#1 2017-07-02 18:37:16
GNUser
automatic mac address spoofer
If you are paranoid about privacy like me, you will like this little creation of mine.
EDIT: Final version of script is in post #7. Options for running it automatically at appropriate time are in post #8.
#2 2017-07-05 02:57:14
PeteGozz
Re: automatic mac address spoofer
Thank you.
There is _much_ here that is useful and good smile
#3 2018-01-25 20:42:15
siva
Thank you for sharing this.  My only question is, how does this differ from macchanger?
#4 2019-03-08 18:44:39
freenet_bro
This script doesn't seem to work for computers connected via ethernet.
Is there a similar script for that or how would I need to modify the script you posted?
#5 2019-03-08 20:39:03
GNUser
@siva: Simplicity and total customizability. Why install a package when a simple shell script will do?
@freenet_bro: See posts #7 and #8.
#6 2019-03-09 16:27:29
freenet_bro
cool, the script works.
But I don't know how to run it at boot time.
I've used `chmod +x mac-spoofer' to make it executable and copied it to `/etc/init.d/'.
Have I missed something?
#7 2019-03-10 13:09:53
GNUser
I revised the scripts so that they have no special dependencies--all the utilities the scripts need are part of a standard *nix installation.
Use this version of the script to generate a random MAC address at each boot:
iface=wlan0
# create fake mac, preserving vendor bits:
real_mac=$(ifconfig $iface | grep ether | awk '{print $2}')
vendor_bits=$(echo $real_mac | cut -d ':' -f 1-3)
random_dec1=$(shuf --input-range=0-255 -n 1); random_hex1=$(printf "%02x" $random_dec1)
random_dec2=$(shuf --input-range=0-255 -n 1); random_hex2=$(printf "%02x" $random_dec2)
random_dec3=$(shuf --input-range=0-255 -n 1); random_hex3=$(printf "%02x" $random_dec3)
fakemac=$(printf "%s:%s:%s:%s" $vendor_bits $random_hex1 $random_hex2 $random_hex3)
# apply fake mac
ip link set $iface address $fakemac
Use this version of the script if you want to keep a fake MAC address for a whole day, regardless of how many times you reboot:
iface=wlan0
fakemac_file=/etc/fakemac-$(date +%j)
if [ -e "$fakemac_file" ]; then # we already have a fakemac file for today
	true
else # remove old fakemac file and create a new one
	rm -f /etc/fakemac*
	printf "$fakemac" >$fakemac_file
fi
# apply fake mac
ip link set $iface address $(cat $fakemac_file)
BTW, notice that the scripts preserve the first 3 bytes of the MAC address, fake only the last 3 bytes. The point of this is that the first 3 bytes identify the network device's vendor/manufacturer. You don't want the vendor bytes to be random: Doing so would make your MAC address obviously fake and you would stand out. Not what we want.
#8 2019-03-11 01:01:46
GNUser
@freenet_bro: There are several ways to run the mac-spoofer script (either version) at boot, as root, before connecting to the internet. The two most obvious ones are via cron or via init.
Option 1: Via cron
Open up a terminal and run this command as root: EDITOR=nano crontab -e then add these two lines to the bottom of the file:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
@reboot /path/to/mac-spoofer
Reboot and enjoy.
Option 2: Via init
There are four steps required, freenet_bro: Put the script in the /etc/init.d directory, make it executable, add LSB headers to top of script, install script links in the /etc/rc?.d directories. You missed the last two steps.
Here is what the script looks like with LSB headers (if you use a network manager other than network-manager, adjust the X-Start-Before line accordingly):
### BEGIN INIT INFO
# Provides:          mac-spoofer
# Required-Start:    $network
# Required-Stop:
# Should-Start:
# Should-Stop:
# X-Start-Before:    network-manager
# Default-Start:     2 3 4 5
# Default-Stop:
# Short-Description: simple mac-spoofer
# Description:       spoof mac address before connecting to internet
### END INIT INFO
iface=wlan0
	true
	rm -f /etc/fakemac*
fi
# apply fake mac
To install the script links, open up a terminal and type this as root (assuming you named the script mac-spoofer):
update-rc.d mac-spoofer defaults
Reboot and enjoy.
#9 2019-03-11 10:21:08
freenet_bro
@GNUser: Thank you very much for the script and the explanation. I really appreciate it.
#10 2019-03-11 11:42:33
GNUser
@freenet_bro: You're welcome, glad I could help. It was also good to make the script more general and less complicated.
#11 2019-06-12 04:43:16
czeekaj
thanks man this is awesome, I'll make a fresh install at some point and pack this into a live iso. wink
