, but they won't publicly admit to doing so. He said use OpenVPN on the https port because they don't block OpenVPN since it runs on ports that are used by legitimate services and a lot of businesses use it.
As to using latest versions, this is one of a handful of programs that I actually compile from source.  I'm running 2.7.3 which is the latest.  2.7.1 is old now and 2.7.2 introduced two bug fixes, one that can potentially leak packets on handshake and one that affects servers.  Debian packages are rarely fully up to date with the latest releases and definitely not on the day of the new release dropping.
