#1 2026-03-27 15:16:15
amaro
mpv annoying pipewire messages
Hello everybody!
I get the following annoying messages in console when playing mp3 files
mpv --shuffle --volume=78 --no-video *
[W][16:58:58.002110] pw.module    | [   impl-module.c:   64 find_module()] could not open /usr/lib/x86_64-linux-gnu/pipewire-0.3: No such file or directory
[E][16:58:58.002777] pw.core      | [          core.c:  389 core_new()] 0x56172de4c5f0: can't find protocol 'PipeWire:Protocol:Native': Operation not supported
Looks like something 'pipewire' related is missing. How to fix it?
Thank you in advance!
#2 2026-03-27 15:21:44
Elyon
Re: mpv annoying pipewire messages
https://dev1galaxy.org/viewtopic.php?id=5867
Maybe install pipewire if that's what you need?
Edit:
I've tried your command on my system. don't get similar message as yours and everything looks well and good.
sudo apt search pipewire-0.3
libpipewire-0.3-0t64/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  Biblioteki dla serwera multimedialnego PipeWire
libpipewire-0.3-common/stable,stable,now 1.4.2-1 all [zainstalowany,automatyczny]
  libraries for the PipeWire multimedia server - common files
libpipewire-0.3-dev/stable 1.4.2-1 amd64
  libraries for the PipeWire multimedia server - development
libpipewire-0.3-modules/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  Biblioteki dla serwera multimedialnego PipeWire - moduły
libpipewire-0.3-modules-x11/stable 1.4.2-1 amd64
  libraries for the PipeWire multimedia server - X11 modules
libpipewire-0.3-modules-xrdp/stable 0.2-2+b1 amd64
  libraries for the PipeWire multimedia server - xrdp modules
There  are three packages installed on my system. maybe you're missing them?
Thinkpad x280 - Devuan Excalibur 6 - Xfce Desktop Environment - Apt/Appman
#3 2026-03-27 16:11:33
amaro
You were right. I was missing the 'libpipewire-0.3-modules' package. I installed it.
Now I get
[E][17:53:21.048964][ plugin_ladspa.c:  339 impl_init()] failed to load plugin '/usr/lib/ladspa/ZamGate-ladspa.so': No such file or directory
[E][17:53:21.049080] spa.filter-graph | [  filter-graph.c:  908 plugin_load()] can't load plugin type 'ladspa': No such file or directory
[E][17:53:21.049099] spa.filter-graph | [  filter-graph.c: 2384 impl_init()] can't load graph: No such file or directory
[E][17:53:21.049397] pw.core      | [          core.c:  389 core_new()] 0x55d958e9c060: can't find protocol 'PipeWire:Protocol:Native': Operation not supported
#4 2026-03-27 16:16:19
Elyon
Does sudo apt install lsp-plugins-ladspa solve the problem?
#5 2026-03-27 16:31:37
amaro
I installed it but it did nothing. I still get the same messages.
What I don't understand is why 'mpv' throws such messages if 'pipewire-audio' is not installed on my system.
#6 2026-03-27 16:57:31
Elyon
libkpipewire-data/stable,stable,now 6.3.6-1 all [zainstalowany,automatyczny]
  KDE's Pipewire libraries - data files
libkpipewire6/stable,now 6.3.6-1 amd64 [zainstalowany,automatyczny]
  KDE's Pipewire libraries - libkpipewire6 library
libkpipewiredmabuf6/stable,now 6.3.6-1 amd64 [zainstalowany,automatyczny]
  KDE's Pipewire libraries - libkpipewiredmabuf6
libkpipewirerecord6/stable,now 6.3.6-1 amd64 [zainstalowany,automatyczny]
  KDE's Pipewire libraries - libkpipewirerecord6
libspa-0.2-bluetooth/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  libraries for the PipeWire multimedia server - bluetooth plugins
libspa-0.2-modules/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  Biblioteki dla serwera multimedialnego PipeWire Simple Plugin API - moduły
libwireplumber-0.5-0/stable,now 0.5.8-2 amd64 [zainstalowany,automatyczny]
  Shared libraries for WirePlumber
pipewire/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  audio and video processing engine multimedia server
pipewire-bin/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  Serwer multimedialny PipeWire - programy
pipewire-pulse/stable,now 1.4.2-1 amd64 [zainstalowany,automatyczny]
  PipeWire PulseAudio daemon
qml6-module-org-kde-pipewire/stable,now 6.3.6-1 amd64 [zainstalowany,automatyczny]
  KDE's Pipewire libraries - QML module
wireplumber/stable,now 0.5.8-2 amd64 [zainstalowany,automatyczny]
  modular session / policy manager for PipeWire
Neither is pipewire-audio installed here.
When searching for pipewire apt shows me those packages as installed. Maybe you're still missing some or there is some configuration error?
#7 2026-03-27 21:42:33
amaro
Looks like a lot of the packages you have are not installed on my system
asr pipewire | grep installed
libpipewire-0.3-0t64/testing,now 1.6.2-1 amd64 [installed,automatic]
libpipewire-0.3-common/testing,now 1.6.2-1 all [installed,automatic]
libpipewire-0.3-modules/testing,now 1.6.2-1 amd64 [installed]
libpipewire-0.3-modules-x11/testing,now 1.6.2-1 amd64 [installed]
libspa-0.2-modules/testing,now 1.6.2-1 amd64 [installed,automatic]
#8 2026-03-28 16:51:35
amaro
I installed the missing packages and there is some kind of an improvement. Since the 'mpv' shuffles the files I tested this a few times. The result is the same - no matter which song is played first I get this message
[E][11:55:35.888891][ plugin_ladspa.c:  339 impl_init()] failed to load plugin '/usr/lib/ladspa/ZamGate-ladspa.so': No such file or directory
[E][11:55:35.890677] spa.filter-graph | [  filter-graph.c:  908 plugin_load()] can't load plugin type 'ladspa': No such file or directory
[E][11:55:35.890709] spa.filter-graph | [  filter-graph.c: 2384 impl_init()] can't load graph: No such file or directory
[E][11:55:35.891041] pw.core      | [          core.c:  389 core_new()] 0x55cd9ac10520: can't find protocol 'PipeWire:Protocol:Native': Operation not supported
And then while playing the rest of the songs the message no longer appears. I find this strange.
#9 2026-03-28 17:58:39
Elyon
What's inside your /usr/lib/ladspa/ directory? Is there ZamGate-ladspa.so present?
#10 2026-03-29 18:53:56
amaro
# ls  /usr/lib/ladspa/
lsp-plugins-ladspa.so
p.s. upon reboot the strange effect (regarding the first played song only) disappeared and now 'mpv' again throws the same bunch of message on every song.
#11 2026-03-30 10:38:09
Elyon
So the message says that you're missing ZamGate-ladspa.so library. Does installing zam-plugins solve the issue? This package should provide the missing library.
#12 2026-03-31 14:34:46
amaro
Installed the 'zam-plugins' package. Now I get this
[E][17:29:29.641816] pw.core      | [          core.c:  389 core_new()] 0x5633fd18a6e0: can't find protocol 'PipeWire:Protocol:Native': Operation not supported
[E][17:29:29.641858] mod.filter-chain | [module-filter-ch: 2096 pipewire__module_init()] can't connect: Operation not supported
[E][17:29:29.642273] pw.core      | [          core.c:  389 core_new()] 0x5633fd18a6e0: can't find protocol 'PipeWire:Protocol:Native': Operation not supported
There is a difference - the errors are just 3 and the first and the third are actually identical.
