#1 2026-04-01 23:05:27
Youtube videos 'not available'
All of a sudden (as of today 01/04) I am unable to watch YouTube videos and as a result cannot watch late night show snippets.
eg: Colbert, Kimmel, Meyers and Oliver.
All I get is 'video not available'.
Does not seem to be an AF joke.
Anyone having the same issue?
#2 2026-04-01 23:14:10
brocashelm
Re: Youtube videos 'not available'
No issues at all with FreeTube. Maybe it's your IP address?
#3 2026-04-01 23:31:33
Never heard of it, downloaded the appimage put in the link but I get continuous/permanent SABR messages.
Other videos have the same problem.
This is the first time I've seen this.
Happens with FF, palemoon and LibreWolf, with or without Pi-Hole.
It was working perfectly yesterday.
#4 2026-04-02 01:54:00
dzz
https://www.bitchute.com/ukregulation
Not necessarily saying the reason is related...
#5 2026-04-02 03:12:32
brocashelm
Sounds like it's time to start using a VPN...
#6 2026-04-02 11:29:26
Elyon
I'm using since yesterday. got a great offer at protonvpn. could watch couple of movies blocked in the EU. great stuff.
Thinkpad x280 - Devuan Excalibur 6 - Xfce Desktop Environment - Apt/Appman
#7 2026-04-02 11:37:46
Duke Nukem
I'm not having a problem with YT, and I'm in the UK.
#8 2026-04-02 12:05:08
Calamity
Youtube is a bleeding nightmare to use in my country, but I still manage to access it occasionally.
Sometimes it's the ISP's fault, sometimes the site itself blocks certain videos if you don't have an account, try to watch through embedded link or use a frontend like Invidious.
Re-examine all that you have been told. Dismiss that which insults your soul.  - Walt Whitman
Dump shampoo and hair dye
Global Skywatch・Subliminal Manipulation
#9 2026-04-02 16:54:56
Calamity wrote:
... use a frontend like Invidious.
Found out about it last night.
It seems to work but YT/Google is trying to foil their efforts.
Still have to see how to make using it more straightforward but for the time being it will do.
#10 2026-04-02 17:15:53
Calamity
Invidious used to work great, now it's far less reliable - the big <G> is onto them (and here I also have to deal with the regional blocklist to even get to it).
Previously they nipped Hooktube in the bud, but this one is not going down so easy.
#11 2026-04-02 17:59:33
fanderal
Freetube worked at YT last night.
Was using invidious for a while: https://invidious.io/. If blocked by YT, was easy/quick to change to another invidious instance and watch the video.
Noticed that, too.
Started using freetube last year. YT occasionally blocks it but an updated freetube is available within a day or two to a week. FWIW, it's the same occational YT block/fix for youtubedl-gui.
You might try the deb pkg from their site:
https://freetubeapp.io/#download
#12 2026-04-02 19:27:00
Calamity
Installed the deb, looks good - thanks for the suggestion!
#13 2026-04-03 14:16:02
dzz
Another alternative to browser-based youtube. Nice gtk interface and is GPL:
https://github.com/trizen/pipe-viewer
Some salvation from *ogle surveillance and maybe a workaround for some blocked content.
Also mpv in conjunction with yt-dlp can stream youtube content directly, if you have the url.
#14 2026-04-03 20:27:49
I wrote:
All of a sudden (as of today 01/04) I am unable to watch YouTube videos ...
Don't know just what may be going on, but ...
All of a sudden (as of today 03/04 17:20 GMT -03:00) I am able to watch YouTube videos again.
Now ...
Was it a glitch that got fixed?
Was there backlash and the block was rolled back?
No idea.
Let's see how long it lasts.
Anyhow, thanks to all those who chipped in.
#15 2026-04-06 10:19:27
Kristof12
The first five days, it was kinda common, open a channel and "no videos here lmao" was quite funny, only way to watch in a stable way for me was to use a VPN yeah
#16 2026-04-06 12:44:50
For Android I can recommend Newpipe (apk download) for Tube viewing. Sometimes *oogle blocks it but then there's a new update coming pretty soon.
#17 2026-04-12 19:54:07
And we're baaaaaaaaack!
After rolling back on the previous 'not available' block, now you cannot see a YouTube video unless you sign in.
For the protection of our | their the community, obviously.
What were you thinking? 8^°
But Invidious still works.
For now.
Kudos to them.
