#1 2026-04-18 16:54:04
dgiglio
[SOLVED] syslog not being rotated
The first entry in /var/log/syslog dates back to October 2025, and the file takes now more than 150MB
The content of /etc/logrotate.d/rsyslog is
/var/log/syslog
/var/log/mail.log
/var/log/kern.log
/var/log/auth.log
/var/log/user.log
/var/log/cron.log
	rotate 4
	weekly
	missingok
	notifempty
	compress
	delaycompress
	sharedscripts
	postrotate
		/usr/lib/rsyslog/rsyslog-rotate
	endscript
while /usr/lib/rsyslog/rsyslog-rotate contains
if [ -d /run/systemd/system ]; then
    systemctl kill -s HUP --kill-whom=main rsyslog.service
else
    invoke-rc.d rsyslog rotate > /dev/null
fi
Any clue?
#2 2026-04-18 17:02:23
Re: [SOLVED] syslog not being rotated
Have a look:
https://dev1galaxy.org/viewtopic.php?id=5763
I have some notes (unfortunately in German) what I did on modifications on my PC.
#3 2026-04-19 08:55:52
dgiglio
Editing /etc/logrotate.d/rsyslog like this
	postrotate
	endscript
solved the issue. I suppose there's something wrong in the /usr/lib/rsyslog/rsyslog-rotate test condition
#4 2026-04-19 09:10:42
abower
Please share your Devuan release and package versions. This should be fixed in Devuan already.
Edit: also whether you are using runit-init and if so, whether you have runit-services installed, and which version.
#5 2026-04-19 16:09:05
Check if /run/systemd/system exists on your system. That would cause the test to fail.
