#1 2026-04-16 09:49:31
sysv_penguin
[SOLVED] Can't find libfuse2 on devuan/feria
This package is needed by a dozen of my AppImages to work properly. They refuse to open without this package.
running sudo apt search libfuse returns this:
golang-github-hanwen-go-fuse-dev/testing 2.8.0-1 all
  Native Go bindings for the FUSE kernel module
libfuse3-4/testing,now 3.18.2-1 amd64 [installed,automatic]
  Filesystem in Userspace (library) (3.x version)
libfuse3-dev/testing 3.18.2-1 amd64
  Filesystem in Userspace (development) (3.x version)
python3-pyfuse3/testing 3.4.0-3+b4 amd64
  Python 3 bindings for libfuse 3 with asynchronous API
python3-pyfuse3-doc/testing 3.4.0-3 all
  Python 3 bindings for libfuse 3 with asynchronous API (documentation)
How can I install this library on my system?
#2 2026-04-16 10:13:19
Re: [SOLVED] Can't find libfuse2 on devuan/feria
My first reaction was: that lib is outdated.
Then I had a look at my Excalibur. There I got listed libfuse2/now 2.9.9-6+b1 amd64 which is installed locally, and libfuse2t64/stable 2.9.9-9 amd64 which isn't installed. Haven't digged any deeper. Don't know why/how libfuse2 was installed, can't remember any special operation.
libfuse2 is from bookworm, libfuse2t64 is from Trixie, there is nothing in Forky/Freia.
You could try libfuse2t64. But I think you need to download it from Trixie/Excalibur and then install it locally. Same is vald for libfuse2 from Bootkworm/Daedalus.
Update: some search revealed that libfuse2 was installed because of Veracrypt.
#3 2026-04-16 22:43:29
sysv_penguin
Indeed, It's outdated but it is a crutial for A LOT of AppImages out there to run properly.
I ended up with an isolated solution to keep everything separated from apt/system packages.
Downloaded libfuse deb from ubuntu questing repo.
Extracted the *.so files and put it inside /opt/libfuse2/
Made a conf file inside /etc/ld.so.conf.d/
Like this:
$ cat /etc/ld.so.conf.d/fuse2compat.conf
/opt/libfuse2/
Then I ran: sudo ldconfig
#4 2026-04-17 11:40:38
Elyon
Thinkpad x280 - Devuan Excalibur 6 - Xfce Desktop Environment - Apt/Appman
#5 2026-04-17 13:00:51
Why that complicated.
In the top left corner of this forum there is a link to the Devuan packages. Search for libfuse2, then goto 2.9.9-6+b1 which is the latest version, and download the deb under Filename.
Copy the download to /tmp, cd there as root and run dpkg -i *.deb and you are done.
